sivix Posted February 26, 2021 Posted February 26, 2021 (edited) Hello everyone! You need to run an orange from battery power. I achieved by lowering the frequency of the current to 160mA. But I can't turn off the GPU. since I don't need it and ethernet. uname -a Linux orangepione 5.9.14-sunxi #20.11.3 SMP Fri Dec 11 20:31:12 CET 2020 armv7l GNU/Linux root@orangepione:~# I installed the h3consumption utility, but it does not output information to the console. root@orangepione:~# h3consumption -p root@orangepione:~# from teams root@orangepione:~# h3consumption -g and root@orangepione:~# h3consumption -g off change but no current. I think the core is very new. I don’t know which way to go, install the old kernel or look for how to disable the GPU and ETH in the new kernel. Thanks in advance! Edited February 26, 2021 by sivix
Werner Posted February 26, 2021 Posted February 26, 2021 13 minutes ago, sivix said: h3consumption This tool was designed for the stone-age legacy 3.4.y kernels which are not supported anymore. So it is obsolete. There are a few tips regarding consumption in the docs: https://docs.armbian.com/Hardware_Allwinner-H3/
hal8k Posted March 13, 2021 Posted March 13, 2021 Hello, you did not state what you lowered your clock speed to, but on my Orange Pi Zero I set the clock to 400MHz and maximum clock speed to 648MHz using conservative governor. This draws around 180-210mA and runs cool at 31C without a heat sink. For IoT you don't need GHz of processing power and 4 cores at 400MHz beats my RPi 2 in terms of both performance and power consumption. The link from Werner is excellent however and you may be able to reduce consumption more.
