Astorek86 Posted April 9, 2021 Posted April 9, 2021 (edited) Title says it all: The Images offers by the site https://www.armbian.com/nanopineo3/ simply doesn't work on a NanoPi Neo3. I don't have a Serial-Connector to find out what's going on during the Boot-Process. I connected a Router on the Lan-Interface, and the Router never get a DHCP-Request from the Neo3. Tried multiple times, SD-Card is fine (tested). If I use an Image from a totally different Project (for Example "DietPi" which also offers a Neo3-Image), it works like a charm. Router gets DHCP-Request, I can connect using SSH (and so on), everything works. My Neo3 is working fine, Power-Supply is also good (it's made for Raspberry Pi and offers 5.1V and 3A...) Edited April 9, 2021 by Astorek86
Werner Posted April 9, 2021 Posted April 9, 2021 Moved to proper location Quote I don't have a Serial-Connector Expand You really want to pick up such a thing Make sure it can handle 1,5Mbaud Edit: Confirmed. Something is wrong. ID:0x805 N In DDR4 333MHz Bus Width=32 Col=10 Bank=4 Bank Group=2 Row=15 CS=1 Die Bus-Width=16 Size=1024MB ddrconfig:14 OUT Boot1 Release Time: May 13 2019 17:34:36, version: 2.50 ChipType = 0x11, 248 mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 emmc reinit mmc2:cmd1,20 SdmmcInit=2 1 mmc0:cmd5,20 SdmmcInit=0 0 BootCapSize=0 UserCapSize=60906MB FwPartOffset=2000 , 0 StorageInit ok = 28775 Raw SecureMode = 0 SecureInit read PBA: 0x4 SecureInit read PBA: 0x404 SecureInit read PBA: 0x804 SecureInit read PBA: 0xc04 SecureInit read PBA: 0x1004 SecureInit ret = 0, SecureMode = 0 atags_set_bootdev: ret:(0) GPT 0x337a9f0 signature is wrong recovery gpt... GPT 0x337a9f0 signature is wrong recovery gpt fail! LoadTrust Addr:0x4000 No find bl30.bin No find bl32.bin Load uboot, ReadLba = 2000 hdr 000000000337a3b0 + 0x0:0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00, Load OK, addr=0x200000, size=0xab950 RunBL31 0x40000 INFO: Preloader serial: 2 NOTICE: BL31: v1.3(debug):403e0b816 NOTICE: BL31: Built : 14:13:08, Aug 11 2020 NOTICE: BL31:Rockchip release version: v1.3 INFO: ARM GICv2 driver initialized INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 1 INFO: plat_rockchip_pmu_init: pd status 0xe INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0x200000 INFO: SPSR = 0x3c9 U-Boot 2020.10-armbian (Mar 08 2021 - 20:04:15 +0100) Model: FriendlyElec NanoPi R2S DRAM: 1022 MiB PMIC: RK8050 (on=0x40, off=0x00) MMC: mmc@ff500000: 1 Loading Environment from MMC... MMC Device 0 not found *** Warning - No MMC card found, using default environment In: serial@ff130000 Out: serial@ff130000 Err: serial@ff130000 Model: FriendlyElec NanoPi R2S Net: eth0: ethernet@ff540000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device Scanning mmc 1:1... Found U-Boot script /boot/boot.scr 3185 bytes read in 4 ms (777.3 KiB/s) ## Executing script at 00500000 Boot script loaded from mmc 1 178 bytes read in 4 ms (43 KiB/s) 13100233 bytes read in 582 ms (21.5 MiB/s) 28582400 bytes read in 1242 ms (21.9 MiB/s) 65424 bytes read in 10 ms (6.2 MiB/s) 2698 bytes read in 7 ms (376 KiB/s) Applying kernel provided DT fixup script (rockchip-fixup.scr) ## Executing script at 09000000 Moving Image from 0x2080000 to 0x2200000, end=3de0000 ## Loading init Ramdisk from Legacy Image at 06000000 ... Image Name: uInitrd Image Type: AArch64 Linux RAMDisk Image (gzip compressed) Data Size: 13100169 Bytes = 12.5 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 01f00000 Booting using the fdt blob at 0x1f00000 Loading Ramdisk to 3d2af000, end 3df2d489 ... OK Loading Device Tree to 000000003d236000, end 000000003d2aefff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Linux version 5.10.21-rockchip64 (root@hirsute) (aarch64-linux-gnu-gcc (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 8.3.0, GNU ld (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36)) 2.32.0.20190321) #21.02.3 SMP PREEMPT Mon Mar 8 01:05:08 UTC 2021 [ 0.000000] Machine model: FriendlyElec NanoPi NEO3 [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 128 MiB at 0x0000000035000000 [ 0.000000] NUMA: No NUMA configuration found [ 0.000000] NUMA: Faking a node at [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] NUMA: NODE_DATA [mem 0x3fdb9100-0x3fdbafff] [ 0.000000] Zone ranges: [ 0.000000] DMA [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] DMA32 empty [ 0.000000] Normal empty [ 0.000000] Movable zone start for each node [ 0.000000] Early memory node ranges [ 0.000000] node 0: [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] Initmem setup node 0 [mem 0x0000000000200000-0x000000003fffffff] [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.0 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: MIGRATE_INFO_TYPE not supported. [ 0.000000] psci: SMC Calling Convention v1.0 [ 0.000000] percpu: Embedded 32 pages/cpu s94040 r8192 d28840 u131072 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: detected: ARM erratum 845719 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 257544 [ 0.000000] Policy zone: DMA [ 0.000000] Kernel command line: root=UUID=57832f0c-c9e3-4250-8e0f-e3cfa21b3745 rootwait rootfstype=ext4 console=ttyS2,1500000 consoleblank=0 loglevel=7 ubootpart=3a5cdcbc-01 usb-storage.quirks= cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1 [ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear) [ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear) [ 0.000000] mem auto-init: stack:off, heap alloc:on, heap free:off [ 0.000000] Memory: 853268K/1046528K available (14848K kernel code, 2632K rwdata, 5972K rodata, 4352K init, 580K bss, 62188K reserved, 131072K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU event tracing is enabled. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4. [ 0.000000] Trampoline variant of Tasks RCU enabled. [ 0.000000] Rude variant of Tasks RCU enabled. [ 0.000000] Tracing variant of Tasks RCU enabled. [ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GIC: Using split EOI/Deactivate mode [ 0.000000] random: get_random_bytes called from start_kernel+0x698/0x850 with crng_init=0 [ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x588fe9dc0, max_idle_ns: 440795202592 ns [ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns [ 0.001066] Console: colour dummy device 80x25 [ 0.001253] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=96000) [ 0.001285] pid_max: default: 32768 minimum: 301 [ 0.001491] LSM: Security Framework initializing [ 0.001563] Yama: becoming mindful. [ 0.001753] AppArmor: AppArmor initialized [ 0.001865] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.001896] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear) [ 0.005808] rcu: Hierarchical SRCU implementation. [ 0.009394] EFI services will not be available. [ 0.010239] smp: Bringing up secondary CPUs ... [ 0.011437] Detected VIPT I-cache on CPU1 [ 0.011555] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.012989] Detected VIPT I-cache on CPU2 [ 0.013090] CPU2: Booted secondary processor 0x0000000002 [0x410fd034] [ 0.014515] Detected VIPT I-cache on CPU3 [ 0.014607] CPU3: Booted secondary processor 0x0000000003 [0x410fd034] [ 0.014863] smp: Brought up 1 node, 4 CPUs [ 0.014914] SMP: Total of 4 processors activated. [ 0.014935] CPU features: detected: 32-bit EL0 Support [ 0.014953] CPU features: detected: CRC32 instructions [ 0.014971] CPU features: detected: 32-bit EL1 Support [ 0.036393] CPU: All CPU(s) started at EL2 [ 0.036493] alternatives: patching kernel code [ 0.039227] devtmpfs: initialized [ 0.063837] Registered cp15_barrier emulation handler [ 0.063878] Registered setend emulation handler [ 0.064379] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.064444] futex hash table entries: 1024 (order: 4, 65536 bytes, linear) [ 0.071429] pinctrl core: initialized pinctrl subsystem [ 0.072801] DMI not present or invalid. [ 0.073878] NET: Registered protocol family 16 [ 0.078015] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations [ 0.078994] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations [ 0.080902] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations [ 0.081132] audit: initializing netlink subsys (disabled) [ 0.081710] audit: type=2000 audit(0.080:1): state=initialized audit_enabled=0 res=1 [ 0.083427] thermal_sys: Registered thermal governor 'fair_share' [ 0.083443] thermal_sys: Registered thermal governor 'bang_bang' [ 0.083461] thermal_sys: Registered thermal governor 'step_wise' [ 0.083477] thermal_sys: Registered thermal governor 'user_space' [ 0.084093] cpuidle: using governor menu [ 0.084705] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.084921] ASID allocator initialised with 65536 entries [ 0.087364] Serial: AMBA PL011 UART driver [ 0.153712] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages [ 0.153751] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages [ 0.153769] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.153790] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages [ 0.161160] cryptd: max_cpu_qlen set to 1000 [ 0.240972] raid6: neonx8 gen() 1052 MB/s [ 0.309105] raid6: neonx8 xor() 780 MB/s [ 0.377278] raid6: neonx4 gen() 1076 MB/s [ 0.445417] raid6: neonx4 xor() 772 MB/s [ 0.513572] raid6: neonx2 gen() 1013 MB/s [ 0.581708] raid6: neonx2 xor() 711 MB/s [ 0.649857] raid6: neonx1 gen() 884 MB/s [ 0.718014] raid6: neonx1 xor() 610 MB/s [ 0.786170] raid6: int64x8 gen() 745 MB/s [ 0.854385] raid6: int64x8 xor() 392 MB/s [ 0.922490] raid6: int64x4 gen() 828 MB/s [ 0.990646] raid6: int64x4 xor() 424 MB/s [ 1.058791] raid6: int64x2 gen() 707 MB/s [ 1.126947] raid6: int64x2 xor() 374 MB/s [ 1.195106] raid6: int64x1 gen() 526 MB/s [ 1.263244] raid6: int64x1 xor() 274 MB/s [ 1.263263] raid6: using algorithm neonx4 gen() 1076 MB/s [ 1.263274] raid6: .... xor() 772 MB/s, rmw enabled [ 1.263289] raid6: using neon recovery algorithm [ 1.269077] iommu: Default domain type: Translated [ 1.270782] vgaarb: loaded [ 1.271792] SCSI subsystem initialized [ 1.272944] usbcore: registered new interface driver usbfs [ 1.273031] usbcore: registered new interface driver hub [ 1.273113] usbcore: registered new device driver usb [ 1.273918] pps_core: LinuxPPS API ver. 1 registered [ 1.273933] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 1.273973] PTP clock support registered [ 1.274292] EDAC MC: Ver: 3.0.0 [ 1.276760] NetLabel: Initializing [ 1.276788] NetLabel: domain hash size = 128 [ 1.276801] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO [ 1.276956] NetLabel: unlabeled traffic allowed by default [ 1.277934] clocksource: Switched to clocksource arch_sys_counter [ 1.525414] VFS: Disk quotas dquot_6.6.0 [ 1.525569] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes) [ 1.527539] AppArmor: AppArmor Filesystem Enabled [ 1.542904] NET: Registered protocol family 2 [ 1.544451] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear) [ 1.544543] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear) [ 1.544847] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear) [ 1.545051] TCP: Hash tables configured (established 8192 bind 8192) [ 1.545364] UDP hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.545441] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear) [ 1.545853] NET: Registered protocol family 1 [ 1.546023] NET: Registered protocol family 44 [ 1.546051] PCI: CLS 0 bytes, default 64 [ 1.546474] Trying to unpack rootfs image as initramfs... [ 2.929305] Freeing initrd memory: 12792K [ 2.931460] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available [ 2.932336] kvm [1]: IPA Size Limit: 40 bits [ 2.935008] kvm [1]: vgic interrupt IRQ9 [ 2.935284] kvm [1]: Hyp mode initialized successfully [ 2.950125] Initialise system trusted keyrings [ 2.950219] Key type blacklist registered [ 2.950730] workingset: timestamp_bits=44 max_order=18 bucket_order=0 [ 2.962972] zbud: loaded [ 2.966396] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 2.967983] fuse: init (API version 7.32) [ 2.970556] integrity: Platform Keyring initialized [ 3.041416] xor: measuring software checksum speed [ 3.049578] 8regs : 1220 MB/sec [ 3.056643] 32regs : 1402 MB/sec [ 3.065680] arm64_neon : 1093 MB/sec [ 3.065696] xor: using function: 32regs (1402 MB/sec) [ 3.065729] Key type asymmetric registered [ 3.065745] Asymmetric key parser 'x509' registered [ 3.065861] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247) [ 3.066210] io scheduler mq-deadline registered [ 3.066231] io scheduler kyber registered [ 3.066531] io scheduler bfq registered [ 3.073191] rockchip-u3phy ff470000.usb3-phy: vbus_drv is not assigned [ 3.076210] rockchip-u3phy ff470000.usb3-phy: Rockchip u3phy initialized successfully [ 3.093223] dma-pl330 ff1f0000.dmac: Loaded driver for PL330 DMAC-241330 [ 3.093258] dma-pl330 ff1f0000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-20 Num_Events-16 [ 3.099674] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled [ 3.105545] ff120000.serial: ttyS1 at MMIO 0xff120000 (irq = 22, base_baud = 1500000) is a 16550A [ 3.107872] ff130000.serial: ttyS2 at MMIO 0xff130000 (irq = 23, base_baud = 1500000) is a 16550A [ 3.195453] printk: console [ttyS2] enabled [ 3.197889] Serial: AMBA driver [ 3.224233] loop: module loaded [ 3.231840] libphy: Fixed MDIO Bus: probed [ 3.233299] tun: Universal TUN/TAP device driver, 1.6 [ 3.235333] thunder_xcv, ver 1.0 [ 3.235715] thunder_bgx, ver 1.0 [ 3.236101] nicpf, ver 1.0 [ 3.237349] e1000e: Intel(R) PRO/1000 Network Driver [ 3.237796] e1000e: Copyright(c) 1999 - 2015 Intel Corporation. [ 3.238480] igb: Intel(R) Gigabit Ethernet Network Driver [ 3.238971] igb: Copyright (c) 2007-2014 Intel Corporation. [ 3.239534] igbvf: Intel(R) Gigabit Virtual Function Network Driver [ 3.240093] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 3.240963] sky2: driver version 1.30 [ 3.242282] VFIO - User Level meta-driver version: 0.3 [ 3.251963] dwc2 ff580000.usb: supply vusb_d not found, using dummy regulator [ 3.252875] dwc2 ff580000.usb: supply vusb_a not found, using dummy regulator [ 3.382058] dwc2 ff580000.usb: EPs: 10, dedicated fifos, 972 entries in SPRAM [ 3.383291] dwc2 ff580000.usb: DWC OTG Controller [ 3.383760] dwc2 ff580000.usb: new USB bus registered, assigned bus number 1 [ 3.384446] dwc2 ff580000.usb: irq 40, io mem 0xff580000 [ 3.385274] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.386073] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.386720] usb usb1: Product: DWC OTG Controller [ 3.387146] usb usb1: Manufacturer: Linux 5.10.21-rockchip64 dwc2_hsotg [ 3.387739] usb usb1: SerialNumber: ff580000.usb [ 3.389278] hub 1-0:1.0: USB hub found [ 3.389684] hub 1-0:1.0: 1 port detected [ 3.392873] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 3.393517] ehci-pci: EHCI PCI platform driver [ 3.394049] ehci-platform: EHCI generic platform driver [ 3.397350] ehci-platform ff5c0000.usb: EHCI Host Controller [ 3.397895] ehci-platform ff5c0000.usb: new USB bus registered, assigned bus number 2 [ 3.398970] ehci-platform ff5c0000.usb: irq 41, io mem 0xff5c0000 [ 3.413957] ehci-platform ff5c0000.usb: USB 2.0 started, EHCI 1.00 [ 3.414984] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.415731] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.416375] usb usb2: Product: EHCI Host Controller [ 3.416821] usb usb2: Manufacturer: Linux 5.10.21-rockchip64 ehci_hcd [ 3.417396] usb usb2: SerialNumber: ff5c0000.usb [ 3.418912] hub 2-0:1.0: USB hub found [ 3.419322] hub 2-0:1.0: 1 port detected [ 3.420712] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver [ 3.421314] ohci-pci: OHCI PCI platform driver [ 3.421822] ohci-platform: OHCI generic platform driver [ 3.423130] ohci-platform ff5d0000.usb: Generic Platform OHCI controller [ 3.423766] ohci-platform ff5d0000.usb: new USB bus registered, assigned bus number 3 [ 3.424723] ohci-platform ff5d0000.usb: irq 42, io mem 0xff5d0000 [ 3.486306] usb usb3: New USB device found, idVendor=1d6b, idProduct=0001, bcdDevice= 5.10 [ 3.487051] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.487695] usb usb3: Product: Generic Platform OHCI controller [ 3.488228] usb usb3: Manufacturer: Linux 5.10.21-rockchip64 ohci_hcd [ 3.488806] usb usb3: SerialNumber: ff5d0000.usb [ 3.490292] hub 3-0:1.0: USB hub found [ 3.490709] hub 3-0:1.0: 1 port detected [ 3.493196] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.493734] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 4 [ 3.495064] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220fe64 hci version 0x110 quirks 0x0000000002010010 [ 3.496028] xhci-hcd xhci-hcd.0.auto: irq 49, io mem 0xff600000 [ 3.497390] usb usb4: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10 [ 3.498238] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.498885] usb usb4: Product: xHCI Host Controller [ 3.499330] usb usb4: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 3.499908] usb usb4: SerialNumber: xhci-hcd.0.auto [ 3.501408] hub 4-0:1.0: USB hub found [ 3.501816] hub 4-0:1.0: 1 port detected [ 3.502869] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 3.503390] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 5 [ 3.504121] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed [ 3.504838] usb usb5: We don't know the algorithms for LPM for this host, disabling LPM. [ 3.505820] usb usb5: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10 [ 3.506644] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 3.507289] usb usb5: Product: xHCI Host Controller [ 3.507732] usb usb5: Manufacturer: Linux 5.10.21-rockchip64 xhci-hcd [ 3.508310] usb usb5: SerialNumber: xhci-hcd.0.auto [ 3.509790] hub 5-0:1.0: USB hub found [ 3.510237] hub 5-0:1.0: 1 port detected [ 3.511591] usbcore: registered new interface driver usb-storage [ 3.514995] mousedev: PS/2 mouse device common for all mice [ 3.517209] i2c /dev entries driver [ 3.526032] rk808 1-0018: chip id: 0x8050 [ 3.535210] rk808-regulator rk808-regulator: there is no dvs0 gpio [ 3.535823] rk808-regulator rk808-regulator: there is no dvs1 gpio [ 3.536381] rk808-regulator rk808-regulator: max buck steps per change: 8 [ 3.539866] vdd_logic: supplied by vcc_sys [ 3.542222] vdd_arm: supplied by vcc_sys [ 3.543180] vcc_ddr: supplied by vcc_sys [ 3.545084] vcc_io: supplied by vcc_sys [ 3.549336] vcc_18: supplied by vcc_io [ 3.553655] vcc18_emmc: supplied by vcc_io [ 3.558008] vdd_10: supplied by vcc_io [ 3.570133] rk808-rtc rk808-rtc: registered as rtc0 [ 3.572390] rk808-rtc rk808-rtc: setting system clock to 2016-01-21T08:50:10 UTC (1453366210) [ 3.575598] input: rk805 pwrkey as /devices/platform/ff160000.i2c/i2c-1/1-0018/rk805-pwrkey/input/input0 [ 3.579984] rockchip-thermal ff250000.tsadc: Missing tshut mode property, using default (cru) [ 3.580768] rockchip-thermal ff250000.tsadc: Missing tshut-polarity property, using default (low) [ 3.583958] dw_wdt ff1a0000.watchdog: No valid TOPs array specified [ 3.587656] sdhci: Secure Digital Host Controller Interface driver [ 3.588229] sdhci: Copyright(c) Pierre Ossman [ 3.588680] Synopsys Designware Multimedia Card Interface Driver [ 3.590565] sdhci-pltfm: SDHCI platform and OF driver helper [ 3.591358] dwmmc_rockchip ff500000.mmc: IDMAC supports 32-bit address mode. [ 3.592041] dwmmc_rockchip ff500000.mmc: Using internal DMA controller. [ 3.592639] dwmmc_rockchip ff500000.mmc: Version ID is 270a [ 3.593272] dwmmc_rockchip ff500000.mmc: DW MMC controller at irq 38,32 bit host data width,256 deep fifo [ 3.594257] ledtrig-cpu: registered to indicate activity on CPUs [ 3.594740] vcc_sd: supplied by vcc_io [ 3.596131] hid: raw HID events driver (C) Jiri Kosina [ 3.596843] usbcore: registered new interface driver usbhid [ 3.597344] usbhid: USB HID core driver [ 3.604384] drop_monitor: Initializing network drop monitor service [ 3.606590] NET: Registered protocol family 10 [ 3.614213] mmc_host mmc0: Bus speed (slot 0) = 400000Hz (slot req 400000Hz, actual 400000HZ div = 0) [ 3.680415] Segment Routing with IPv6 [ 3.680941] NET: Registered protocol family 17 [ 3.681617] 8021q: 802.1Q VLAN Support v1.8 [ 3.682160] Key type dns_resolver registered [ 3.683634] registered taskstats version 1 [ 3.684036] Loading compiled-in X.509 certificates [ 3.690705] Loaded X.509 cert 'Build time autogenerated kernel key: 98b5fbd0004968eadd44123544af94c22f57c8e4' [ 3.697525] zswap: loaded using pool zstd/z3fold [ 3.698904] Key type ._fscrypt registered [ 3.699285] Key type .fscrypt registered [ 3.699641] Key type fscrypt-provisioning registered [ 3.704835] Btrfs loaded, crc32c=crc32c-generic [ 3.738874] Key type encrypted registered [ 3.739299] AppArmor: AppArmor sha1 policy hashing enabled [ 3.800876] friendlyelec-board board: Serial : c710169d01d3bb73 [ 3.807334] rk3328-dmc-freq dmc: current ATF version 0x101 [ 3.815095] input: gpio-keys as /devices/platform/gpio-keys/input/input1 [ 3.816757] of_cfs_init [ 3.817067] of_cfs_init: OK [ 3.819752] dw-apb-uart ff130000.serial: forbid DMA for kernel console [ 3.824733] Freeing unused kernel memory: 4352K [ 3.825357] Run /init as init process Loading, please wait... Starting version 241 [ 4.221289] dwmmc_rockchip ff500000.mmc: Busy; trying anyway [ 4.699995] gpio-syscon ff100000.syscon:grf-gpio: can't read the data register offset! [ 4.721870] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 4.756472] random: fast init done [ 4.759771] mmc0: error -110 whilst initialising SD card [ 4.807001] rk_gmac-dwmac ff540000.ethernet: IRQ eth_wake_irq not found [ 4.807631] rk_gmac-dwmac ff540000.ethernet: IRQ eth_lpi not found [ 4.808522] rk_gmac-dwmac ff540000.ethernet: PTP uses main clock [ 4.814105] rk_gmac-dwmac ff540000.ethernet: clock input or output? (input). [ 4.814780] rk_gmac-dwmac ff540000.ethernet: TX delay(0x24). [ 4.815300] rk_gmac-dwmac ff540000.ethernet: RX delay(0x18). [ 4.815840] rk_gmac-dwmac ff540000.ethernet: integrated PHY? (no). [ 4.816559] rk_gmac-dwmac ff540000.ethernet: cannot get clock clk_mac_speed [ 4.818368] rk_gmac-dwmac ff540000.ethernet: clock input from PHY [ 4.824657] rk_gmac-dwmac ff540000.ethernet: init for RGMII [ 4.825869] rk_gmac-dwmac ff540000.ethernet: User ID: 0x10, Synopsys ID: 0x35 [ 4.827645] rk_gmac-dwmac ff540000.ethernet: DWMAC1000 [ 4.828152] rk_gmac-dwmac ff540000.ethernet: DMA HW capability register supported [ 4.829713] rk_gmac-dwmac ff540000.ethernet: RX Checksum Offload Engine supported [ 4.830576] rk_gmac-dwmac ff540000.ethernet: COE Type 2 [ 4.831984] rk_gmac-dwmac ff540000.ethernet: TX Checksum insertion supported [ 4.832650] rk_gmac-dwmac ff540000.ethernet: Wake-Up On Lan supported [ 4.837689] rk_gmac-dwmac ff540000.ethernet: Normal descriptors [ 4.838354] rk_gmac-dwmac ff540000.ethernet: Ring mode enabled [ 4.838905] rk_gmac-dwmac ff540000.ethernet: Enable RX Mitigation via HW Watchdog Timer [ 4.898148] libphy: stmmac: probed Begin: Loading essential drivers ... done. Begin: Running /scripts/init-premount ... done. Begin: Mounting root file system ... Begin: Running /scripts/local-top ... done. Begin: Running /scripts/local-premount ... Scanning for Btrfs filesystems done. Begin: Waiting for root file system ... [ 5.274017] dwmmc_rockchip ff500000.mmc: Busy; trying anyway [ 5.774568] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 5.789299] mmc_host mmc0: Bus speed (slot 0) = 300000Hz (slot req 300000Hz, actual 300000HZ div = 0) Begin: Running /scripts/local-block ... done. [ 6.332919] dwmmc_rockchip ff500000.mmc: Busy; trying anyway [ 6.833462] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 6.848193] mmc_host mmc0: Bus speed (slot 0) = 200000Hz (slot req 200000Hz, actual 200000HZ div = 0) Begin: Running /scripts/local-block ... done. [ 7.398445] dwmmc_rockchip ff500000.mmc: Busy; trying anyway [ 7.898989] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) [ 7.913729] mmc_host mmc0: Bus speed (slot 0) = 100000Hz (slot req 100000Hz, actual 100000HZ div = 0) Begin: Running /scripts/local-block ... done. [ 8.484045] dwmmc_rockchip ff500000.mmc: Busy; trying anyway [ 8.984617] mmc_host mmc0: Timeout sending command (cmd 0x202000 arg 0x0 status 0x80202000) Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. Begin: Running /scripts/local-block ... done. done. Gave up waiting for root file system device. Common problems: - Boot args (cat /proc/cmdline) - Check rootdelay= (did the system wait long enough?) - Missing modules (cat /proc/modules; ls /dev) ALERT! UUID=57832f0c-c9e3-4250-8e0f-e3cfa21b3745 does not exist. Dropping to a shell! (initramfs) [ 35.810034] vcc_sd: disabling Will retry with image built from master. Stay tuned
Werner Posted April 9, 2021 Posted April 9, 2021 Aight, weird situation. I tried both buster and focal and both failed for me. - tried different sd cards - tried different device and OS for flashing - tried a freshly built image from master too for Rich both images work fine. My board is perfectly fine since it boots from a known to work older sd.
Astorek86 Posted April 10, 2021 Author Posted April 10, 2021 Thanks for investigating and helping! :) Serial-to-USB-Connector is ordered^^. Okay, I think I figured something out. I tried some of the "Archived Version" of Armbian ( https://armbian.systemonachip.net/archive/nanopineo3/archive ): It seems that 21.02.1 (Buster) didn't run either on my Neo3; same behavior (like, Router never get a DHCP-Request). Armbian 20.11 (Buster) works! With that Image, I could finally use the NanoPi. * First thing I did: "apt-get update; apt-get dist-upgrade". Everything runs fine, than "reboot"... And nothing works anymore. Router never get a DHCP-Request after Rebooting. * After that, I flashed my SD-Card again (20.11 Buster), I changed a Package to hold ("apt-mark hold linux-image-current-rockchip64"), and update again. Update runs through, I could reboot the NanoPi and... everything still works! So, if I connect to the NanoPi using SSH, it shows: "Welcome to Armbian 21.02.3 Buster with Linux 5.8.17-rockchip64" Whatever the Problem is, it has something to do with the Package "linux-image-current-rockchip64"... SD Card is a SanDisk Extreme, 64 GB, U3 A2. I tried another SD-Card (SanDisk Ultra, 16 GB, Class 10), same result. After my Serial-to-USB-Connector arrived, I'll try to find out what's going on...
Astorek86 Posted April 10, 2021 Author Posted April 10, 2021 Double post, but I think it's okay this Time^^. It seems that it has something to do about Scaling the CPU-Frequency. There's another Thread in the Forum which describes a similar problem: So, what I did was: - open /etc/sysfs.conf - write down following lines to stick the CPU-Speed at 1.2 GHz: devices/system/cpu/cpu0/cpufreq/scaling_governor = userspace devices/system/cpu/cpu0/cpufreq/scaling_setspeed = 1200000 After that, I could install the newest "linux-image-current-rockchip64"-Package and Neo3 survives a Reboot. After the Reboot, I modified the sysfs.conf again to delete the two lines, reboot again and... No Connection. My Router doesn't get a DHCP-Request after the last Reboot. Tested it with both SD-Card (as described a post earlier) with two Neo3 (Yep, I had a second Neo3 but didn't used before), both doing exactly the same. Running on newest Rockchip-Kernel without modifing sysfs.conf = no boot. With modified sysfs.conf = running. For me, the Problem is solved. I need to modify /etc/sysfs.conf as described, and I can finally work with those Devices^^. EDIT: Nah, it was too easy, the Problem is just partially solved. I still can't use the newest Image provided on the Site, even if I change sysfs.conf on the SD-Card before the first boot. But I can use the archived Version 20.11 Buster, change sysfs.conf, upgrade to the newest Version using apt... And than, it runs and survives multiple reboots and shutdowns^^. Tested with both SD-Cards and both Neo3. Really weird...
