pgmech Posted January 11, 2021 Posted January 11, 2021 Hi, I have problem to enable multiboot on TV BOX Evolveo H8 ( https://www.evolveo.com/en/android-box-h8 ) Amlogic S912 3gb Ram 16gb rom 1gbit WiFI LTM8830 CoreElec starts from SD card without any problems. Box don't have Backup&Update app (only OTA update) so I try to use dedicated reset button and adb reboot update but always finished with recovery menu and massage " Support Api.3 Recovery is listening adb sideload... Waiting adb sideload command.. E: cannot load volume /misc!" I tried differnt sd cards (32gb/64gb) and dtb files without any success with balbes armbian compilation. Some photos of box board : https://photos.app.goo.gl/8wmR329H1Qgy99rJ9 On other box with amlogic S912 I start armbian without any probles (box has Update&Backup App) Mayby someone has idea what I doing wrong ?
SteeMan Posted January 11, 2021 Posted January 11, 2021 From the instructions: "The start system in Coreelec is not compatible with LibreELECE Armbian etc. If you run coreelec on your TV box, you will no longer be able to run LE and Armbian normally until the full recovery of the standard firmware via the USB Burn Tool and the new activation of the universal multi-boot, which is used in all new systems."
pgmech Posted January 12, 2021 Author Posted January 12, 2021 As I understood when I boot Coreelec first time i overwrite orginal boot and now Armbian can't start Is there any workaround to enable proper multiboot if there is no stock firmware image avaible for this particular TV BOX ?
balbes150 Posted January 13, 2021 Posted January 13, 2021 8 часов назад, pgmech сказал: Is there any workaround to enable proper multiboot if there is no stock firmware image avaible for this particular TV BOX ? No
pgmech Posted January 14, 2021 Author Posted January 14, 2021 So I get stuck into Coreelec Mayby anyone has idea if this tv box is clone of sth more popular which has rom avaible (board photo in 1 post)? Thanks in advance
