pschasch Posted January 9, 2021 Posted January 9, 2021 Hello, I was looking for Kali on BPi and tried the "Kali Linux BananaPi offensive-securityDOTcom-2020.04"-image without success. Unfortunately the image does not boot and no support from there (Domain-contact nor forum[...][...]). Some message about "mount: mounting /dev/mmcblk0p1 on /root failed: No such device", even if kernel was started from this 'No such device"'-SD-card. So Igor wrote me about katoolin which I tested on BPi with Armbian 20.11.3 Busterarmbian. For anyone who is interested here is my way: install "Armbian 20.11.3 Buster \l" install "katoolin see https://github.com/LionSec/katoolin" sudo python2.7 katoolin/katoolin.py -> Add Kali repositories & Update by the menu katoolin.py adds "deb http://http.kali.org/kali kali-rolling main contrib non-free" to /etc/apt-sources apt-get install armitage to get msfconsole, first test with vsftpd_234_backdoor-exploit on testdevice was successfull, meterpreter not tested yet. apt-get install burpsuite did not work, I had to add "deb http://old.kali.org/kali sana main non-free contrib" manually. after this burpsuite could be started. For all who will look for this one day :-D 1
NicoD Posted January 9, 2021 Posted January 9, 2021 All the Kali tools should work on Armbian Buster. Kali is debian with many network tools pre-installed. You might also be interested in this. https://olinux.net/install-kali-linux-tools-ubuntu-debian-system/ 1
Werner Posted January 10, 2021 Posted January 10, 2021 There was actually an attempt to bring Armbian and Kali together and release it as images for SBCs. However the project is not very active. I guess they underestimated the effort needed to put in for maintenance https://github.com/GoVanguard/karmbian 2
NicoD Posted January 10, 2021 Posted January 10, 2021 7 hours ago, Werner said: https://github.com/GoVanguard/karmbian I didn't know that.
