Armbian on S905W TVBOX (A95X F1) | WIFI Chip SV6051P
hannah
Issue: No WIFI in my TV Box
My BOX:
A95X F1 Amlogic S905W Quad core 2GB DDR3 16GB eMMC 2.4G WIFI Chip SV6051P
hxxps://www.youtube.com/watch?v=BL-bbD_X0v0
Note I have thoroughly reviewed this thread and still unable to get wifi in this box.
Here are the details:
- Image used:
https://mega.nz/folder/j9QSDQSQ#6WpasOlbZYIInfw6yo4phQ/file/78xiBbga
Image Name: Armbian_20.10_Arm-64_focal_current_5.9.0_desktop.img.xz
- dtb used = meson-gxl-s905w-p281.dtb
root@arm-64:/boot/extlinux# less extlinux.conf
# aml s9xxx
FDT /dtb/amlogic/meson-gxl-s905w-p281.dtb
APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
- armbian info:
root@arm-64:/boot/extlinux# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=arm-64
BOARD_NAME="ARM-64"
BOARDFAMILY=arm-64
BUILD_REPOSITORY_URL=https://github.com/150balbes/Build-Armbian.git
BUILD_REPOSITORY_COMMIT=62b8c07-dirty
DISTRIBUTION_CODENAME=focal
DISTRIBUTION_STATUS=supported
VERSION=20.10
LINUXFAMILY=arm-64
BRANCH=current
ARCH=arm64
IMAGE_TYPE=user-built
BOARD_TYPE=conf
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
root@arm-64:/boot/extlinux# uname -a
Linux arm-64 5.9.0-arm-64 #20.10 SMP PREEMPT Wed Oct 14 12:04:42 MSK 2020 aarch64 aarch64 aarch64 GNU/Linux
- no wlan0 interface
root@arm-64:~# nmcli device show | grep -i general.device
GENERAL.DEVICE:                         eth0
GENERAL.DEVICE:                         lo
- I see ssv* files in firmware folder
root@arm-64:/boot/extlinux# ls -l /lib/firmware/ssv*
-rw-rw-r-- 1 root root 81176 Nov 20 19:21 /lib/firmware/ssv6051-sw.bin
-rw-rw-r-- 1 root root  2494 Nov 20 19:21 /lib/firmware/ssv6051-wifi.cfg
-rwxrwxr-x 1 root root 39808 Nov 20 19:21 /lib/firmware/ssv6x5x-sw.bin
-rwxrwxr-x 1 root root  3373 Nov 20 19:21 /lib/firmware/ssv6x5x-wifi.cfg
root@arm-64:/boot/extlinux# ls -l /usr/lib/firmware/ssv*
-rw-rw-r-- 1 root root 81176 Nov 20 19:21 /usr/lib/firmware/ssv6051-sw.bin
-rw-rw-r-- 1 root root  2494 Nov 20 19:21 /usr/lib/firmware/ssv6051-wifi.cfg
-rwxrwxr-x 1 root root 39808 Nov 20 19:21 /usr/lib/firmware/ssv6x5x-sw.bin
-rwxrwxr-x 1 root root  3373 Nov 20 19:21 /usr/lib/firmware/ssv6x5x-wifi.cfg
- I created this file ssv6051.conf
root@arm-64:/etc/modprobe.d# cat ssv6051.conf
options ssv6051 stacfgpath=/lib/firmware/ssv6051-wifi.cfg
At this time I do not see any wlan0 interface and thus WIFI is NOT available.
Kindly assist and guide me.
Regards
Hannah
Edited by hannah
Link to post
Share on other sites
@hannah
no way to get ssv6051 wifi on mainline kernel, not until someone writes a proper driver for it.
ssv6051 driver exists on rockchip 4.4 kernel, but it is so poorly written that nobody never cared to rewrite it.
That's a bit of a pity, because that wifi chip and its bigger brother (the ssv6256p) have quite reasonable performance.
Link to post
