armbianmonitor cpu-temperature broken
Go to solution Solved by Werner,
I have the same problem on Orange Pi PC
rmbianmonitor -m
12:15:42:   ---      0.06  15%   4%   9%   1%   0%   0%/usr/bin/armbianmonitor: line 388: read: read error: 0: Invalid argument
/usr/bin/armbianmonitor: line 389: [: -ge: unary operator expected
cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepipc
BOARD_NAME="Orange Pi PC"
BOARDFAMILY=sun8i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=fef01045-dirty
DISTRIBUTION_CODENAME=bionic
DISTRIBUTION_STATUS=supported
VERSION=20.11.6
LINUXFAMILY=sunxi
BRANCH=dev
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMGE_TYPE=Image
3 hours ago, Илья Козлов said:
Please fix this or use "-U" instead and upload whole output manually
So armbianmonitor -U
Using sudo is also a good idea if some resources used by armbianmonitor needs root privileges.
If I remember well it solves this issue last time I tried.
 sudo armbianmonitor -U | pastebinit
http://paste.ubuntu.com/p/42StCf2NhS/
  • Solution
20138	hi  linux-dtb-dev-sunxi                   5.97                                 armhf        Linux DTB, version 5.2.14-sunxi
Try using
a) an actual supported branch and
b) up-to-date packages
