[Invalid] - Bqeel - Only 2GB of Ram instead of 4GB
Kitem
Armbianmonitor:
Hi All,
This is my first post.
First of all let me thanks all the ones are hard working on this project.
I have installed Armbian Buster on my Bqeel Y4 Max (S905x2) and I have managed to fix some little issues although the wired connection still not work.
However, at the moment I'm trying to understand why Armbian sees only 2GB of RAM instead of 4GB.
I have search google and the forum and, if I'm not wrong, the issue is in the boot file.
I noticed someone has fixed it by installing the latest Ubuntu image, but I'm wondering if would be possible to get the 4GB without re-installing everything.
I have included my armbianmonitor -u
I hope you can help me :)
Link to comment
Share on other sites
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
Link to comment
