1 hour ago, cw73 said:
Hello folks! What is your preferred way to receive trouble reports?
Directly you can't file a bug so forum is the right only way - but prior opening a new topic, look for similar reports and add your experiences there. All A20 boards share most of its problems. Similar for other boards ... How we deal with bugs? We are picking troubles you are mentioning on the forum and solve them if we bump into them, if we can / have time and when possible. Remember that you don't cover not a single second of our time, so you have no rights to complain or file bugs. Your support contract doesn't provide you such services https://github.com/armbian/build#support A few people can't cover bugs you can find in software that is created by several thousands of people. Some parts are maintained well, some not at all, while we blow 50 - 80 hours dealing with this every day ...
For our internal purposes we use Jira https://armbian.atlassian.net/  - to track bugs we might be working on and to save time when making a release documentation - as we just did.
Thanks for all your hints and explanations. Let me point out that I do not intend to complain in any way. It's more the opposite. I have been using Armbian privately since year without paying much attention to your development and support work. So I want to be constructive and help with the limited capabilities (both in time and skills!).
Regarding one of my issues I found back one thread in the forum https://forum.armbian.com/topic/14099-rtl8188eu-wifi-dongle/ . Now I have added a solution that has worked for me.
I stop spamming the release thread now! Thanks again!
vor 15 Stunden schrieb lanefu:
Comments like this are insulting to me and probably other devs as well.
I beg your pardon.
I didn't want to insult anybody!
  • lanefu unpinned and unfeatured this topic
On 5/10/2021 at 6:08 AM, lanefu said:
Yeah we ususlly ssh in on first boot so wouldn't see that.  But yes its only cosmetic and you could just press enter and proceed as normal
If you are particular about your system and avoiding changes you may want to freeze the kernel on your 21.02 install via armbian-config
Add jira task https://armbian.atlassian.net/browse/AR-743
Resolved via https://github.com/armbian/build/pull/2979!
