jlaurencin Posted December 16, 2020 Posted December 16, 2020 (edited) On 12/16/2020 at 10:41 AM, gprovost said: Yes new packages with required driver are ready, you can just do the usual apt-get update && apt-get upgrade then reboot. Expand Hello, Sorry for my bad english, I'm French, I'm using "Armbian_20.11.4_Helios64_buster_current_5.9.14.img.xz" During the startup sequence I get the following errors: GPT 0x3380ec0 signature is wrong recovery gpt... GPT 0x3380ec0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 Load OK, addr=0x200000, size=0xdd6b0 RunBL31 0x40000 NOTICE: BL31: v1.3(debug):42583b6 NOTICE: BL31: Built : 07:55:13, Oct 15 2019 NOTICE: BL31: Rockchip release version: v1.1 INFO: GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3 INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: plat_rockchip_pmu_init(1190): pd status 3e INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.07-armbian (Dec 15 2020 - 08:45:45 +0100) SoC: Rockchip rk3399 Reset cause: RST DRAM: 3.9 GiB PMIC: RK808 SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB MMC: mmc@fe320000: 1, sdhci@fe330000: 0 Loading Environment from MMC... *** Warning - bad CRC, using default environment How to solve them? Edited December 17, 2020 by aprayoga Move to separate thread
aprayoga Posted December 16, 2020 Posted December 16, 2020 @jlaurencin it's just a warning, not a problem. https://www.denx.de/wiki/view/DULG/WarningBadCRCUsingDefaultEnvironment
jlaurencin Posted December 16, 2020 Author Posted December 16, 2020 But I've reinstalled several times, each time I reboot it crashes the system startup.
jlaurencin Posted December 16, 2020 Author Posted December 16, 2020 I think the real problem is "GPT 0x3380ec0 signature is wrong" and I don't know how to resolve that.
aprayoga Posted December 17, 2020 Posted December 17, 2020 No, that is not an issue. Please provide complete serial console log. Is this the first time setup? Did you upgraded from previous version? Where did you install the Armbian, eMMC or micro SD card?
