nottledim Posted July 17, 2016 Posted July 17, 2016 Hi, Just installed Armbian (5.14) on SD card and tried in my OrangePi plus. It doesn't start to boot - it does nothing. I can boot by initiating boot from the system console. I've upgraded to 5.16 but still doesn't boot. Also where do I get gpio? I notice /boot/boot.cmd uses gpio but it doesn't exist. Thanks
wildcat_paris Posted July 17, 2016 Posted July 17, 2016 hello @nottledim, - make sure you have a proper power supply (according to the board manufacturer) - make sure you have a reliable SDcard https://github.com/igorpecovnik/lib/blob/master/documentation/user-faq.md
tkaiser Posted July 17, 2016 Posted July 17, 2016 I can boot by initiating boot from the system console. I've upgraded to 5.16 but still doesn't boot. Well, that's confusing. Armbian doesn't boot but you upgraded it to 5.16? Anyway: You should elaborate a bit more on what you're doing, this might improve chances/quality of answers. In case you use a serial console and booting needs manual intervention then perhaps the UART adapter is stopping u-boot's autoboot behaviour (we see this from time to time and not only UART adapters are responsible for this but sometimes also USB peripherals). GPIO statements in boot.cmd are unrelated to access to GPIO pins. Take a look into /etc/modules, load the approriate module and access GPIO pins from sysfs (Wiring$Something should also work but I never used this since I fail to understand why one has to use a cloned WiringPi library anyway)
nottledim Posted July 17, 2016 Author Posted July 17, 2016 (edited) Well, that's confusing. Armbian doesn't boot but you upgraded it to 5.16? Sorry to confuse - it doesn't auto boot. I have to attach a console to ttyS0 and tell it to boot. It works after that. Anyway: You should elaborate a bit more on what you're doing, this might improve chances/quality of answers. In case you use a serial console and booting needs manual intervention then perhaps the UART adapter is stopping u-boot's autoboot behaviour (we see this from time to time and not only UART adapters are responsible for this but sometimes also USB peripherals). The only reason I used sys console was because it didn't boot and I was looking for some messages. It stops at the boot prompt. There's nothing special about this system - it's just an OP+ board an ethernet cable and a USB keyboard dongle. The PSU can supply 2.5A if needed - it powers peripherals like HDD OK when they're attached. I have no trouble booting other systems. The SD card is new - a Samsung EVO 16G. It looks genuine but who knows! I'll try another if I can find one. It is unproven in this case. GPIO statements in boot.cmd are unrelated to access to GPIO pins. Take a look into /etc/modules, load the approriate module and access GPIO pins from sysfs (Wiring$Something should also work but I never used this since I fail to understand why one has to use a cloned WiringPi library anyway) OK, thanks - Sounds interesting - I'll look into that. Thanks Edited July 17, 2016 by zador.blood.stained Fixed quote blocks for easier understanding
zador.blood.stained Posted July 17, 2016 Posted July 17, 2016 I can boot by initiating boot from the system console. I've upgraded to 5.16 but still doesn't boot. Please provide full u-boot output from serial console up to the point where it drops to a command prompt.
nottledim Posted July 17, 2016 Author Posted July 17, 2016 That was easier said than done. I've not seen that before (because I've been starting terminal emulator after applying power to OP+) U-Boot SPL 2016.05-armbian (Jul 05 2016 - 17:49:33)DRAM: 1024 MiBTrying to boot from MMC1U-Boot 2016.05-armbian (Jul 05 2016 - 17:49:33 +0200) Allwinner TechnologyCPU: Allwinner H3 (SUN8I 1680)Model: Xunlong Orange Pi PlusI2C: readyDRAM: 1 GiBMMC: SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1*** Warning - bad CRC, using default environmentIn: serialOut: serialErr: serialNet: No ethernet found.starting USB...USB0: USB EHCI 1.00USB1: USB EHCI 1.00scanning bus 0 for devices... 5 USB Device(s) foundscanning bus 1 for devices... Device NOT ready Request Sense returned 02 3A 002 USB Device(s) foundHit any key to stop autoboot: 0=> I see it's trying to boot from emmc card rather than SD card. emmc card contains a lorobis system. I probably need to switch something back to default to SD card. How do I do that?
zador.blood.stained Posted July 17, 2016 Posted July 17, 2016 U-Boot SPL 2016.05-armbian (Jul 05 2016 - 17:49:33) DRAM: 1024 MiB Trying to boot from MMC1 This is definitely SPL from an Armbian u-boot Hit any key to stop autoboot: 0 => This looks like interrupted boot sequence, u-boot doesn't try to load anything and drops to a command prompt. Can you try disconnecting all USB devices before booting (and also start terminal emulator before powering on the board)?
nottledim Posted July 17, 2016 Author Posted July 17, 2016 That's interesting. I removed everything and it didn't boot. Then I noticed that innocent looking keyboard dongle was still plugged in. Once removed it booted: U-Boot SPL 2016.05-armbian (Jul 05 2016 - 17:49:33)DRAM: 1024 MiBTrying to boot from MMC1U-Boot 2016.05-armbian (Jul 05 2016 - 17:49:33 +0200) Allwinner TechnologyCPU: Allwinner H3 (SUN8I 1680)Model: Xunlong Orange Pi PlusI2C: readyDRAM: 1 GiBMMC: SUNXI SD/MMC: 0 (SD), SUNXI SD/MMC: 1*** Warning - bad CRC, using default environmentIn: serialOut: serialErr: serialNet: No ethernet found.starting USB...USB0: USB EHCI 1.00USB1: USB EHCI 1.00scanning bus 0 for devices... 2 USB Device(s) foundscanning bus 1 for devices... Device NOT ready Request Sense returned 02 3A 002 USB Device(s) foundHit any key to stop autoboot: 0switch to partitions #0, OKmmc0 is current deviceScanning mmc 0:1...Found U-Boot script /boot/boot.scr2444 bytes read in 182 ms (12.7 KiB/s)## Executing script at 43100000gpio: pin PL10 (gpio 298) value is 1gpio: pin PG11 (gpio 203) value is 1** File not found /boot/.verbose **** File not found /boot/.next **** Unrecognized filesystem type **** File not found .next **37328 bytes read in 436 ms (83 KiB/s)3134678 bytes read in 3137 ms (975.6 KiB/s)5011576 bytes read in 5011 ms (976.6 KiB/s)Kernel image @ 0x48000000 [ 0x000000 - 0x4c7878 ]## Loading init Ramdisk from Legacy Image at 42000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3134614 Bytes = 3 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OKUsing machid 0x1029 from environmentStarting kernel ...[sun8i_fixup]: From boot, get meminfo: Start: 0x40000000 Size: 1024MBion_carveout reserve: 160m@0 256m@0 130m@1 200m@1ion_reserve_select: ion chipid [0x2004620!ion_reserve_common: ion reserve: [0x50000000, 0x60000000]!Debian GNU/Linux 8 orangepiplus ttyS0orangepiplus login: I tried it again with he dongle in the other USB socket (usb1) and it boots OK. It also boots OK if there is different device in usb2.
martinayotte Posted July 17, 2016 Posted July 17, 2016 Then I noticed that innocent looking keyboard dongle was still plugged in. Once removed it booted So, that dongle wasn't so innocent ...
nottledim Posted July 17, 2016 Author Posted July 17, 2016 So, that dongle wasn't so innocent ... no, so it would seem. It works OK in usb1 socket. I'm just wondering why. Maybe it's to do with the order the usb buses are started. Dunno. Anyway, I learned a lot from the whole exercise.
