xwalter Posted July 17, 2016 Posted July 17, 2016 hello everyone ! I'm trying to listen music with my orange pi over armbian of course. I have installed VLC and it seems works but not sound . I use the 3,5mm output connected to the amplifier At the moment no sound and no music .... Does anyone know what I have to do ? Thanks in advanced Walter
aliceander Posted July 17, 2016 Posted July 17, 2016 Did you read through the pinned thread [Tutorial] Orange Pi One - adding USB, analog audio out, TV out, mic and IR receiver at the top of the forum? I know it has some information on audio; hopefully it has something pertaining to your issue. 1
Ford Prefect Posted July 17, 2016 Posted July 17, 2016 I think that by default VLC uses the HDMI sound output. You must select audio codec in "preferences" and save it IIRC. Some choices are only effective if you restart VLC. I had no problems selecting various USB audio out devices with VLC. I use an audio/video cable that was tested with an android distribution. aplay -l is useful to list the various audio out devices available.
xwalter Posted July 18, 2016 Author Posted July 18, 2016 if I type lsmod I cannot see any driver for the sound . Do you think is this the problem?
jernej Posted July 18, 2016 Posted July 18, 2016 if I type lsmod I cannot see any driver for the sound . Do you think is this the problem? No, because all H3 sound drivers except spdif are built-in in kernel and are not loaded as modules.
borombo Posted July 19, 2016 Posted July 19, 2016 check your /etc/asound.conf file. Try this one and use dmixer as default output device ------------------------------------------------------------ pcm.!default { type plug slave.pcm "dmixer" } pcm.dmixer { type dmix ipc_key 1024 slave { pcm "hw:0,0" period_time 0 period_size 1024 buffer_size 4096 rate 44100 } bindings { 0 0 1 1 } } ctl.dmixer { type hw card 0 } ------------------------------------------------------------
The_Loko Posted July 19, 2016 Posted July 19, 2016 The default sound output is hdmi, you need to change it on /etc/asound.conf. This is the default file: pcm.!default { type hw card 1 } ctl.!default { type hw card 1 } You need to change the card number to 0 on both lines, if it is not 0 you can check the card number with cat /proc/asound/cards
