Janaboy Posted February 9, 2021 Posted February 9, 2021 Dear All, I have a Beelink s905 box with Armbian (Ubuntu 19.10). I have problems to install Mosquitto as it is required a package which i don't know how to install: The following packages have unmet dependencies: mosquitto:armhf : Depends: libwebsockets8:armhf (>= 1.6.0) but it is not installable E: Unable to correct problems, you have held broken packages. I am okay to use another type of Mqtt broker but couldn't find a solution I am searching for hours now.. Somebody has any ideas? Thank you in advance
guidol Posted February 9, 2021 Posted February 9, 2021 Did you try to sudo apt update -y && apt upgrade -y before you install mosquitto? For the "broken packages" try sudo dpkg –configure -a or sudo apt -f install
Janaboy Posted February 9, 2021 Author Posted February 9, 2021 2 minutes ago, guidol said: Did you try to sudo apt update -y && apt upgrade -y before you install mosquitto? For the "broken packages" try sudo dpkg –configure -a or sudo apt -f install I have tried it now, but no changes
SteeMan Posted February 9, 2021 Posted February 9, 2021 I suspect your problem is related to the fact that Ubuntu 19.10 was End of Life on July 17, 2020. You would likely be better off by getting on a supported ubuntu release.
