volume up/down keys in Armbian Focal
Go to solution Solved by piner,
I am currently using Armbian on my Pinebook Pro. I am having an issue with the volume up and down keys on Armbian. They are not working; other keys like brightness control seem to work without issues.
I have checked the XFCE keyboard application shortcuts and there seem to be two items relevant to volume control:
amixer set Master 5%+
amixer set Master 5%-
I have checked out other xfce based distros and they don't have these explicit shortcut. Do I need to delete these items to make the volume up/down keys work? I was also asssuming that pulseaudio is the default software for managing volume (not alsamixer). Do I need to play with alsa settings?
I would be appreciative if anyone can help me in fixing the volume up/down buttons in my pinebook pro.
Best
7 hours ago, lanefu said:
Providing logs with
armbianmonitor -u
 helps with troubleshooting and significantly raises chances that issue gets addressed.
thank you for the directions. I issued the command on xfce terminal; however, it complained about the firewall I am using and suggested using
armbianmonitor -U
Based on the command directions, I am posting the output below
     1
     2    ### Activated 1 lzo-rle zram swap devices with 1899 MB each
     3
     4    ### Activated Armbian ramlog partition with zstd compression
     5
     6    Sun 24 Jan 2021 07:56:01 AM EST | Pinebook Pro | 20.11.6 | arm64 | aarch64 | 5.9.14-rockchip64
     7
     8    ### dmesg:
     9
    10    [    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
    11    [    0.000000] Linux version 5.9.14-rockchip64 (root@desktop) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile
 Architecture 8.3-2019.03 (arm-rel-8.36)) XXX.XXX.0.20190321) #20.11.4 SMP PREEMPT Tue Dec 15 08:52:20 CET 2020
    12    [    0.000000] Machine model: Pine64 Pinebook Pro
    13    [    0.000000] efi: UEFI not found.
    14    [    0.000000] cma: Reserved 128 MiB at 0x00000000ebc00000
    15    [    0.000000] NUMA: No NUMA configuration found
    16    [    0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x00000000f7ffffff]
    17    [    0.000000] NUMA: NODE_DATA [mem 0xf77db100-0xf77dcfff]
    18    [    0.000000] Zone ranges:
    19    [    0.000000]   DMA      [mem 0x0000000000200000-0x000000003fffffff]
    20    [    0.000000]   DMA32    [mem 0x0000000040000000-0x00000000f7ffffff]
    21    [    0.000000]   Normal   empty
    22    [    0.000000] Movable zone start for each node
    23    [    0.000000] Early memory node ranges
    24    [    0.000000]   node   0: [mem 0x0000000000200000-0x00000000f7ffffff]
    25    [    0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x00000000f7ffffff]
    26    [    0.000000] On node 0 totalpages: 1015296
    27    [    0.000000]   DMA zone: 4088 pages used for memmap
    28    [    0.000000]   DMA zone: 0 pages reserved
    29    [    0.000000]   DMA zone: 261632 pages, LIFO batch:63
    30    [    0.000000]   DMA32 zone: 11776 pages used for memmap
    31    [    0.000000]   DMA32 zone: 753664 pages, LIFO batch:63
    32    [    0.000000] psci: probing for conduit method from DT.
    33    [    0.000000] psci: PSCIv1.1 detected in firmware.
    34    [    0.000000] psci: Using standard PSCI v0.2 function IDs
    35    [    0.000000] psci: MIGRATE_INFO_TYPE not supported.
    36    [    0.000000] psci: SMC Calling Convention v1.2
    37    [    0.000000] percpu: Embedded 32 pages/cpu s93784 r8192 d29096 u131072
    38    [    0.000000] pcpu-alloc: s93784 r8192 d29096 u131072 alloc=32*4096
    39    [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3 [0] 4 [0] 5
    40    [    0.000000] Detected VIPT I-cache on CPU0
    41    [    0.000000] CPU features: detected: ARM erratum 845719
    42    [    0.000000] CPU features: detected: GIC system register CPU interface
    43    [    0.000000] Speculative Store Bypass Disable mitigation not required
    44    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 999432
    45    [    0.000000] Policy zone: DMA32
    46    [    0.000000] Kernel command line: root=UUID=17e7ab46-4e11-4e0f-9633-e33b211860a6 rootwait rootfstype=ext4 bootsplash.bootfile=bootsplash.armbian console=ttyS2,1500000 console=tty1 consoleblank=0 loglevel
=1 ubootpart=d9767a15-01 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u   cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
    47    [    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
    48    [    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
    49    [    0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off
    50    [    0.000000] software IO TLB: mapped [mem 0x3bfff000-0x3ffff000] (64MB)
    51    [    0.000000] Memory: 3740416K/4061184K available (14464K kernel code, 2094K rwdata, 5980K rodata, 4224K init, 573K bss, 189696K reserved, 131072K cma-reserved)
    52    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
    53    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    54    [    0.000000] rcu:     RCU event tracing is enabled.
    55    [    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
    56    [    0.000000]     Trampoline variant of Tasks RCU enabled.
    57    [    0.000000]     Rude variant of Tasks RCU enabled.
    58    [    0.000000]     Tracing variant of Tasks RCU enabled.
    59    [    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
    60    [    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
    61    [    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
    62    [    0.000000] GICv3: GIC: Using split EOI/Deactivate mode
    63    [    0.000000] GICv3: 256 SPIs implemented
    64    [    0.000000] GICv3: 0 Extended SPIs implemented
    65    [    0.000000] GICv3: Distributor has no Range Selector support
    66    [    0.000000] GICv3: 16 PPIs implemented
    67    [    0.000000] GICv3: CPU0: found redistributor 0 region 0:0x00000000fef00000
    68    [    0.000000] ITS [mem 0xfee20000-0xfee3ffff]
    69    [    0.000000] ITS@0x00000000fee20000: allocated 65536 Devices @f6d00000 (flat, esz 8, psz 64K, shr 0)
    70    [    0.000000] ITS: using cache flushing for cmd queue
    71    [    0.000000] GICv3: using LPI property table @0x00000000f6cb0000
    72    [    0.000000] GIC: using cache flushing for LPI property table
    73    [    0.000000] GICv3: CPU0: using allocated LPI pending table @0x00000000f6cc0000
    74    [    0.000000] GICv3: GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cpus/cpu@1[1] /cpus/cpu@2[2] /cpus/cpu@3[3] }
    75    [    0.000000] GICv3: GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /cpus/cpu@101[5] }
    76    [    0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0
    77    [    0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys).
    78    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns
    79    [    0.000007] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
    80    [    0.001447] Console: colour dummy device 80x25
    81    [    0.001465] printk: console [tty1] enabled
    82    [    0.001589] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000)
    83    [    0.001603] pid_max: default: 32768 minimum: 301
    84    [    0.001756] LSM: Security Framework initializing
    85    [    0.001794] Yama: becoming mindful.
    86    [    0.001943] AppArmor: AppArmor initialized
    87    [    0.002034] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    88    [    0.002064] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes, linear)
    89    [    0.005315] rcu: Hierarchical SRCU implementation.
    90    [    0.006502] Platform MSI: interrupt-controller@fee20000 domain created
    91    [    0.007083] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@fee20000 domain created
    92    [    0.009629] EFI services will not be available.
    93    [    0.010289] smp: Bringing up secondary CPUs ...
    94    [    0.011242] Detected VIPT I-cache on CPU1
    95    [    0.011287] GICv3: CPU1: found redistributor 1 region 0:0x00000000fef20000
    96    [    0.011304] GICv3: CPU1: using allocated LPI pending table @0x00000000f6cd0000
    97    [    0.011358] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
    98    [    0.012451] Detected VIPT I-cache on CPU2
    99    [    0.012486] GICv3: CPU2: found redistributor 2 region 0:0x00000000fef40000
   100    [    0.012500] GICv3: CPU2: using allocated LPI pending table @0x00000000f6ce0000
   101    [    0.012537] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
   102    [    0.013663] Detected VIPT I-cache on CPU3
   103    [    0.013696] GICv3: CPU3: found redistributor 3 region 0:0x00000000fef60000
   104    [    0.013710] GICv3: CPU3: using allocated LPI pending table @0x00000000f6cf0000
   105    [    0.013746] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
   106    [    0.014812] CPU features: detected: Branch predictor hardening
   107    [    0.014823] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
   108    [    0.014831] Detected PIPT I-cache on CPU4
   109    [    0.014867] GICv3: CPU4: found redistributor 100 region 0:0x00000000fef80000
   110    [    0.014881] GICv3: CPU4: using allocated LPI pending table @0x00000000f6d80000
   111    [    0.014921] CPU4: Booted secondary processor 0x0000000100 [0x410fd082]
   112    [    0.015946] Detected PIPT I-cache on CPU5
   113    [    0.015975] GICv3: CPU5: found redistributor 101 region 0:0x00000000fefa0000
   114    [    0.015988] GICv3: CPU5: using allocated LPI pending table @0x00000000f6d90000
   115    [    0.016017] CPU5: Booted secondary processor 0x0000000101 [0x410fd082]
   116    [    0.016172] smp: Brought up 1 node, 6 CPUs
   117    [    0.016181] SMP: Total of 6 processors activated.
   118    [    0.016191] CPU features: detected: 32-bit EL0 Support
   119    [    0.016200] CPU features: detected: CRC32 instructions
   120    [    0.016209] CPU features: detected: 32-bit EL1 Support
   121    [    0.043318] CPU: All CPU(s) started at EL2
   122    [    0.043374] alternatives: patching kernel code
   123    [    0.047071] devtmpfs: initialized
   124    [    0.063167] Registered cp15_barrier emulation handler
   125    [    0.063187] Registered setend emulation handler
   126    [    0.063975] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
   127    [    0.064043] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
   128    [    0.067318] xor: measuring software checksum speed
   129    [    0.105645]    8regs     :  2346.000 MB/sec
   130    [    0.145733]    32regs    :  2757.000 MB/sec
   131    [    0.185825]    arm64_neon:  2279.000 MB/sec
   132    [    0.185832] xor: using function: 32regs (2757.000 MB/sec)
   133    [    0.185884] pinctrl core: initialized pinctrl subsystem
   134    [    0.186532] DMI not present or invalid.
   135    [    0.187107] NET: Registered protocol family 16
   136    [    0.189892] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
   137    [    0.191362] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
   138    [    0.192130] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
   139    [    0.192247] audit: initializing netlink subsys (disabled)
   140    [    0.192549] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
   141    [    0.193746] thermal_sys: Registered thermal governor 'fair_share'
   142    [    0.193750] thermal_sys: Registered thermal governor 'bang_bang'
   143    [    0.193757] thermal_sys: Registered thermal governor 'step_wise'
   144    [    0.193762] thermal_sys: Registered thermal governor 'user_space'
   145    [    0.194280] cpuidle: using governor menu
   146    [    0.194617] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
   147    [    0.194831] ASID allocator initialised with 65536 entries
   148    [    0.196099] Serial: AMBA PL011 UART driver
   149    [    0.261958] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
   150    [    0.261968] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
   151    [    0.261976] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
   152    [    0.261982] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
   153    [    0.267505] cryptd: max_cpu_qlen set to 1000
   154    [    0.342245] raid6: neonx8   gen()  1668 MB/s
   155    [    0.410397] raid6: neonx8   xor()  1206 MB/s
   156    [    0.478569] raid6: neonx4   gen()  1691 MB/s
   157    [    0.546749] raid6: neonx4   xor()  1239 MB/s
   158    [    0.614926] raid6: neonx2   gen()  1505 MB/s
   159    [    0.683103] raid6: neonx2   xor()  1142 MB/s
   160    [    0.751278] raid6: neonx1   gen()  1184 MB/s
   161    [    0.819448] raid6: neonx1   xor()   927 MB/s
   162    [    0.887660] raid6: int64x8  gen()   997 MB/s
   163    [    0.955878] raid6: int64x8  xor()   392 MB/s
   164    [    1.023993] raid6: int64x4  gen()   988 MB/s
   165    [    1.092138] raid6: int64x4  xor()   589 MB/s
   166    [    1.160314] raid6: int64x2  gen()   928 MB/s
   167    [    1.228463] raid6: int64x2  xor()   522 MB/s
   168    [    1.296622] raid6: int64x1  gen()   724 MB/s
   169    [    1.364789] raid6: int64x1  xor()   390 MB/s
   170    [    1.364795] raid6: using algorithm neonx4 gen() 1691 MB/s
   171    [    1.364800] raid6: .... xor() 1239 MB/s, rmw enabled
   172    [    1.364806] raid6: using neon recovery algorithm
   173    [    1.366341] vcc_12v: supplied by vcc_sysin
   174    [    1.366766] vcc3v3_sys: supplied by vcc_sysin
   175    [    1.367421] vcc5v0_usb: supplied by vcc_sysin
   176    [    1.367877] vcc_0v9: supplied by vcc3v3_sys
   177    [    1.368281] vcca1v8_s3: supplied by vcc3v3_sys
   178    [    1.368835] vcc3v0_sd: supplied by vcc3v3_sys
   179    [    1.478070] vcc3v3_panel: supplied by vcc3v3_sys
   180    [    1.478531] vcc3v3_ssd: supplied by vcc3v3_sys
   181    [    1.479030] vcc5v0_otg: supplied by vcc5v0_usb
   182    [    1.479561] vbus_5vout: supplied by vcc5v0_usb
   183    [    1.480404] iommu: Default domain type: Translated
   184    [    1.483817] vgaarb: loaded
   185    [    1.484348] SCSI subsystem initialized
   186    [    1.484630] libata version 3.00 loaded.
   187    [    1.484905] usbcore: registered new interface driver usbfs
   188    [    1.484950] usbcore: registered new interface driver hub
   189    [    1.485058] usbcore: registered new device driver usb
   190    [    1.485702] pps_core: LinuxPPS API ver. 1 registered
   191    [    1.485708] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
   192    [    1.485724] PTP clock support registered
   193    [    1.486097] EDAC MC: Ver: 3.0.0
   194    [    1.487324] NetLabel: Initializing
   195    [    1.487331] NetLabel:  domain hash size = 128
   196    [    1.487335] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
   197    [    1.487402] NetLabel:  unlabeled traffic allowed by default
   198    [    1.487902] clocksource: Switched to clocksource arch_sys_counter
   199    [    1.612772] VFS: Disk quotas dquot_6.6.0
   200    [    1.612850] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
   201    [    1.613713] AppArmor: AppArmor Filesystem Enabled
   202    [    1.624397] NET: Registered protocol family 2
   203    [    1.625298] tcp_listen_portaddr_hash hash table entries: 2048 (order: 3, 32768 bytes, linear)
   204    [    1.625475] TCP established hash table entries: 32768 (order: 6, 262144 bytes, linear)
   205    [    1.626012] TCP bind hash table entries: 32768 (order: 7, 524288 bytes, linear)
   206    [    1.626677] TCP: Hash tables configured (established 32768 bind 32768)
   207    [    1.626861] UDP hash table entries: 2048 (order: 4, 65536 bytes, linear)
   208    [    1.627025] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes, linear)
   209    [    1.627371] NET: Registered protocol family 1
   210    [    1.627403] NET: Registered protocol family 44
   211    [    1.627416] PCI: CLS 0 bytes, default 64
   212    [    1.627648] Trying to unpack rootfs image as initramfs...
   213    [    2.766025] Freeing initrd memory: 15428K
   214    [    2.767296] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
   215    [    2.767716] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
   216    [    2.768418] kvm [1]: IPA Size Limit: 40bits
   217    [    2.769207] kvm [1]: vgic-v2@fff20000
   218    [    2.769243] kvm [1]: GIC system register CPU interface enabled
   219    [    2.769493] kvm [1]: vgic interrupt IRQ10
   220    [    2.769781] kvm [1]: Hyp mode initialized successfully
   221    [    2.780244] Initialise system trusted keyrings
   222    [    2.780290] Key type blacklist registered
   223    [    2.780481] workingset: timestamp_bits=44 max_order=20 bucket_order=0
   224    [    2.787116] zbud: loaded
   225    [    2.788897] squashfs: version 4.0 (2009/01/31) Phillip Lougher
   226    [    2.789832] fuse: init (API version 7.31)
   227    [    2.791214] integrity: Platform Keyring initialized
   228    [    2.857087] Key type asymmetric registered
   229    [    2.857093] Asymmetric key parser 'x509' registered
   230    [    2.857146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
   231    [    2.857349] io scheduler mq-deadline registered
   232    [    2.857356] io scheduler kyber registered
   233    [    2.857491] io scheduler bfq registered
   234    [    2.875065] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
   235    [    2.875090] OF: /pcie@f8000000: Missing device_type
   236    [    2.875121] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
   237    [    2.875142] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
   238    [    2.876098] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
   239    [    2.883625] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-241330
   240    [    2.883636] dma-pl330 ff6d0000.dma-controller:     DBUFF-32x8bytes Num_Chans-6 Num_Peri-12 Num_Events-12
   241    [    2.885153] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-241330
   242    [    2.885164] dma-pl330 ff6e0000.dma-controller:     DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16
   243    [    2.889448] vdd_log: supplied by regulator-dummy
   244    [    2.890843] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
   245    [    2.894023] ff180000.serial: ttyS0 at MMIO 0xff180000 (irq = 38, base_baud = 1500000) is a 16550A
   246    [    2.894190] serial serial0: tty port ttyS0 registered
   247    [    2.895081] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 39, base_baud = 1500000) is a 16550A
   248    [    2.895268] printk: console [ttyS2] enabled
   249    [    2.896627] Serial: AMBA driver
   250    [    2.898090] cacheinfo: Unable to detect cache hierarchy for CPU 0
   251    [    2.910060] loop: module loaded
   252    [    2.916352] spi-nor spi0.0: gd25q128 (16384 Kbytes)
   253    [    2.935089] libphy: Fixed MDIO Bus: probed
   254    [    2.935437] tun: Universal TUN/TAP device driver, 1.6
   255    [    2.936511] thunder_xcv, ver 1.0
   256    [    2.936554] thunder_bgx, ver 1.0
   257    [    2.936601] nicpf, ver 1.0
   258    [    2.937698] e1000e: Intel(R) PRO/1000 Network Driver
   259    [    2.937702] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
   260    [    2.937759] igb: Intel(R) Gigabit Ethernet Network Driver
   261    [    2.937764] igb: Copyright (c) 2007-2014 Intel Corporation.
   262    [    2.937800] igbvf: Intel(R) Gigabit Virtual Function Network Driver
   263    [    2.937805] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
   264    [    2.938088] sky2: driver version 1.30
   265    [    2.938786] VFIO - User Level meta-driver version: 0.3
   266    [    2.956843] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
   267    [    2.956866] ehci-pci: EHCI PCI platform driver
   268    [    2.956905] ehci-platform: EHCI generic platform driver
   269    [    2.959304] ehci-platform fe380000.usb: EHCI Host Controller
   270    [    2.959330] ehci-platform fe380000.usb: new USB bus registered, assigned bus number 1
   271    [    2.959498] ehci-platform fe380000.usb: irq 30, io mem 0xfe380000
   272    [    2.971930] ehci-platform fe380000.usb: USB 2.0 started, EHCI 1.00
   273    [    2.972189] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
   274    [    2.972199] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   275    [    2.972208] usb usb1: Product: EHCI Host Controller
   276    [    2.972215] usb usb1: Manufacturer: Linux 5.9.14-rockchip64 ehci_hcd
   277    [    2.972222] usb usb1: SerialNumber: fe380000.usb
   278    [    2.972758] hub 1-0:1.0: USB hub found
   279    [    2.972808] hub 1-0:1.0: 1 port detected
   280    [    2.975580] ehci-platform fe3c0000.usb: EHCI Host Controller
   281    [    2.975603] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus number 2
   282    [    2.975734] ehci-platform fe3c0000.usb: irq 32, io mem 0xfe3c0000
   283    [    2.987950] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
   284    [    2.988333] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
   285    [    2.988346] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   286    [    2.988356] usb usb2: Product: EHCI Host Controller
   287    [    2.988366] usb usb2: Manufacturer: Linux 5.9.14-rockchip64 ehci_hcd
   288    [    2.988375] usb usb2: SerialNumber: fe3c0000.usb
   289    [    2.989139] hub 2-0:1.0: USB hub found
   290    [    2.989186] hub 2-0:1.0: 1 port detected
   291    [    2.989955] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
   292    [    2.989978] ohci-pci: OHCI PCI platform driver
   293    [    2.990034] ohci-platform: OHCI generic platform driver
   294    [    2.990351] ohci-platform fe3a0000.usb: Generic Platform OHCI controller
   295    [    2.990371] ohci-platform fe3a0000.usb: new USB bus registered, assigned bus number 3
   296    [    2.990507] ohci-platform fe3a0000.usb: irq 31, io mem 0xfe3a0000
   297    [    3.052121] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
   298    [    3.052130] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   299    [    3.052138] usb usb3: Product: Generic Platform OHCI controller
   300    [    3.052146] usb usb3: Manufacturer: Linux 5.9.14-rockchip64 ohci_hcd
   301    [    3.052153] usb usb3: SerialNumber: fe3a0000.usb
   302    [    3.052689] hub 3-0:1.0: USB hub found
   303    [    3.052729] hub 3-0:1.0: 1 port detected
   304    [    3.053410] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
   305    [    3.053428] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus number 4
   306    [    3.053568] ohci-platform fe3e0000.usb: irq 33, io mem 0xfe3e0000
   307    [    3.116107] usb usb4: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.09
   308    [    3.116116] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   309    [    3.116124] usb usb4: Product: Generic Platform OHCI controller
   310    [    3.116131] usb usb4: Manufacturer: Linux 5.9.14-rockchip64 ohci_hcd
   311    [    3.116138] usb usb4: SerialNumber: fe3e0000.usb
   312    [    3.116668] hub 4-0:1.0: USB hub found
   313    [    3.116725] hub 4-0:1.0: 1 port detected
   314    [    3.118263] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   315    [    3.118287] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5
   316    [    3.118468] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
   317    [    3.118533] xhci-hcd xhci-hcd.0.auto: irq 228, io mem 0xfe900000
   318    [    3.118950] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
   319    [    3.118959] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   320    [    3.118967] usb usb5: Product: xHCI Host Controller
   321    [    3.118975] usb usb5: Manufacturer: Linux 5.9.14-rockchip64 xhci-hcd
   322    [    3.118982] usb usb5: SerialNumber: xhci-hcd.0.auto
   323    [    3.119534] hub 5-0:1.0: USB hub found
   324    [    3.119574] hub 5-0:1.0: 1 port detected
   325    [    3.119965] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
   326    [    3.119981] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 6
   327    [    3.119997] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
   328    [    3.120078] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
   329    [    3.120218] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
   330    [    3.120227] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   331    [    3.120235] usb usb6: Product: xHCI Host Controller
   332    [    3.120242] usb usb6: Manufacturer: Linux 5.9.14-rockchip64 xhci-hcd
   333    [    3.120250] usb usb6: SerialNumber: xhci-hcd.0.auto
   334    [    3.120783] hub 6-0:1.0: USB hub found
   335    [    3.120820] hub 6-0:1.0: 1 port detected
   336    [    3.121340] usbcore: registered new interface driver usb-storage
   337    [    3.123869] mousedev: PS/2 mouse device common for all mice
   338    [    3.125290] i2c /dev entries driver
   339    [    3.134264] rk808 0-001b: chip id: 0x0
   340    [    3.138795] rk808-regulator rk808-regulator: there is no dvs0 gpio
   341    [    3.138825] rk808-regulator rk808-regulator: there is no dvs1 gpio
   342    [    3.139702] vdd_center: supplied by vcc_sysin
   343    [    3.140303] vdd_cpu_l: supplied by vcc_sysin
   344    [    3.140609] vcc_ddr: supplied by vcc_sysin
   345    [    3.141212] vcc_1v8: supplied by vcc_sysin
   346    [    3.141650] LDO_REG1: supplied by vcc_sysin
   347    [    3.142117] LDO_REG2: supplied by vcc_sysin
   348    [    3.143548] vcc1v8_pmupll: supplied by vcc_sysin
   349    [    3.144687] vcc_sdio: supplied by vcc_sysin
   350    [    3.145705] vcca3v0_codec: supplied by vcc_sysin
   351    [    3.146854] vcc_1v5: supplied by vcc_sysin
   352    [    3.147864] vcca1v8_codec: supplied by vcc_sysin
   353    [    3.149052] vcc_3v0: supplied by vcc_sysin
   354    [    3.149359] vcc3v3_s3: supplied by vcc3v3_sys
   355    [    3.149698] vcc3v3_s0: supplied by vcc3v3_sys
   356    [    3.153316] rk808-rtc rk808-rtc: registered as rtc0
   357    [    3.153872] rk808-rtc rk808-rtc: setting system clock to 2021-01-24T12:55:49 UTC (1611492949)
   358    [    3.157214] fan53555-regulator 0-0040: FAN53555 Option[8] Rev[1] Detected!
   359    [    3.158562] vcc0v9_s3: supplied by vcc_1v8
   360    [    3.158655] vdd_cpu_b: supplied by vcc_1v8
   361    [    3.161784] fan53555-regulator 0-0041: FAN53555 Option[8] Rev[1] Detected!
   362    [    3.162351] random: fast init done
   363    [    3.163163] vdd_gpu: supplied by vcc_1v8
   364    [    3.172575] dw_wdt ff848000.watchdog: No valid TOPs array specified
   365    [    3.174736] sdhci: Secure Digital Host Controller Interface driver
   366    [    3.174741] sdhci: Copyright(c) Pierre Ossman
   367    [    3.174772] Synopsys Designware Multimedia Card Interface Driver
   368    [    3.176391] dwmmc_rockchip fe310000.mmc: IDMAC supports 32-bit address mode.
   369    [    3.176419] dwmmc_rockchip fe310000.mmc: Using internal DMA controller.
   370    [    3.176436] dwmmc_rockchip fe310000.mmc: Version ID is 270a
   371    [    3.176508] dwmmc_rockchip fe310000.mmc: DW MMC controller at irq 27,32 bit host data width,256 deep fifo
   372    [    3.176819] dwmmc_rockchip fe310000.mmc: allocated mmc-pwrseq
   373    [    3.176829] mmc_host mmc0: card is non-removable.
   374    [    3.296106] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   375    [    3.309526] dwmmc_rockchip fe320000.mmc: IDMAC supports 32-bit address mode.
   376    [    3.309560] dwmmc_rockchip fe320000.mmc: Using internal DMA controller.
   377    [    3.309576] dwmmc_rockchip fe320000.mmc: Version ID is 270a
   378    [    3.309647] dwmmc_rockchip fe320000.mmc: DW MMC controller at irq 28,32 bit host data width,256 deep fifo
   379    [    3.310135] dwmmc_rockchip fe320000.mmc: Got CD GPIO
   380    [    3.323035] mmc_host mmc1: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0)
   381    [    3.323928] usb 2-1: new high-speed USB device number 2 using ehci-platform
   382    [    3.336680] sdhci-pltfm: SDHCI platform and OF driver helper
   383    [    3.338521] mmc2: CQHCI version 5.10
   384    [    3.342230] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
   385    [    3.343863] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
   386    [    3.345483] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
   387    [    3.348393] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
   388    [    3.351937] mmc0: queuing unknown CIS tuple 0x81 (9 bytes)
   389    [    3.363776] mmc2: SDHCI controller on fe330000.sdhci [fe330000.sdhci] using ADMA
   390    [    3.368570] ledtrig-cpu: registered to indicate activity on CPUs
   391    [    3.369720] SMCCC: SOC_ID: ARCH_FEATURES(ARCH_SOC_ID) returned error: fffffffffffffffd
   392    [    3.370136] hid: raw HID events driver (C) Jiri Kosina
   393    [    3.370400] usbcore: registered new interface driver usbhid
   394    [    3.370405] usbhid: USB HID core driver
   395    [    3.378154] drop_monitor: Initializing network drop monitor service
   396    [    3.379363] NET: Registered protocol family 10
   397    [    3.387880] mmc_host mmc1: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
   398    [    3.406286] mmc_host mmc0: Bus speed (slot 0) = 148500000Hz (slot req 150000000Hz, actual 148500000HZ div = 0)
   399    [    3.426000] Segment Routing with IPv6
   400    [    3.426109] NET: Registered protocol family 17
   401    [    3.426281] 8021q: 802.1Q VLAN Support v1.8
   402    [    3.426343] Key type dns_resolver registered
   403    [    3.426896] registered taskstats version 1
   404    [    3.426909] Loading compiled-in X.509 certificates
   405    [    3.430394] Loaded X.509 cert 'Build time autogenerated kernel key: dccf44bd6a6a6c80c8ebb43ecbfc03e645b516d0'
   406    [    3.430590] zswap: loaded using pool lzo/zbud
   407    [    3.430959] Key type ._fscrypt registered
   408    [    3.430964] Key type .fscrypt registered
   409    [    3.430970] Key type fscrypt-provisioning registered
   410    [    3.434098] Btrfs loaded, crc32c=crc32c-generic
   411    [    3.439598] mmc2: Command Queue Engine enabled
   412    [    3.439630] mmc2: new HS200 MMC card at address 0001
   413    [    3.441094] mmcblk2: mmc2:0001 DA4064 58.2 GiB
   414    [    3.441510] mmcblk2boot0: mmc2:0001 DA4064 partition 1 4.00 MiB
   415    [    3.441924] mmcblk2boot1: mmc2:0001 DA4064 partition 2 4.00 MiB
   416    [    3.442186] mmcblk2rpmb: mmc2:0001 DA4064 partition 3 16.0 MiB, chardev (243:0)
   417    [    3.443771]  mmcblk2: p1 p2
   418    [    3.456608] Key type encrypted registered
   419    [    3.456628] AppArmor: AppArmor sha1 policy hashing enabled
   420    [    3.485797] usb 2-1: New USB device found, idVendor=05e3, idProduct=0608, bcdDevice=85.36
   421    [    3.485809] usb 2-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
   422    [    3.485817] usb 2-1: Product: USB2.0 Hub
   423    [    3.486689] hub 2-1:1.0: USB hub found
   424    [    3.487032] hub 2-1:1.0: 4 ports detected
   425    [    3.508414] rockchip-pcie f8000000.pcie: host bridge /pcie@f8000000 ranges:
   426    [    3.508462] rockchip-pcie f8000000.pcie:      MEM 0x00fa000000..0x00fbdfffff -> 0x00fa000000
   427    [    3.508482] rockchip-pcie f8000000.pcie:       IO 0x00fbe00000..0x00fbefffff -> 0x00fbe00000
   428    [    3.509355] rockchip-pcie f8000000.pcie: no vpcie12v regulator found
   429    [    3.567952] usb 3-1: new low-speed USB device number 2 using ohci-platform
   430    [    3.775920] usb 2-1.2: new high-speed USB device number 3 using ehci-platform
   431    [    3.800012] usb 3-1: New USB device found, idVendor=258a, idProduct=001e, bcdDevice= 1.00
   432    [    3.800027] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
   433    [    3.800038] usb 3-1: Product: USB KEYBOARD
   434    [    3.800047] usb 3-1: Manufacturer: HAILUCK CO.,LTD
   435    [    3.809432] input: HAILUCK CO.,LTD USB KEYBOARD as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.0/0003:258A:001E.0001/input/input0
   436    [    3.868721] hid-generic 0003:258A:001E.0001: input,hidraw0: USB HID v1.10 Keyboard [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input0
   437    [    3.892659] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input1
   438    [    3.893228] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input2
   439    [    3.893777] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input3
   440    [    3.952348] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input4
   441    [    3.952715] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input5
   442    [    3.953323] hid-generic 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1
   443    [    4.036722] dwmmc_rockchip fe320000.mmc: Successfully tuned phase to 84
   444    [    4.036747] mmc1: new ultra high speed SDR104 SDXC card at address 0001
   445    [    4.037948] mmcblk1: mmc1:0001 EE8QT 239 GiB
   446    [    4.040398]  mmcblk1: p1
   447    [    4.052898] dwmmc_rockchip fe310000.mmc: Successfully tuned phase to 50
   448    [    4.060030] mmc0: new ultra high speed SDR104 SDIO card at address 0001
   449    [    4.063946] rockchip-pcie f8000000.pcie: PCIe link training gen1 timeout!
   450    [    4.064943] rockchip-pcie: probe of f8000000.pcie failed with error -110
   451    [    4.070677] input: gpio-key-lid as /devices/platform/gpio-key-lid/input/input6
   452    [    4.071567] input: gpio-key-power as /devices/platform/gpio-key-power/input/input7
   453    [    4.072172] of_cfs_init
   454    [    4.072209] of_cfs_init: OK
   455    [    4.076221] Freeing unused kernel memory: 4224K
   456    [    4.088057] Run /init as init process
   457    [    4.088068]   with arguments:
   458    [    4.088074]     /init
   459    [    4.088080]   with environment:
   460    [    4.088086]     HOME=/
   461    [    4.088092]     TERM=linux
   462    [    4.088099]     ubootpart=d9767a15-01
   463    [    4.088105]     cgroup_enable=memory
   464    [    4.088111]     cgroup_memory=1
   465    [    4.279936] usb 2-1.2: device not accepting address 3, error -71
   466    [    4.844748] rockchip-vop ff8f0000.vop: Adding to iommu group 2
   467    [    4.855166] rockchip-vop ff900000.vop: Adding to iommu group 3
   468    [    4.863656] rockchip-dp ff970000.edp: no DP phy configured
   469    [    5.983703] EXT4-fs (mmcblk1p1): mounted filesystem with writeback data mode. Opts: (null)
   470    [    6.550260] systemd[1]: Inserted module 'autofs4'
   471    [    6.604835] systemd[1]: systemd 245.4-4ubuntu3.4 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTIL
S +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
   472    [    6.606252] systemd[1]: Detected architecture arm64.
   473    [    6.641158] systemd[1]: Set hostname to <pinebook-pro>.
   474    [    6.736999] dw-apb-uart ff1a0000.serial: forbid DMA for kernel console
   475    [    7.066517] systemd[1]: /lib/systemd/system/dbus.socket:5: ListenStream= references a path below legacy directory /var/run/, updating /var/run/dbus/system_bus_socket → /run/dbus/system_bus_socket; pleas
e update the unit file accordingly.
   476    [    7.440951] random: systemd: uninitialized urandom read (16 bytes read)
   477    [    7.445369] systemd[1]: Created slice system-modprobe.slice.
   478    [    7.445919] random: systemd: uninitialized urandom read (16 bytes read)
   479    [    7.447382] systemd[1]: Created slice system-serial\x2dgetty.slice.
   480    [    7.447731] random: systemd: uninitialized urandom read (16 bytes read)
   481    [    7.449061] systemd[1]: Created slice User and Session Slice.
   482    [    7.449741] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
   483    [    7.451038] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
   484    [    7.451583] systemd[1]: Reached target User and Group Name Lookups.
   485    [    7.451984] systemd[1]: Reached target Remote File Systems.
   486    [    7.452309] systemd[1]: Reached target Slices.
   487    [    7.452645] systemd[1]: Reached target Swap.
   488    [    7.452968] systemd[1]: Reached target System Time Set.
   489    [    7.453897] systemd[1]: Listening on Syslog Socket.
   490    [    7.454745] systemd[1]: Listening on fsck to fsckd communication Socket.
   491    [    7.455339] systemd[1]: Listening on initctl Compatibility Named Pipe.
   492    [    7.456665] systemd[1]: Listening on Journal Audit Socket.
   493    [    7.457490] systemd[1]: Listening on Journal Socket (/dev/log).
   494    [    7.458410] systemd[1]: Listening on Journal Socket.
   495    [    7.459313] systemd[1]: Listening on udev Control Socket.
   496    [    7.460244] systemd[1]: Listening on udev Kernel Socket.
   497    [    7.466213] systemd[1]: Mounting Huge Pages File System...
   498    [    7.472368] systemd[1]: Mounting POSIX Message Queue File System...
   499    [    7.478700] systemd[1]: Mounting Kernel Debug File System...
   500    [    7.485079] systemd[1]: Mounting Kernel Trace File System...
   501    [    7.492541] systemd[1]: Starting Restore / save the current clock...
   502    [    7.498681] systemd[1]: Starting Set the console keyboard layout...
   503    [    7.505876] systemd[1]: Starting Create list of static device nodes for the current kernel...
   504    [    7.506490] systemd[1]: Condition check resulted in Load Kernel Module drm being skipped.
   505    [    7.512419] systemd[1]: Started Nameserver information manager.
   506    [    7.513510] systemd[1]: Reached target Network (Pre).
   507    [    7.516315] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   508    [    7.516512] systemd[1]: Condition check resulted in File System Check on Root Device being skipped.
   509    [    7.526030] systemd[1]: Starting Load Kernel Modules...
   510    [    7.532096] systemd[1]: Starting Remount Root and Kernel File Systems...
   511    [    7.541663] systemd[1]: Starting udev Coldplug all Devices...
   512    [    7.548304] systemd[1]: Starting Uncomplicated firewall...
   513    [    7.558162] systemd[1]: Mounted Huge Pages File System.
   514    [    7.559520] systemd[1]: Mounted POSIX Message Queue File System.
   515    [    7.560884] systemd[1]: Mounted Kernel Debug File System.
   516    [    7.562164] systemd[1]: Mounted Kernel Trace File System.
   517    [    7.567170] systemd[1]: Finished Restore / save the current clock.
   518    [    7.571612] systemd[1]: Finished Create list of static device nodes for the current kernel.
   519    [    7.578158] EXT4-fs (mmcblk1p1): re-mounted. Opts: commit=600,errors=remount-ro
   520    [    7.579327] systemd[1]: Finished Load Kernel Modules.
   521    [    7.587385] systemd[1]: Finished Remount Root and Kernel File Systems.
   522    [    7.595055] systemd[1]: Mounting FUSE Control File System...
   523    [    7.601329] systemd[1]: Mounting Kernel Configuration File System...
   524    [    7.610748] systemd[1]: Starting Rebuild Hardware Database...
   525    [    7.611320] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   526    [    7.617875] systemd[1]: Starting Load/Save Random Seed...
   527    [    7.628672] systemd[1]: Starting Apply Kernel Variables...
   528    [    7.630249] bpfilter: Loaded bpfilter_umh pid 408
   529    [    7.630800] Started bpfilter
   530    [    7.634578] systemd[1]: Starting Create System Users...
   531    [    7.641506] systemd[1]: Mounted FUSE Control File System.
   532    [    7.642642] systemd[1]: Mounted Kernel Configuration File System.
   533    [    7.707704] systemd[1]: Finished Create System Users.
   534    [    7.717088] systemd[1]: Starting Create Static Device Nodes in /dev...
   535    [    7.721640] systemd[1]: Finished Apply Kernel Variables.
   536    [    7.803751] systemd[1]: Finished Create Static Device Nodes in /dev.
   537    [    7.955798] systemd[1]: Finished Set the console keyboard layout.
   538    [    7.957529] systemd[1]: Reached target Local File Systems (Pre).
   539    [    7.972117] systemd[1]: Mounting Mount unit for chromium, revision 1428...
   540    [    7.982538] systemd[1]: Mounting Mount unit for chromium, revision 1449...
   541    [    7.994108] systemd[1]: Mounting Mount unit for core18, revision 1949...
   542    [    8.005497] systemd[1]: Mounting Mount unit for core20, revision 907...
   543    [    8.016712] systemd[1]: Mounting Mount unit for foliate, revision 630...
   544    [    8.027575] systemd[1]: Mounting Mount unit for gnome-3-28-1804, revision 147...
   545    [    8.040772] systemd[1]: Mounting Mount unit for gtk-common-themes, revision 1514...
   546    [    8.052141] systemd[1]: Mounting Mount unit for numix-gtk-themes, revision 3...
   547    [    8.065638] systemd[1]: Mounting Mount unit for snapd, revision 10709...
   548    [    8.075822] systemd[1]: Mounting /tmp...
   549    [    8.097858] systemd[1]: Mounted /tmp.
   550    [    8.256836] systemd[1]: Finished udev Coldplug all Devices.
   551    [    8.258373] systemd[1]: Mounted Mount unit for chromium, revision 1428.
   552    [    8.259702] systemd[1]: Mounted Mount unit for core20, revision 907.
   553    [    8.261332] systemd[1]: Mounted Mount unit for gnome-3-28-1804, revision 147.
   554    [    8.262712] systemd[1]: Mounted Mount unit for core18, revision 1949.
   555    [    8.264184] systemd[1]: Mounted Mount unit for chromium, revision 1449.
   556    [    8.265605] systemd[1]: Mounted Mount unit for foliate, revision 630.
   557    [    8.272821] systemd[1]: Starting Helper to synchronize boot up for ifupdown...
   558    [    8.300042] systemd[1]: Finished Helper to synchronize boot up for ifupdown.
   559    [    8.330130] systemd[1]: Mounted Mount unit for gtk-common-themes, revision 1514.
   560    [    8.355853] systemd[1]: Finished Uncomplicated firewall.
   561    [    8.362528] systemd[1]: Mounted Mount unit for numix-gtk-themes, revision 3.
   562    [    8.386100] systemd[1]: Mounted Mount unit for snapd, revision 10709.
   563    [    8.387115] systemd[1]: Reached target Local File Systems.
   564    [    8.392578] systemd[1]: Starting Load AppArmor profiles...
   565    [    8.398353] systemd[1]: Starting Armbian ZRAM config...
   566    [    8.405401] systemd[1]: Starting Set console font and keymap...
   567    [    8.411297] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
   568    [    8.411808] systemd[1]: Condition check resulted in Mark the need to relabel after reboot being skipped.
   569    [    8.412159] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   570    [    8.438608] systemd[1]: Finished Set console font and keymap.
   571    [    8.450480] systemd[1]: plymouth-read-write.service: Succeeded.
   572    [    8.453205] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
   573    [    8.629697] audit: type=1400 audit(1611492954.972:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-xpdfimport" pid=511 comm="apparmor_parser"
   574    [    8.633018] audit: type=1400 audit(1611492954.976:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=509 comm="apparmor_parser"
   575    [    8.644567] audit: type=1400 audit(1611492954.988:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-oopslash" pid=514 comm="apparmor_parser"
   576    [    8.645383] audit: type=1400 audit(1611492954.988:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/chronyd" pid=512 comm="apparmor_parser"
   577    [    8.664184] audit: type=1400 audit(1611492955.008:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/sbin/haveged" pid=515 comm="apparmor_parser"
   578    [    8.667936] audit: type=1400 audit(1611492955.008:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="libreoffice-senddoc" pid=517 comm="apparmor_parser"
   579    [    8.673209] audit: type=1400 audit(1611492955.016:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=513 comm="apparmor_parser"
   580    [    8.673317] audit: type=1400 audit(1611492955.016:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=513 comm="app
armor_parser"
   581    [    8.674813] audit: type=1400 audit(1611492955.016:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/bin/man" pid=516 comm="apparmor_parser"
   582    [    8.674844] audit: type=1400 audit(1611492955.016:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="man_filter" pid=516 comm="apparmor_parser"
   583    [    8.894027] zram: Added device: zram0
   584    [    8.894861] zram: Added device: zram1
   585    [    8.895669] zram: Added device: zram2
   586    [    9.031234] zram0: detected capacity change from 0 to 1992265728
   587    [    9.243946] random: crng init done
   588    [    9.243957] random: 7 urandom warning(s) missed due to ratelimiting
   589    [    9.297916] systemd[1]: Finished Load/Save Random Seed.
   590    [    9.299679] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   591    [    9.337928] systemd[1]: Finished Load AppArmor profiles.
   592    [    9.344126] systemd[1]: Starting Raise network interfaces...
   593    [    9.348097] Adding 1945568k swap on /dev/zram0.  Priority:5 extents:1 across:1945568k SSFS
   594    [    9.349977] systemd[1]: Starting Load AppArmor profiles managed internally by snapd...
   595    [    9.556087] systemd[1]: Finished Load AppArmor profiles managed internally by snapd.
   596    [    9.560406] zram1: detected capacity change from 0 to 52428800
   597    [    9.641735] systemd[1]: Finished Armbian ZRAM config.
   598    [    9.648391] systemd[1]: Starting Armbian memory supported logging...
   599    [    9.764495] EXT4-fs (zram1): mounted filesystem without journal. Opts: discard
   600    [    9.764548] ext4 filesystem being mounted at /var/log supports timestamps until 2038 (0x7fffffff)
   601    [    9.876064] systemd[1]: Finished Raise network interfaces.
   602    [   12.480464] systemd[1]: Finished Rebuild Hardware Database.
   603    [   12.489796] systemd[1]: Starting udev Kernel Device Manager...
   604    [   12.749355] systemd[1]: Started udev Kernel Device Manager.
   605    [   12.750683] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
   606    [   12.750849] systemd[1]: Condition check resulted in Dispatch Password Requests to Console Directory Watch when bootsplash is active being skipped.
   607    [   12.750963] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
   608    [   12.751088] systemd[1]: Reached target Local Encrypted Volumes.
   609    [   13.306688] systemd[1]: Found device /dev/ttyS2.
   610    [   13.412335] systemd[1]: Created slice system-systemd\x2dbacklight.slice.
   611    [   13.416875] systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:edp-backlight...
   612    [   13.450616] cfg80211: Loading compiled-in X.509 certificates for regulatory database
   613    [   13.470438] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
   614    [   13.477382] systemd[1]: Finished Load/Save Screen Backlight Brightness of backlight:edp-backlight.
   615    [   13.492404] mc: Linux media interface: v0.10
   616    [   13.515742] brcmfmac: F1 signature read @0x18000000=0x15294345
   617    [   13.528126] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
   618    [   13.529694] usbcore: registered new interface driver brcmfmac
   619    [   13.541695] power_supply cw2015-battery: Not all required supplies found, defer probe
   620    [   13.541709] cw2015 4-0062: Failed to register power supply
   621    [   13.544199] videodev: Linux video capture interface: v2.00
   622    [   13.553625] power_supply cw2015-battery: Not all required supplies found, defer probe
   623    [   13.553639] cw2015 4-0062: Failed to register power supply
   624    [   13.556294] brcmfmac mmc0:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.pine64,pinebook-pro.txt failed with error -2
   625    [   13.623768] power_supply cw2015-battery: Not all required supplies found, defer probe
   626    [   13.623782] cw2015 4-0062: Failed to register power supply
   627    [   13.625947] panfrost ff9a0000.gpu: clock rate = 500000000
   628    [   13.630565] Bluetooth: Core ver 2.22
   629    [   13.630644] NET: Registered protocol family 31
   630    [   13.630647] Bluetooth: HCI device and connection manager initialized
   631    [   13.630663] Bluetooth: HCI socket layer initialized
   632    [   13.630670] Bluetooth: L2CAP socket layer initialized
   633    [   13.630687] Bluetooth: SCO socket layer initialized
   634    [   13.646893] panfrost ff9a0000.gpu: mali-t860 id 0x860 major 0x2 minor 0x0 status 0x0
   635    [   13.646902] panfrost ff9a0000.gpu: features: 00000000,100e77bf, issues: 00000000,24040400
   636    [   13.646908] panfrost ff9a0000.gpu: Features: L2:0x07120206 Shader:0x00000000 Tiler:0x00000809 Mem:0x1 MMU:0x00002830 AS:0xff JS:0x7
   637    [   13.646912] panfrost ff9a0000.gpu: shader_present=0xf l2_present=0x1
   638    [   13.653415] es8316 1-0011: Failed to get IRQ 0: -22
   639    [   13.663945] power_supply cw2015-battery: Not all required supplies found, defer probe
   640    [   13.663959] cw2015 4-0062: Failed to register power supply
   641    [   13.669883] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43456-sdio for chip BCM4345/9
   642    [   13.670770] brcmfmac: brcmf_c_process_clm_blob: no clm_blob available (err=-2), device may have limited channels available
   643    [   13.675636] power_supply cw2015-battery: Not all required supplies found, defer probe
   644    [   13.675657] cw2015 4-0062: Failed to register power supply
   645    [   13.676249] [drm] Initialized panfrost 1.1.0 20180908 for ff9a0000.gpu on minor 0
   646    [   13.676774] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/9 wl0: Feb 11 2020 11:54:51 version XXX.XXX.96.61 (be7af2d@shgit) (r745790) FWID 01-a41d86bd es7.c5.n4.a3
   647    [   13.685160] power_supply cw2015-battery: Not all required supplies found, defer probe
   648    [   13.685169] cw2015 4-0062: Failed to register power supply
   649    [   13.692599] OF: graph: no port node found in /i2c@ff3d0000/fusb30x@22
   650    [   13.698441] rockchip-rga ff680000.rga: HW Version: 0x03.02
   651    [   13.707126] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
   652    [   13.707156] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 7
   653    [   13.707315] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010
   654    [   13.707376] xhci-hcd xhci-hcd.2.auto: irq 227, io mem 0xfe800000
   655    [   13.707999] usb usb7: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.09
   656    [   13.708008] usb usb7: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   657    [   13.708012] usb usb7: Product: xHCI Host Controller
   658    [   13.708016] usb usb7: Manufacturer: Linux 5.9.14-rockchip64 xhci-hcd
   659    [   13.708020] usb usb7: SerialNumber: xhci-hcd.2.auto
   660    [   13.708804] hub 7-0:1.0: USB hub found
   661    [   13.708852] hub 7-0:1.0: 1 port detected
   662    [   13.709237] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
   663    [   13.709253] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 8
   664    [   13.709268] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed
   665    [   13.709339] usb usb8: We don't know the algorithms for LPM for this host, disabling LPM.
   666    [   13.709503] usb usb8: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.09
   667    [   13.709508] usb usb8: New USB device strings: Mfr=3, Product=2, SerialNumber=1
   668    [   13.709512] usb usb8: Product: xHCI Host Controller
   669    [   13.709517] usb usb8: Manufacturer: Linux 5.9.14-rockchip64 xhci-hcd
   670    [   13.709521] usb usb8: SerialNumber: xhci-hcd.2.auto
   671    [   13.710082] hub 8-0:1.0: USB hub found
   672    [   13.710121] hub 8-0:1.0: 1 port detected
   673    [   13.714833] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm])
   674    [   13.715005] [drm] unsupported AFBC format[3231564e]
   675    [   13.717714] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm])
   676    [   13.719930] rockchip-rga ff680000.rga: Registered rockchip-rga as /dev/video0
   677    [   13.720117] rockchip-drm display-subsystem: bound ff970000.edp (ops rockchip_dp_component_ops [rockchipdrm])
   678    [   13.720440] rockchip-drm display-subsystem: bound fec00000.dp (ops cdn_dp_component_ops [rockchipdrm])
   679    [   13.745227] rockchip_vdec: module is from the staging directory, the quality is unknown, you have been warned.
   680    [   13.745797] cdn-dp fec00000.dp: [drm:cdn_dp_pd_event_work [rockchipdrm]] Not connected. Disabling cdn
   681    [   13.746828] rkvdec ff660000.video-codec: Adding to iommu group 1
   682    [   13.762661] bootsplash: Loading splash file (563104 bytes)
   683    [   13.762698] bootsplash: Loaded (563104 bytes, 2 pics, 76 blobs).
   684    [   13.765840] hantro_vpu: module is from the staging directory, the quality is unknown, you have been warned.
   685    [   13.768590] hantro-vpu ff650000.video-codec: Adding to iommu group 0
   686    [   13.769723] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-enc as /dev/video2
   687    [   13.771948] hantro-vpu ff650000.video-codec: registered rockchip,rk3399-vpu-dec as /dev/video3
   688    [   13.801248] Bluetooth: HCI UART driver ver 2.3
   689    [   13.801269] Bluetooth: HCI UART protocol H4 registered
   690    [   13.801274] Bluetooth: HCI UART protocol BCSP registered
   691    [   13.801487] Bluetooth: HCI UART protocol LL registered
   692    [   13.801492] Bluetooth: HCI UART protocol ATH3K registered
   693    [   13.801548] Bluetooth: HCI UART protocol Three-wire (H5) registered
   694    [   13.802402] Bluetooth: HCI UART protocol Intel registered
   695    [   13.803443] Bluetooth: HCI UART protocol Broadcom registered
   696    [   13.803457] Driver 'hci_uart_qca' needs updating - please use bus_type methods
   697    [   13.803528] Bluetooth: HCI UART protocol QCA registered
   698    [   13.803532] Bluetooth: HCI UART protocol AG6XX registered
   699    [   13.803582] Bluetooth: HCI UART protocol Marvell registered
   700    [   13.924225] dw-apb-uart ff180000.serial: failed to request DMA
   701    [   14.029488] input: HAILUCK CO.,LTD USB KEYBOARD Mouse as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input8
   702    [   14.029902] input: HAILUCK CO.,LTD USB KEYBOARD Touchpad as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input9
   703    [   14.030213] input: HAILUCK CO.,LTD USB KEYBOARD System Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input10
   704    [   14.030801] systemd[1]: Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
   705    [   14.088675] input: HAILUCK CO.,LTD USB KEYBOARD Consumer Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input11
   706    [   14.089031] input: HAILUCK CO.,LTD USB KEYBOARD Wireless Radio Control as /devices/platform/fe3a0000.usb/usb3/3-1/3-1:1.1/0003:258A:001E.0002/input/input12
   707    [   14.089552] hid-multitouch 0003:258A:001E.0002: input,hiddev96,hidraw1: USB HID v1.10 Mouse [HAILUCK CO.,LTD USB KEYBOARD] on usb-fe3a0000.usb-1/input1
   708    [   14.114521] Console: switching to colour frame buffer device 240x67
   709    [   14.164446] rockchip-drm display-subsystem: [drm] fb0: rockchipdrmfb frame buffer device
   710    [   14.169461] Bluetooth: hci0: BCM: chip id 130
   711    [   14.169873] Bluetooth: hci0: BCM: features 0x0f
   712    [   14.171746] systemd[1]: Starting Load/Save RF Kill Switch Status...
   713    [   14.172052] Bluetooth: hci0: BCM4345C5
   714    [   14.172065] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0000
   715    [   14.174889] Bluetooth: hci0: BCM4345C5 'brcm/BCM4345C5.hcd' Patch
   716    [   14.188975] [drm] Initialized rockchip 1.0.0 20140818 for display-subsystem on minor 1
   717    [   14.198154] power_supply cw2015-battery: cw2015-battery: Found supply : dc-charger
   718    [   14.198167] power_supply cw2015-battery: cw2015-battery: Found supply : tcpm-source-psy-4-0022
   719    [   14.265693] asoc-simple-card es8316-sound: ASoC: no DMI vendor name!
   720    [   14.270626] input: rockchip,es8316-codec Headphones as /devices/platform/es8316-sound/sound/card0/input13
   721    [   14.278908] systemd[1]: Starting Tell Plymouth To Write Out Runtime Data...
   722    [   14.283484] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
   723    [   14.283737] systemd[1]: Started Dispatch Password Requests to Console Directory Watch when bootsplash is active.
   724    [   14.286879] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
   725    [   14.287080] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   726    [   14.287159] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   727    [   14.287221] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   728    [   14.287271] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   729    [   14.297040] systemd[1]: plymouth-read-write.service: Succeeded.
   730    [   14.298011] systemd[1]: Finished Tell Plymouth To Write Out Runtime Data.
   731    [   14.298775] systemd[1]: Condition check resulted in Show Plymouth Boot Screen being skipped.
   732    [   14.299005] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
   733    [   14.299195] systemd[1]: Condition check resulted in Forward Password Requests to Plymouth Directory Watch being skipped.
   734    [   14.299332] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
   735    [   14.299376] systemd[1]: Condition check resulted in Store a System Token in an EFI Variable being skipped.
   736    [   14.299458] systemd[1]: Condition check resulted in Commit a transient machine-id on disk being skipped.
   737    [   14.299502] systemd[1]: Condition check resulted in Platform Persistent Storage Archival being skipped.
   738    [   14.304699] systemd[1]: Started Load/Save RF Kill Switch Status.
   739    [   15.095100] systemd[1]: Finished Armbian memory supported logging.
   740    [   15.101408] Bluetooth: hci0: BCM4345C5 Ampak_CL1 UART 37.4 MHz BT 5.0 [Version: Version: 0039.0089]
   741    [   15.101420] Bluetooth: hci0: BCM4345C5 (003.006.006) build 0089
   742    [   15.103988] systemd[1]: Starting Journal Service...
   743    [   15.287231] systemd[1]: Started Journal Service.
   744    [   15.315318] systemd-journald[975]: Received client request to flush runtime journal.
   745
   746    ### armbian-release:
   747
   748    # PLEASE DO NOT EDIT THIS FILE
   749    BOARD=pinebook-pro
   750    BOARD_NAME="Pinebook Pro"
   751    BOARDFAMILY=rockchip64
   752    BUILD_REPOSITORY_URL=https://github.com/armbian/build
   753    BUILD_REPOSITORY_COMMIT=fef01045-dirty
   754    DISTRIBUTION_CODENAME=focal
   755    DISTRIBUTION_STATUS=supported
   756    VERSION=20.11.6
   757    LINUXFAMILY=rockchip64
   758    BRANCH=current
   759    ARCH=arm64
   760    IMAGE_TYPE=stable
   761    BOARD_TYPE=wip
   762    INITRD_ARCH=arm64
   763    KERNEL_IMAGE_TYPE=Image
   764
   765    ### boot environment:
   766
   767    verbosity=1
   768    bootlogo=true
   769    overlay_prefix=rockchip
   770    fdtfile=rockchip/rk3399-pinebook-pro.dtb
   771    rootdev=UUID=17e7ab46-4e11-4e0f-9633-e33b211860a6
   772    rootfstype=ext4
   773    usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
   774
   775    ### lsusb:
   776
   777    Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   778    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   779    Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
   780    Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   781    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   782    Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
   783    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   784    Bus 003 Device 002: ID 258a:001e HAILUCK CO.,LTD USB KEYBOARD
   785    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
   786    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
   787
   788    ### lscpu:
   789
   790    Architecture:                    aarch64
   791    CPU op-mode(s):                  32-bit, 64-bit
   792    Byte Order:                      Little Endian
   793    CPU(s):                          6
   794    On-line CPU(s) list:             0-5
   795    Thread(s) per core:              1
   796    Core(s) per socket:              3
   797    Socket(s):                       2
   798    NUMA node(s):                    1
   799    Vendor ID:                       ARM
   800    Model:                           4
   801    Model name:                      Cortex-A53
   802    Stepping:                        r0p4
   803    CPU max MHz:                     2016.0000
   804    CPU min MHz:                     408.0000
   805    BogoMIPS:                        48.00
   806    NUMA node0 CPU(s):               0-5
   807    Vulnerability Itlb multihit:     Not affected
   808    Vulnerability L1tf:              Not affected
   809    Vulnerability Mds:               Not affected
   810    Vulnerability Meltdown:          Not affected
   811    Vulnerability Spec store bypass: Not affected
   812    Vulnerability Spectre v1:        Mitigation; __user pointer sanitization
   813    Vulnerability Spectre v2:        Mitigation; Branch predictor hardening
   814    Vulnerability Srbds:             Not affected
   815    Vulnerability Tsx async abort:   Not affected
   816    Flags:                           fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   817
   818    ### cpuinfo:
   819
   820    processor    : 0
   821    BogoMIPS    : 48.00
   822    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   823    CPU implementer    : 0x41
   824    CPU architecture: 8
   825    CPU variant    : 0x0
   826    CPU part    : 0xd03
   827    CPU revision    : 4
   828
   829    processor    : 1
   830    BogoMIPS    : 48.00
   831    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   832    CPU implementer    : 0x41
   833    CPU architecture: 8
   834    CPU variant    : 0x0
   835    CPU part    : 0xd03
   836    CPU revision    : 4
   837
   838    processor    : 2
   839    BogoMIPS    : 48.00
   840    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   841    CPU implementer    : 0x41
   842    CPU architecture: 8
   843    CPU variant    : 0x0
   844    CPU part    : 0xd03
   845    CPU revision    : 4
   846
   847    processor    : 3
   848    BogoMIPS    : 48.00
   849    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   850    CPU implementer    : 0x41
   851    CPU architecture: 8
   852    CPU variant    : 0x0
   853    CPU part    : 0xd03
   854    CPU revision    : 4
   855
   856    processor    : 4
   857    BogoMIPS    : 48.00
   858    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   859    CPU implementer    : 0x41
   860    CPU architecture: 8
   861    CPU variant    : 0x0
   862    CPU part    : 0xd08
   863    CPU revision    : 2
   864
   865    processor    : 5
   866    BogoMIPS    : 48.00
   867    Features    : fp asimd evtstrm aes pmull sha1 sha2 crc32 cpuid
   868    CPU implementer    : 0x41
   869    CPU architecture: 8
   870    CPU variant    : 0x0
   871    CPU part    : 0xd08
   872    CPU revision    : 2
   873
   874
   875    ### meminfo:
   876
   877    MemTotal:        3891140 kB
   878    MemFree:         3554732 kB
   879    MemAvailable:    3571912 kB
   880    Buffers:           21664 kB
   881    Cached:           133372 kB
   882    SwapCached:            0 kB
   883    Active:            72632 kB
   884    Inactive:         117528 kB
   885    Active(anon):        460 kB
   886    Inactive(anon):    49020 kB
   887    Active(file):      72172 kB
   888    Inactive(file):    68508 kB
   889    Unevictable:        8100 kB
   890    Mlocked:               0 kB
   891    SwapTotal:       1945568 kB
   892    SwapFree:        1945568 kB
   893    Dirty:                84 kB
   894    Writeback:             0 kB
   895    AnonPages:         43200 kB
   896    Mapped:            18244 kB
   897    Shmem:             14252 kB
   898    KReclaimable:      23556 kB
   899    Slab:              72412 kB
   900    SReclaimable:      23556 kB
   901    SUnreclaim:        48856 kB
   902    KernelStack:        2992 kB
   903    PageTables:         1864 kB
   904    NFS_Unstable:          0 kB
   905    Bounce:                0 kB
   906    WritebackTmp:          0 kB
   907    CommitLimit:     3891136 kB
   908    Committed_AS:     106688 kB
   909    VmallocTotal:   135290159040 kB
   910    VmallocUsed:       36372 kB
   911    VmallocChunk:          0 kB
   912    Percpu:             2064 kB
   913    AnonHugePages:         0 kB
   914    ShmemHugePages:        0 kB
   915    ShmemPmdMapped:        0 kB
   916    FileHugePages:         0 kB
   917    FilePmdMapped:         0 kB
   918    CmaTotal:         131072 kB
   919    CmaFree:          123872 kB
   920    HugePages_Total:       0
   921    HugePages_Free:        0
   922    HugePages_Rsvd:        0
   923    HugePages_Surp:        0
   924    Hugepagesize:       2048 kB
   925    Hugetlb:               0 kB
   926
   927    ### virtual memory:
   928
   929    vm.admin_reserve_kbytes = 8192
   930    vm.block_dump = 0
   931    vm.compaction_proactiveness = 20
   932    vm.compact_unevictable_allowed = 1
   933    vm.dirty_background_bytes = 0
   934    vm.dirty_background_ratio = 10
   935    vm.dirty_bytes = 0
   936    vm.dirty_expire_centisecs = 3000
   937    vm.dirty_ratio = 20
   938    vm.dirtytime_expire_seconds = 43200
   939    vm.dirty_writeback_centisecs = 500
   940    vm.extfrag_threshold = 500
   941    vm.hugetlb_shm_group = 0
   942    vm.laptop_mode = 0
   943    vm.legacy_va_layout = 0
   944    vm.lowmem_reserve_ratio = 256    256    32    0
   945    vm.max_map_count = 65530
   946    vm.min_free_kbytes = 45056
   947    vm.min_slab_ratio = 5
   948    vm.min_unmapped_ratio = 1
   949    vm.mmap_min_addr = 32768
   950    vm.mmap_rnd_bits = 18
   951    vm.mmap_rnd_compat_bits = 11
   952    vm.nr_hugepages = 0
   953    vm.nr_hugepages_mempolicy = 0
   954    vm.nr_overcommit_hugepages = 0
   955    vm.numa_stat = 1
   956    vm.numa_zonelist_order = Node
   957    vm.oom_dump_tasks = 1
   958    vm.oom_kill_allocating_task = 0
   959    vm.overcommit_kbytes = 0
   960    vm.overcommit_memory = 0
   961    vm.overcommit_ratio = 50
   962    vm.page-cluster = 0
   963    vm.page_lock_unfairness = 5
   964    vm.panic_on_oom = 0
   965    vm.percpu_pagelist_fraction = 0
   966    vm.stat_interval = 1
   967    vm.swappiness = 100
   968    vm.user_reserve_kbytes = 120491
   969    vm.vfs_cache_pressure = 100
   970    vm.watermark_boost_factor = 15000
   971    vm.watermark_scale_factor = 10
   972    vm.zone_reclaim_mode = 0
   973
   974    ### ip addr:
   975
   976    1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
   977        link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
   978        inet XXX.XXX.0.1/8 scope host lo
   979           valid_lft forever preferred_lft forever
   980        inet6 ::1/128 scope host
   981           valid_lft forever preferred_lft forever
   982    2: wlan0: <BROADCAST,MULTICAST> mtu 1500 qdisc noop state DOWN group default qlen 1000
   983        link/ether d4:12:43:26:55:5a brd ff:ff:ff:ff:ff:ff
   984
   985    ### partitions:
   986
   987    major minor  #blocks  name
   988
   989       7        0     240916 loop0
   990       7        1      50012 loop1
   991       7        2     148856 loop2
   992       7        3      58592 loop3
   993       7        4     123016 loop4
   994       7        5        412 loop5
   995       7        6      66324 loop6
   996       7        7        360 loop7
   997      31        0      16384 mtdblock0
   998     179        0   61071360 mmcblk2
   999     179        1     218750 mmcblk2p1
  1000     179        2   60821359 mmcblk2p2
  1001     179       96  250085376 mmcblk1
  1002     179       97  247568128 mmcblk1p1
  1003       7        8      27644 loop8
  1004     252        0    1945572 zram0
  1005     252        1      51200 zram1
  1006
  1007    ### df:
  1008
  1009    udev            1.8G     0  1.8G   0% /dev
  1010    tmpfs           380M  6.1M  374M   2% /run
  1011    /dev/mmcblk1p1  233G   87G  144G  38% /
  1012    tmpfs           1.9G     0  1.9G   0% /dev/shm
  1013    tmpfs           5.0M  4.0K  5.0M   1% /run/lock
  1014    tmpfs           1.9G     0  1.9G   0% /sys/fs/cgroup
  1015    tmpfs           1.9G     0  1.9G   0% /tmp
  1016    /dev/loop3       58M   58M     0 100% /snap/core20/907
  1017    /dev/loop0      236M  236M     0 100% /snap/chromium/1428
  1018    /dev/loop2      146M  146M     0 100% /snap/gnome-3-28-1804/147
  1019    /dev/loop1       49M   49M     0 100% /snap/core18/1949
  1020    /dev/loop4      121M  121M     0 100% /snap/chromium/1449
  1021    /dev/loop5      512K  512K     0 100% /snap/foliate/630
  1022    /dev/loop6       65M   65M     0 100% /snap/gtk-common-themes/1514
  1023    /dev/loop7      384K  384K     0 100% /snap/numix-gtk-themes/3
  1024    /dev/loop8       27M   27M     0 100% /snap/snapd/10709
  1025    /dev/zram1       49M  296K   45M   1% /var/log
  1026
  1027    ### lsblk:
  1028
  1029    NAME         FSTYPE     SIZE MOUNTPOINT                   UUID
  1030    loop0        squashfs 235.3M /snap/chromium/1428
  1031    loop1        squashfs  48.9M /snap/core18/1949
  1032    loop2        squashfs 145.4M /snap/gnome-3-28-1804/147
  1033    loop3        squashfs  57.2M /snap/core20/907
  1034    loop4        squashfs 120.1M /snap/chromium/1449
  1035    loop5        squashfs   412K /snap/foliate/630
  1036    loop6        squashfs  64.8M /snap/gtk-common-themes/1514
  1037    loop7        squashfs   360K /snap/numix-gtk-themes/3
  1038    loop8        squashfs    27M /snap/snapd/10709
  1039    mtdblock0                16M
  1040    mmcblk2                58.2G
  1041    ├─mmcblk2p1  vfat     213.6M                              73BA-2FAF
  1042    └─mmcblk2p2  ext4        58G                              244d82de-6240-444d-83e1-8bf0840bf399
  1043    mmcblk2boot0              4M
  1044    mmcblk2boot1              4M
  1045    mmcblk1               238.5G
  1046    └─mmcblk1p1  ext4     236.1G /                            17e7ab46-4e11-4e0f-9633-e33b211860a6
  1047    zram1                    50M /var/log
  1048
  1049    ### zramctl:
  1050
  1051    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  1052    /dev/zram1 zstd           50M  260K 32.1K  228K       6 /var/log
  1053    /dev/zram0 lzo-rle       1.9G    4K   74B   12K       6 [SWAP]
  1054
  1055    ### mtab:
  1056
  1057    /dev/loop0 /snap/chromium/1428 squashfs ro,nodev,relatime 0 0
  1058    /dev/loop1 /snap/core18/1949 squashfs ro,nodev,relatime 0 0
  1059    /dev/loop2 /snap/gnome-3-28-1804/147 squashfs ro,nodev,relatime 0 0
  1060    /dev/loop3 /snap/core20/907 squashfs ro,nodev,relatime 0 0
  1061    /dev/loop4 /snap/chromium/1449 squashfs ro,nodev,relatime 0 0
  1062    /dev/loop5 /snap/foliate/630 squashfs ro,nodev,relatime 0 0
  1063    /dev/loop6 /snap/gtk-common-themes/1514 squashfs ro,nodev,relatime 0 0
  1064    /dev/loop7 /snap/numix-gtk-themes/3 squashfs ro,nodev,relatime 0 0
  1065    /dev/loop8 /snap/snapd/10709 squashfs ro,nodev,relatime 0 0
  1066    /dev/mmcblk1p1 / ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1067    /dev/mmcblk1p1 /var/log.hdd ext4 rw,noatime,nodiratime,errors=remount-ro,commit=600 0 0
  1068    /dev/zram1 /var/log ext4 rw,relatime,discard 0 0
  1069
  1070    ### mmc2:0001 info:
  1071
  1072                   fwrev: 0x3536323330613137
  1073                  uevent: DRIVER=mmcblk MMC_TYPE=MMC MMC_NAME=DA4064 MODALIAS=mmc:block
  1074                     cid: 4501004441343036340188d1230f8600
  1075             rel_sectors: 0x1
  1076    enhanced_rpmb_supported: 0x1
  1077                     rca: 0x0001
  1078            pre_eol_info: 0x01
  1079                     csd: d00f00328f5903ffffffffef8a404000
  1080                  manfid: 0x000045
  1081                     ocr: 0x00000080
  1082    preferred_erase_size: 4194304
  1083    enhanced_area_offset: 18446744073709551594
  1084      raw_rpmb_size_mult: 0x80
  1085                    type: MMC
  1086                   hwrev: 0x0
  1087                    date: 08/2019
  1088                     prv: 0x1
  1089             ffu_capable: 1
  1090                     dsr: 0x404
  1091              erase_size: 524288
  1092               life_time: 0x01 0x01
  1093      enhanced_area_size: 4294967274
  1094                   oemid: 0x0100
  1095                  serial: 0x88d1230f
  1096                 cmdq_en: 1
  1097                     rev: 0x8
  1098                    name: DA4064
  1099
  1100    ### mmc1:0001 info:
  1101
  1102                   fwrev: 0x0
  1103                  uevent: DRIVER=mmcblk MMC_TYPE=SD MMC_NAME=EE8QT MODALIAS=mmc:block
  1104                     cid: 1b534d4545385154306de5554f0144e1
  1105                     rca: 0x0001
  1106                     csd: 400e00325b59000773ff7f800a40401f
  1107                  manfid: 0x00001b
  1108                     ocr: 0x00040000
  1109    preferred_erase_size: 16777216
  1110                    type: SD
  1111                   hwrev: 0x3
  1112                    date: 04/2020
  1113                     dsr: 0x404
  1114              erase_size: 512
  1115                   oemid: 0x534d
  1116                  serial: 0x6de5554f
  1117                     ssr: 00000000080000000400c0000f053c00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
  1118                     scr: 0285848300000000
  1119                    name: EE8QT
  1120
  1121    ### Boot system health:
  1122
  1123    Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1124    07:56:03: 1200/1512MHz  2.90  43%  22%  14%   0%   7%   0% 30.0°C  0/6
  1125    07:56:03:  816/1200MHz  2.90  21%  12%   8%   0%   0%   0% 29.4°C  0/6
  1126    07:56:04:  408/1512MHz  2.90  21%  12%   7%   0%   0%   0% 29.4°C  0/6
  1127    07:56:04:  600/1416MHz  2.90  21%  12%   8%   0%   0%   0% 29.4°C  0/6
  1128    07:56:04: 1800/1512MHz  2.90  63%  27%   9%   0%  22%   2% 30.6°C  0/6
  1129
  1130    ### lsusb:
  1131
  1132    Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1133    Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1134    Bus 008 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
  1135    Bus 007 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1136    Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1137    Bus 002 Device 002: ID 05e3:0608 Genesys Logic, Inc. Hub
  1138    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1139    Bus 003 Device 002: ID 258a:001e HAILUCK CO.,LTD USB KEYBOARD
  1140    Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
  1141    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
  1142
  1143    /:  Bus 08.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
  1144    /:  Bus 07.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
  1145    /:  Bus 06.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 5000M
  1146    /:  Bus 05.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
  1147    /:  Bus 04.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1148    /:  Bus 03.Port 1: Dev 1, Class=root_hub, Driver=ohci-platform/1p, 12M
  1149        |__ Port 1: Dev 2, If 0, Class=Human Interface Device, Driver=usbhid, 1.5M
  1150        |__ Port 1: Dev 2, If 1, Class=Human Interface Device, Driver=usbhid, 1.5M
  1151    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1152        |__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
  1153    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=ehci-platform/1p, 480M
  1154
  1155    ### lspci:
  1156
  1157
  1158    ### Installed packages:
  1159
  1160    ii  armbian-config                                   20.11.6                              all          Armbian configuration utility
  1161    ii  armbian-firmware                                 20.11.3                              all          Linux firmware
  1162    ii  armbian-focal-desktop                            20.11.6                              all          Armbian desktop for Ubuntu focal
  1163    ii  hostapd                                          3:2.9-102~armbian20.05.2+1           arm64        IEEE 802.11 AP and IEEE 802.1X/WPA/WPA2/EAP Authenticator
  1164    ii  htop                                             3.1.0-0~armbian20.08.2+1             arm64        interactive processes viewer
  1165    ii  linux-base                                       4.5ubuntu3.1                         all          Linux image base package
  1166    ii  linux-dtb-current-rockchip64                     20.11.4                              arm64        Linux DTB, version 5.9.14-rockchip64
  1167    ii  linux-focal-root-current-pinebook-pro            20.11.6                              arm64        Armbian tweaks for focal on pinebook-pro (current branch)
  1168    ii  linux-image-current-rockchip64                   20.11.4                              arm64        Linux kernel, version 5.9.14-rockchip64
  1169    ii  linux-libc-dev:arm64                             5.4.0-64.72                          arm64        Linux Kernel Headers for development
  1170    ii  linux-u-boot-pinebook-pro-current                20.11.6                              arm64        Uboot loader 2020.10
  1171
  1172    ### Loaded modules:
  1173
  1174    Module                  Size  Used by
  1175    uinput                 28672  0
  1176    rfcomm                 98304  4
  1177    algif_hash             20480  2
  1178    algif_skcipher         20480  2
  1179    af_alg                 32768  10 algif_hash,algif_skcipher
  1180    bnep                   32768  2
  1181    governor_performance    16384  0
  1182    snd_soc_hdmi_codec     20480  0
  1183    hci_uart              155648  0
  1184    btqca                  20480  1 hci_uart
  1185    hantro_vpu             90112  0
  1186    rockchip_vdec          32768  0
  1187    btrtl                  24576  1 hci_uart
  1188    btbcm                  24576  1 hci_uart
  1189    snd_soc_simple_amplifier    16384  1
  1190    rockchip_rga           28672  0
  1191    btintel                32768  1 hci_uart
  1192    v4l2_h264              16384  2 rockchip_vdec,hantro_vpu
  1193    snd_soc_simple_card    24576  4
  1194    videobuf2_dma_contig    24576  2 rockchip_vdec,hantro_vpu
  1195    snd_soc_rockchip_i2s    24576  2
  1196    snd_soc_es8316         45056  1
  1197    fusb302                28672  0
  1198    btsdio                 20480  0
  1199    v4l2_mem2mem           45056  3 rockchip_vdec,hantro_vpu,rockchip_rga
  1200    videobuf2_dma_sg       20480  1 rockchip_rga
  1201    videobuf2_vmalloc      20480  1 hantro_vpu
  1202    snd_soc_simple_card_utils    28672  1 snd_soc_simple_card
  1203    tcpm                   57344  1 fusb302
  1204    panfrost               69632  3
  1205    videobuf2_memops       20480  3 videobuf2_vmalloc,videobuf2_dma_contig,videobuf2_dma_sg
  1206    gpu_sched              45056  1 panfrost
  1207    videobuf2_v4l2         36864  4 rockchip_vdec,hantro_vpu,rockchip_rga,v4l2_mem2mem
  1208    hid_multitouch         32768  0
  1209    videobuf2_common       65536  5 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,v4l2_mem2mem
  1210    typec                  61440  1 tcpm
  1211    snd_soc_core          262144  6 snd_soc_hdmi_codec,snd_soc_simple_amplifier,snd_soc_simple_card_utils,snd_soc_rockchip_i2s,snd_soc_simple_card,snd_soc_es8316
  1212    bluetooth             671744  33 btrtl,btqca,btsdio,btintel,hci_uart,btbcm,bnep,rfcomm
  1213    videodev              307200  6 rockchip_vdec,videobuf2_v4l2,hantro_vpu,rockchip_rga,videobuf2_common,v4l2_mem2mem
  1214    snd_pcm_dmaengine      20480  1 snd_soc_core
  1215    brcmfmac              413696  0
  1216    cw2015_battery         20480  0
  1217    snd_pcm               131072  5 snd_soc_hdmi_codec,snd_soc_core,snd_soc_es8316,snd_pcm_dmaengine
  1218    mc                     65536  6 rockchip_vdec,videodev,videobuf2_v4l2,hantro_vpu,videobuf2_common,v4l2_mem2mem
  1219    brcmutil               24576  1 brcmfmac
  1220    snd_timer              45056  2 snd_pcm
  1221    snd                   102400  10 snd_soc_hdmi_codec,snd_timer,snd_soc_core,snd_pcm
  1222    cfg80211              888832  1 brcmfmac
  1223    soundcore              16384  1 snd
  1224    gpio_charger           16384  0
  1225    cpufreq_dt             20480  0
  1226    rfkill                 40960  7 bluetooth,cfg80211
  1227    zstd                   16384  6
  1228    zram                   40960  2
  1229    nf_log_ipv6            16384  5
  1230    ip6t_REJECT            16384  1
  1231    nf_reject_ipv6         20480  1 ip6t_REJECT
  1232    xt_hl                  16384  22
  1233    ip6t_rt                20480  3
  1234    nf_log_ipv4            16384  5
  1235    nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
  1236    ipt_REJECT             16384  1
  1237    nf_reject_ipv4         16384  1 ipt_REJECT
  1238    xt_LOG                 20480  10
  1239    xt_limit               16384  13
  1240    xt_addrtype            16384  4
  1241    xt_tcpudp              20480  18
  1242    xt_conntrack           16384  16
  1243    nf_conntrack          172032  1 xt_conntrack
  1244    nf_defrag_ipv6         24576  1 nf_conntrack
  1245    nf_defrag_ipv4         16384  1 nf_conntrack
  1246    sch_fq_codel           20480  2
  1247    ip6table_filter        16384  1
  1248    ip6_tables             32768  53 ip6table_filter
  1249    iptable_filter         16384  1
  1250    bpfilter               16384  0
  1251    ip_tables              32768  9 iptable_filter
  1252    x_tables               53248  13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,ip6t_rt,ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl,ip6t_REJECT
  1253    autofs4                49152  2
  1254    rockchipdrm           147456  8
  1255    analogix_dp            53248  1 rockchipdrm
  1256    dw_hdmi                53248  1 rockchipdrm
  1257    dw_mipi_dsi            20480  1 rockchipdrm
  1258    drm_kms_helper        258048  4 dw_mipi_dsi,rockchipdrm,dw_hdmi,analogix_dp
  1259    cec                    81920  2 drm_kms_helper,dw_hdmi
  1260    panel_simple           81920  0
  1261    rc_core                61440  1 cec
  1262    drm                   630784  14 gpu_sched,drm_kms_helper,dw_mipi_dsi,panel_simple,rockchipdrm,dw_hdmi,panfrost,analogix_dp
  1263    drm_panel_orientation_quirks    20480  1 drm
  1264    pwm_bl                 20480  0
  1265
  1266    ### Current system health:
  1267
  1268    Time       big.LITTLE   load %cpu %sys %usr %nice %io %irq   CPU  C.St.
  1269    08:08:07:   ---      0.76  12%   3%   8%   0%   0%   0% 39.4°C  0/6
  1270    08:08:07:   ---      0.76   3%   1%   0%   0%   0%   0% 38.8°C  0/6
  1271    08:08:07:   ---      0.76   3%   2%   0%   0%   0%   0% 38.1°C  0/6
  1272    08:08:08:   ---      0.76   2%   2%   0%   0%   0%   0% 38.8°C  0/6
  1273    08:08:08:   ---      0.76   2%   2%   0%   0%   0%   0% 38.1°C  0/6
  1274    08:08:09:   ---      0.76  12%   3%   8%   0%   0%   0% 44.4°C  0/6
  1275    08:08:10:   ---      0.76  95%   4%  90%   0%   0%   0% 50.0°C  0/6
  1276    08:08:11:   ---      1.26  99%   1%  98%   0%   0%   0% 50.6°C  0/6
  1277    08:08:12:   ---      1.26  58%   1%  57%   0%   0%   0% 43.3°C  0/6
  1278    08:08:12:   ---      1.26   2%   2%   0%   0%   0%   0% 42.2°C  0/6
  1279
  1280    ### resolv.conf
  1281
  1282    -rw-r--r-- 1 root root 92 Jan 24 07:56 /etc/resolv.conf
  1283    # Generated by NetworkManager
  1284    search home
  1285    nameserver XXX.XXX.2.1
  1286    nameserver XXX.XXX.234.129
  1287
  1288    ### Current sysinfo:
  1289
  1290    Linux 5.9.14-rockchip64 (pinebook-pro)     2021-01-24     _aarch64_    (6 CPU)
  1291
  1292    avg-cpu:  %user   %nice %system %iowait  %steal   %idle
  1293               8.44    0.22    3.22    0.58    0.00   87.54
  1294
  1295    Device             tps    kB_read/s    kB_wrtn/s    kB_dscd/s    kB_read    kB_wrtn    kB_dscd
  1296    mtdblock0         0.05         0.45         0.00         0.00        336          0          0
  1297    mmcblk2           0.39        11.85         0.00         0.00       8914          0          0
  1298    mmcblk2p1         0.12         4.21         0.00         0.00       3163          0          0
  1299    mmcblk2p2         0.21         6.22         0.00         0.00       4678          0          0
  1300    mmcblk2boot1      0.08         0.31         0.00         0.00        232          0          0
  1301    mmcblk2boot0      0.08         0.31         0.00         0.00        232          0          0
  1302    mmcblk1          22.35      1213.46       331.78         0.00     912537     249500          0
  1303    mmcblk1p1        22.22      1210.67       331.78         0.00     910433     249500          0
  1304    zram0             0.76         3.02         0.01         0.00       2272          4          0
  1305    zram1             0.38         0.59         1.53         0.00        444       1148          0
  1306    zram2             0.00         0.00         0.00         0.00          0          0          0
  1307
  1308    procs -----------------------memory---------------------- ---swap-- -----io---- -system-- --------cpu--------
  1309     r  b         swpd         free         buff        cache   si   so    bi    bo   in   cs  us  sy  id  wa  st
  1310     0  0            0      1623216        58200      1244048    0    0   210    56  634  785   9   3  88   1   0
  1311
  1312                  total        used        free      shared  buff/cache   available
  1313    Mem:          3.7Gi       943Mi       1.5Gi       263Mi       1.2Gi       2.4Gi
  1314    Swap:         1.9Gi          0B       1.9Gi
  1315
  1316    NAME       ALGORITHM DISKSIZE  DATA COMPR TOTAL STREAMS MOUNTPOINT
  1317    /dev/zram1 zstd           50M  664K  145K  468K       6 /var/log
  1318    /dev/zram0 lzo-rle       1.9G    4K   74B   12K       6 [SWAP]
  1319
  1320     08:08:17 up 12 min,  1 user,  load average: 1.24, 0.94, 0.67
  1321
  1322    [   25.846071] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1323    [   25.846566] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1324    [   25.848067] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1325    [   25.848561] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1326    [   25.849938] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1327    [   25.850435] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1328    [   25.851878] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1329    [   25.852407] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1330    [   25.853929] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1331    [   25.854422] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1332    [   25.857438] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1333    [   25.857946] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1334    [   25.863280] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1335    [   25.863774] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1336    [   25.870360] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1337    [   25.870855] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1338    [   25.871806] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1339    [   25.872346] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1340    [   25.878532] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1341    [   25.879028] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1342    [   25.884619] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1343    [   25.885114] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1344    [   25.886074] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1345    [   25.886566] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1346    [   26.177815] Bluetooth: RFCOMM TTY layer initialized
  1347    [   26.177833] Bluetooth: RFCOMM socket layer initialized
  1348    [   26.177857] Bluetooth: RFCOMM ver 1.11
  1349    [   27.798380] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
  1350    [   28.192086] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1351    [   28.192103] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1352    [   29.322283] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1353    [   29.322300] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1354    [   30.530238] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1355    [   30.530260] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1356    [   31.068327] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1357    [   31.068823] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1358    [   31.072509] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1359    [   31.073010] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1360    [   31.726523] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1361    [   31.726539] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1362    [   35.812173] vcc3v3_ssd: disabling
  1363    [   35.812190] vbus_5vout: disabling
  1364    [   35.812201] vcc0v9_s3: disabling
  1365    [   36.728853] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1366    [   36.729347] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1367    [   36.731038] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1368    [   36.731530] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1369    [   37.137010] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1370    [   37.137507] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1371    [   37.143164] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1372    [   37.143722] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1373    [   37.145852] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1374    [   37.146347] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1375    [   37.147993] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1376    [   37.148828] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1377    [   37.150417] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1378    [   37.150915] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1379    [   37.154662] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1380    [   37.155173] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1381    [   37.164302] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1382    [   37.164833] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1383    [   37.166285] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1384    [   37.166779] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1385    [   37.168256] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1386    [   37.168749] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1387    [   37.170244] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1388    [   37.170738] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1389    [   37.172382] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1390    [   37.172877] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1391    [   37.175387] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1392    [   37.175880] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1393    [   37.180612] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1394    [   37.181108] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1395    [   37.186720] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1396    [   37.187214] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1397    [   37.188190] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1398    [   37.188679] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1399    [   37.194645] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1400    [   37.195139] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1401    [   37.200412] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1402    [   37.200933] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1403    [   37.201803] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1404    [   37.202290] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1405    [   38.537634] overlayfs: "xino" feature enabled using 2 upper inode bits.
  1406    [   38.637713] overlayfs: "xino" feature enabled using 2 upper inode bits.
  1407    [   38.731044] overlayfs: "xino" feature enabled using 2 upper inode bits.
  1408    [   42.323196] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1409    [   42.323712] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1410    [   42.328791] rockchip-i2s ff890000.i2s: Fail to set mclk -22
  1411    [   42.329309] rockchip-i2s ff890000.i2s: ASoC: error at snd_soc_dai_set_sysclk on ff890000.i2s: -22
  1412    [   53.641873] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1413    [   53.641889] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1414    [   60.592689] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1415    [   60.592726] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1416    [   72.150821] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1417    [   72.150844] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1418    [   76.582160] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1419    [   76.582195] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1420    [   79.102757] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1421    [   79.102792] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1422    [   96.186917] input: Sesh (AVRCP) as /devices/virtual/input/input14
  1423    [  102.822250] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1424    [  102.822273] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1425    [  103.563112] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1426    [  103.563149] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1427    [  104.269091] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1428    [  104.269127] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1429    [  109.886129] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1430    [  109.886152] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1431    [  112.186102] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1432    [  112.186125] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1433    [  115.991990] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1434    [  115.992013] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1435    [  118.097866] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1436    [  118.097889] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1437    [  128.034283] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1438    [  128.034307] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1439    [  140.896355] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1440    [  140.896377] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1441    [  149.030144] input: Sesh (AVRCP) as /devices/virtual/input/input15
  1442    [  154.500955] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1443    [  154.500992] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1444    [  160.427585] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1445    [  160.427621] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1446    [  175.551956] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1447    [  175.551978] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1448    [  176.067403] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1449    [  176.067425] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1450    [  179.035323] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1451    [  179.035346] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1452    [  179.552519] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1453    [  179.552533] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1454    [  203.954551] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1455    [  203.954579] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1456    [  204.451585] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1457    [  204.451625] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1458    [  209.952761] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1459    [  209.952777] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1460    [  228.117582] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1461    [  228.117605] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1462    [  228.796241] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1463    [  228.796257] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1464    [  251.955329] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1465    [  251.955345] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1466    [  255.988098] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1467    [  255.988135] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1468    [  282.393972] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1469    [  282.394002] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1470    [  289.223686] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1471    [  289.223710] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1472    [  313.512863] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1473    [  313.512886] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1474    [  314.462452] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1475    [  314.462474] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1476    [  323.355327] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1477    [  323.355369] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1478    [  349.703019] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1479    [  349.703059] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1480    [  351.801630] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1481    [  351.801652] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1482    [  352.734513] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1483    [  352.734537] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1484    [  379.818830] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1485    [  379.818880] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1486    [  385.942650] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1487    [  385.942666] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1488    [  391.423224] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1489    [  391.423247] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1490    [  394.619180] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1491    [  394.619204] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1492    [  395.557056] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1493    [  395.557075] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1494    [  396.882656] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1495    [  396.882679] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1496    [  417.520138] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1497    [  417.520156] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1498    [  423.965526] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1499    [  423.965564] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1500    [  424.651489] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1501    [  424.651525] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1502    [  428.860550] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1503    [  428.860586] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1504    [  449.795679] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1505    [  449.795719] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1506    [  461.347995] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1507    [  461.348017] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1508    [  462.454974] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1509    [  462.454990] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1510    [  465.537500] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1511    [  465.537515] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1512    [  487.139455] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1513    [  487.139493] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1514    [  495.971791] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1515    [  495.971821] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1516    [  512.635045] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1517    [  512.635061] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1518    [  520.948766] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1519    [  520.948781] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1520    [  529.460812] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1521    [  529.460853] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1522    [  530.418494] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1523    [  530.418517] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1524    [  546.442425] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1525    [  546.442466] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1526    [  550.780840] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1527    [  550.780870] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1528    [  556.560888] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1529    [  556.560917] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1530    [  558.300280] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1531    [  558.300309] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1532    [  559.420617] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1533    [  559.420640] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1534    [  577.252364] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1535    [  577.252403] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1536    [  588.104523] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1537    [  588.104547] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1538    [  592.929761] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1539    [  592.929783] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1540    [  594.036616] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1541    [  594.036653] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1542    [  601.194085] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1543    [  601.194107] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1544    [  618.698624] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1545    [  618.698661] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1546    [  619.388414] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1547    [  619.388451] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1548    [  620.769042] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1549    [  620.769079] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1550    [  630.218339] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1551    [  630.218375] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1552    [  652.788400] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1553    [  652.788415] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1554    [  672.748860] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1555    [  672.748883] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1556    [  677.163765] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1557    [  677.163795] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1558    [  678.198584] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1559    [  678.198632] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1560    [  688.605518] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1561    [  688.605555] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1562    [  691.484103] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1563    [  691.484127] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1564    [  710.531450] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1565    [  710.531472] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1566    [  714.019769] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1567    [  714.019793] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1568    [  718.100428] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1569    [  718.100443] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1570    [  728.014083] rockchip-dp ff970000.edp: Failed to apply PSR -110
  1571    [  728.014131] [drm:analogix_dp_bridge_atomic_enable [analogix_dp]] *ERROR* Failed to disable psr -110
  1572
  1573
  1574    vm.admin_reserve_kbytes = 8192
  1575    vm.block_dump = 0
  1576    vm.compaction_proactiveness = 20
  1577    vm.compact_unevictable_allowed = 1
  1578    vm.dirty_background_bytes = 0
  1579    vm.dirty_background_ratio = 10
  1580    vm.dirty_bytes = 0
  1581    vm.dirty_expire_centisecs = 3000
  1582    vm.dirty_ratio = 20
  1583    vm.dirtytime_expire_seconds = 43200
  1584    vm.dirty_writeback_centisecs = 500
  1585    vm.extfrag_threshold = 500
  1586    vm.hugetlb_shm_group = 0
  1587    vm.laptop_mode = 0
  1588    vm.legacy_va_layout = 0
  1589    vm.lowmem_reserve_ratio = 256    256    32    0
  1590    vm.max_map_count = 65530
  1591    vm.min_free_kbytes = 45056
  1592    vm.min_slab_ratio = 5
  1593    vm.min_unmapped_ratio = 1
  1594    vm.mmap_min_addr = 32768
  1595    vm.nr_hugepages = 0
  1596    vm.nr_hugepages_mempolicy = 0
  1597    vm.nr_overcommit_hugepages = 0
  1598    vm.numa_stat = 1
  1599    vm.numa_zonelist_order = Node
  1600    vm.oom_dump_tasks = 1
  1601    vm.oom_kill_allocating_task = 0
  1602    vm.overcommit_kbytes = 0
  1603    vm.overcommit_memory = 0
  1604    vm.overcommit_ratio = 50
  1605    vm.page-cluster = 0
  1606    vm.page_lock_unfairness = 5
  1607    vm.panic_on_oom = 0
  1608    vm.percpu_pagelist_fraction = 0
  1609    vm.stat_interval = 1
  1610    vm.swappiness = 100
  1611    vm.user_reserve_kbytes = 120491
  1612    vm.vfs_cache_pressure = 100
  1613    vm.watermark_boost_factor = 15000
  1614    vm.watermark_scale_factor = 10
  1615    vm.zone_reclaim_mode = 0
  1616
  1617    ### interrupts:
  1618               CPU0       CPU1       CPU2       CPU3       CPU4       CPU5
  1619     10:          0          0          0          0          0          0     GICv3  25 Level     vgic
  1620     12:          0          0          0          0          0          0     GICv3  27 Level     kvm guest vtimer
  1621     15:      96628     103702     118868     107927     146843     116784     GICv3  30 Level     arch_timer
  1622     17:          0          0          0          0          0          0     GICv3 113 Level     rk_timer
  1623     18:          0          0          0          0          0          0  GICv3-23   0 Level     arm-pmu
  1624     19:          0          0          0          0          0          0  GICv3-23   1 Level     arm-pmu
  1625     20:          0          0          0          0          0          0     GICv3  37 Level     ff6d0000.dma-controller
  1626     21:      16526          0          0          0          0          0     GICv3  38 Level     ff6d0000.dma-controller
  1627     22:          0          0          0          0          0          0     GICv3  39 Level     ff6e0000.dma-controller
  1628     23:        673          0          0          0          0          0     GICv3  40 Level     ff6e0000.dma-controller
  1629     27:       5085      79763          0          0          0          0     GICv3  96 Level     dw-mci
  1630     28:      41602     589017          0          0          0          0     GICv3  97 Level     dw-mci
  1631     29:        865          0          0          0          0          0     GICv3  43 Level     mmc2
  1632     30:          2          0          0          0          0          0     GICv3  58 Level     ehci_hcd:usb1
  1633     31:         45      19727          0          0          0          0     GICv3  60 Level     ohci_hcd:usb3
  1634     32:        165          0          0          0          0          0     GICv3  62 Level     ehci_hcd:usb2
  1635     33:          0          0          0          0          0          0     GICv3  64 Level     ohci_hcd:usb4
  1636     35:         12          0          0          0          0          0     GICv3  94 Level     ff100000.saradc
  1637     36:        801          0          0          0          0          0     GICv3  91 Level     ff110000.i2c
  1638     37:          0          0          0          0          0          0     GICv3  66 Level     ff130000.i2c
  1639     38:     147556          0          0          0          0          0     GICv3 131 Level     ttyS0
  1640     39:          5          0          0          0          0          0     GICv3 132 Level     ttyS2
  1641     40:       2031          0          0          0          0          0     GICv3  85 Level     ff1d0000.spi
  1642     41:          0          0          0          0          0          0     GICv3 129 Level     rockchip_thermal
  1643     42:      10977          0          0          0          0          0     GICv3  89 Level     ff3c0000.i2c
  1644     43:       2890          0          0          0          0          0     GICv3  88 Level     ff3d0000.i2c
  1645     44:          0          0          0          0          0          0     GICv3 146 Level     ff650000.video-codec
  1646     45:          0          0          0          0          0          0     GICv3 145 Level     ff650000.video-codec
  1647     46:          0          0          0          0          0          0     GICv3 147 Level     ff650800.iommu
  1648     47:          0          0          0          0          0          0     GICv3 148 Level     ff660000.video-codec
  1649     48:          0          0          0          0          0          0     GICv3 149 Level     ff660480.iommu
  1650     49:          0          0          0          0          0          0     GICv3  87 Level     ff680000.rga
  1651     50:          0          0          0          0          0          0     GICv3 152 Edge      ff848000.watchdog
  1652     52:      26132          0          0          0          0          0     GICv3 151 Level     ff8f3f00.iommu, ff8f0000.vop
  1653     53:          0          0          0          0          0          0     GICv3 150 Level     ff903f00.iommu, ff900000.vop
  1654     54:          0          0          0          0          0          0     GICv3  75 Level     ff914000.iommu
  1655     55:          0          0          0          0          0          0     GICv3  76 Level     ff924000.iommu
  1656     56:          0          0          0          0          0          0     GICv3  42 Level     analogix-dp
  1657     57:      60038          0          0          0          0          0     GICv3  52 Level     panfrost-job
  1658     58:          0          0          0          0          0          0     GICv3  53 Level     panfrost-mmu
  1659     59:          2        944          0          0          0          0     GICv3  51 Level     panfrost-gpu
  1660     69:       4582          0          0          0          0          0  rockchip_gpio_irq   4 Edge      host_wake
  1661     70:          1          0          0          0          0          0  rockchip_gpio_irq   5 Edge      Power
  1662     72:          0          0          0          0          0          0  rockchip_gpio_irq   7 Edge      fe320000.mmc cd
  1663     73:          0          0          0          0          0          0  rockchip_gpio_irq   8 Edge      Headphone detection
  1664     98:          0          0          0          0          0          0  rockchip_gpio_irq   1 Edge      Lid
  1665     99:          0          0          0          0          0          0  rockchip_gpio_irq   2 Level     fsc_interrupt_int_n
  1666    171:          0          0          0          0          0          0  rockchip_gpio_irq  10 Level     rk808
  1667    217:          0          0          0          0          0          0  rockchip_gpio_irq  24 Edge      dc-charger
  1668    225:          1          0          0          0          0          0     GICv3  59 Level     rockchip_usb2phy
  1669    226:          1          0          0          0          0          0     GICv3  63 Level     rockchip_usb2phy
  1670    227:          0          0          0          0          0          0     GICv3 137 Level     xhci-hcd:usb7
  1671    228:          0          0          0          0          0          0     GICv3 142 Level     xhci-hcd:usb5
  1672    234:          0          0          0          0          0          0     rk808   5 Edge      RTC alarm
  1673    IPI0:     99318      86021     117609     133341      22301      31258       Rescheduling interrupts
  1674    IPI1:     56845      33945      30407      35767     295748     190783       Function call interrupts
  1675    IPI2:         0          0          0          0          0          0       CPU stop interrupts
  1676    IPI3:         0          0          0          0          0          0       CPU stop (for crash dump) interrupts
  1677    IPI4:         0          0          0          0          0          0       Timer broadcast interrupts
  1678    IPI5:       861        584        445        529       1332        874       IRQ work interrupts
  1679    IPI6:         0          0          0          0          0          0       CPU wake-up interrupts
  1680    Err:          0
  • Solution
Hi there,
Wanted to let you know that I fixed the problem, it appears. Pulse audio pasystray seems to be the issue afaiu. Below are the steps to make the multimedia volume keys work on pinebook pro:
1. Open Keyboard from Settings and remove the volume shortcuts from the applications shortcut tab.
2. Open Session and Startup settings and deselect Pulse audio pasystray to disable from autostarting.
3. Reboot to make sure you don't have pasystray starting on the notification area.
4. Right click on the panel to add "Pulse Audio Plugin" to your panel.
That is it. You may want to reboot once more to ensure all your panel items are in place. Pulse Audio Plugin of XFCE is better suited for daily usage than pasystray imho as it is less cluttered.
