JSF Posted January 19, 2021 Posted January 19, 2021 Trying to understand this issue. If I ONLY need the 1Gbs (LAN1) ethernet connection and DO NOT need the 2.5Gbs (LAN2) connection, do I need to perform the "Fix" for this issue? I'll be using Armbian Buster for this device.
barnumbirr Posted January 19, 2021 Posted January 19, 2021 No, don't need to perform fix if you're only ever going to use the 1Gbps interface AFAIK. 1
gprovost Posted January 21, 2021 Posted January 21, 2021 @jsfrederick You only need the fix if you intend to use the 2.5GbE Interface (LAN2) at 1Gbps speed. So in your case you don't need the fix.
JSF Posted January 22, 2021 Author Posted January 22, 2021 On 1/21/2021 at 1:36 AM, gprovost said: @jsfrederick You only need the fix if you intend to use the 2.5GbE Interface (LAN2) at 1Gbps speed. So in your case you don't need the fix. Thank you for confirming. Looking forward to getting my Helios64 up and running.
