Pine64 kernel panic after power failure
Go to solution Solved by Igor,
I have been running Armbian on a headless Pine64 (the kickstarter one) for quite sometime without any issues. Last week I woke up in the morning and noticed that there had been a power cut. The Pine64 was on again but I couldn't SSH into it. I plugged a monitor and found the system hangs while booting with the following error:
Error while loading shared libraries: lib system-shares-241.so: cannot open shared object file: No such file or directory
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00007f00
CPU: 1 PID: 1 Comm: init Not tainted 5.4.43-sunxi64 #20.05.2
Hardware name: Pine64+ (DT)
Call trace:
dump_backtrace+0x0/0x180
show_stack+0x14/0x20
dump_stack+0xb0/0xd8
panic+0x144/0x310
do_exit+0x974/0x9a8
do_group_exit+0x40/0xa8
_arm64_sys_exit_group+0x14/0x18
el0_svc_common.constprop.2+0x88/0x150
el0_svc_handler+0x20/0x80
el0_svc+0x8/0xc
SMP: stopping secondary CPUs
Kernel Offset: disabled
CPU features: 0x0002,24002004
Memory Limit: none
I took the card over to my laptop and ran fsck which found no problems. I would rather fix the issue if is possible, but I have no idea how to do it. Is is possible? Or should I just create a new card?
Best,
