Janaboy Posted February 9, 2021 Share Posted February 9, 2021 Dear All, I have a Beelink s905 box with Armbian (Ubuntu 19.10). I have problems to install Mosquitto as it is required a package which i don't know how to install: The following packages have unmet dependencies: mosquitto:armhf : Depends: libwebsockets8:armhf (>= 1.6.0) but it is not installable E: Unable to correct problems, you have held broken packages. I am okay to use another type of Mqtt broker but couldn't find a solution I am searching for hours now.. Somebody has any ideas? Thank you in advance Link to comment Share on other sites More sharing options...
guidol Posted February 9, 2021 Share Posted February 9, 2021 Did you try to sudo apt update -y && apt upgrade -y before you install mosquitto? For the "broken packages" try sudo dpkg –configure -a or sudo apt -f install Link to comment Share on other sites More sharing options...
Janaboy Posted February 9, 2021 Author Share Posted February 9, 2021 2 minutes ago, guidol said: Did you try to sudo apt update -y && apt upgrade -y before you install mosquitto? For the "broken packages" try sudo dpkg –configure -a or sudo apt -f install I have tried it now, but no changes Link to comment Share on other sites More sharing options...
SteeMan Posted February 9, 2021 Share Posted February 9, 2021 I suspect your problem is related to the fact that Ubuntu 19.10 was End of Life on July 17, 2020. You would likely be better off by getting on a supported ubuntu release. Link to comment Share on other sites More sharing options...
Janaboy Posted February 10, 2021 Author Share Posted February 10, 2021 I will try to update my system then Link to comment Share on other sites More sharing options...
