IvMa Posted December 19, 2020 Posted December 19, 2020 I can't burn a 256GB SD, neither with Etcher nor with dd. With an 8Gb Sd everything works. Thanks Board:
Werner Posted December 19, 2020 Posted December 19, 2020 Writing sd cards with something else than USBimager or Etcher is unsupported and the dd command itself says basically nothing about what the issue/error is.
IvMa Posted December 19, 2020 Author Posted December 19, 2020 Sorry I was wrong to attach the file, the ext4 partition is not created correctly.
Igor Posted December 19, 2020 Posted December 19, 2020 2 hours ago, IvMa said: Sorry I was wrong to attach the file, the ext4 partition is not created correctly. What are you trying to burn? Which image? Armbian?
IvMa Posted December 19, 2020 Author Posted December 19, 2020 3 minutes ago, Igor said: What are you trying to burn? Which image? Armbian? The image is: Armbian_20.10_Arm-64_focal_current_5.9.0.img with an 8Gb Sd it works with the 256Gb one no.
Igor Posted December 19, 2020 Posted December 19, 2020 1 minute ago, IvMa said: Armbian_20.10_Arm-64_focal_current_5.9.0.img Aha, unofficial builds, can't help. Check this: https://docs.armbian.com/User-Guide_Getting-Started/#how-to-check-download-authenticity
