Hi all,
Something to share for those who use the USB-C serial console from another Linux host. Install and use 'tio' to connect to the serial console instead of minicom. This supports both 1500k baud and also can be easily used inside GNU screen (minicom gets a meta key conflict per default; CTRL-A is default meta key for both GNU screen and minicom). Minicom resulted in regular errors posted in syslog by the ftdi_sio kernel module. Did not run any strace to find out what syscall is causing it, but in short, tio appears to not treat the tty as a modem: no errors are popping up in syslog. Hopefully the serial consoles will remain up now.
One caveat: I did not find a way to send a BREAK over serial using tio. This is something that is handy in case kernel freezes up, as sometimes you will still have opportunity to do a magic sysrq triggered reboot (BREAK + b = initiate a reboot of the kernel, also see magic sysrq & REISUB).
Groetjes,
  Reveal hidden contents
