[solved] BananaPi Pro: boot directory still on sd card after moving to sata ssd
Go to solution Solved by jofland,
System: armbian, BananaPi Pro, sd card, sata ssd, usb hdd
I manually moved my existing armbian system from sd card to a sata ssd. Then I changed the rootdev in armbianEnv.txt to the ssd´s UUID.
After reboot I thought everything was ok. Then after a system update I figured out that the kernel version differs from the installed kernel modules.
I think the new kernel and the modules are installed in /boot at /dev/sda whereas the kernel still boots from /dev/mmcblk0p1.
How can I fix this?
Here some information:
root@pi-nas:/mnt/boot# lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINT
sda           8:0    0   477G  0 disk
├─sda1        8:1    0  29,3G  0 part /
├─sda2        8:2    0 445,7G  0 part /home
└─sda3        8:3    0     2G  0 part [SWAP]
sdb           8:16   0   1,6T  0 disk
└─sdb1        8:17   0   1,6T  0 part /share
mmcblk0     179:0    0   7,3G  0 disk
└─mmcblk0p1 179:1    0   1,3G  0 part
root@pi-nas:~# mount /dev/mmcblk0p1 /mnt/
root@pi-nas:~# ls /mnt/boot/
armbianEnv.txt                  boot.scr                 overlay-user
armbian_first_run.txt.template  boot.scr.bak             System.map-5.4.20-sunxi
boot.bmp                        config-5.4.20-sunxi      uInitrd
boot.cmd                        dtb                      uInitrd-5.4.20-sunxi
boot.cmd.bak                    dtb-5.4.20-sunxi         vmlinuz-5.4.20-sunxi
boot-desktop.png                initrd.img-5.4.20-sunxi  zImage
root@pi-nas:~# cat /mnt/boot/armbianEnv.txt
verbosity=1
logo=disabled
console=both
disp_mode=1920x1080p60
overlay_prefix=sun7i-a20
rootdev=UUID=f631e37b-e2e5-431a-aab0-cbbcc544528f
rootfstype=ext4
root@pi-nas:~# blkid /dev/sda1
/dev/sda1: UUID="f631e37b-e2e5-431a-aab0-cbbcc544528f" TYPE="ext4" PARTUUID="000a6123-01"
root@pi-nas:~# ls /boot
boot.scr              dtb-5.10.34-sunxi         uInitrd                zImage
config-5.10.34-sunxi  initrd.img-5.10.34-sunxi  uInitrd-5.10.34-sunxi
dtb                   System.map-5.10.34-sunxi  vmlinuz-5.10.34-sunxi
root@pi-nas:~# uname -a
Linux pi-nas 5.4.20-sunxi #20.02.1 SMP Mon Feb 17 02:09:41 CET 2020 armv7l GNU/Linux
root@pi-nas:~# ls /lib/modules/
5.10.34-sunxi
7 hours ago, jofland said:
manually moved
did nand-sata-install not work for you?
vor 16 Stunden schrieb Werner:
I didn't know about that before I did the manual way. I think I can't use it anymore because the target partition will be wiped.
So I am looking for a manual way to fix my problem. Any ideas?
vor 9 Stunden schrieb TRS-80:
Did you know about Recovery section of Docs?  Maybe there is something helpful in there.
Interesting docs. I didn't know.
Unfortunately I don't think anything fits for my problem except creating manual symlinks between the boot directory on sd card and ssd. But is this a solution that survives the mext kernel update?
My problem is, the boot process uses the boot directory on sd card. The system uses the one on the ssd e.g. for storing updated kernel files.
How can I point the boot directory from sd card to ssd?
  • Solution
I solved it by my own:
I had to mount the boot directory of the sd card over the boot directory of the ssd. Therefore I added two lines to the /etc/fstab of my ssd:
/dev/mmcblk0p1  /media/mmcboot           ext4    defaults,noatime,nodiratime,commit=600,errors=remount-ro,x-gvfs-hide    0       1
/media/mmcboot/boot  /boot           none    bind
(had to create the directory /media/mmcboot first)
Now the kernel loads in the right version. Kernel update works. Topic can be closed.
Some information:
Linux pi-nas 5.10.34-sunxi #21.05.1 SMP Thu May 6 20:13:21 UTC 2021 armv7l GNU/Linux
armbianEnv.txt                  boot.scr.bak              System.map-5.10.34-sunxi
armbian_first_run.txt.template  config-5.10.34-sunxi      uInitrd
boot.bmp                        dtb                       uInitrd-5.10.34-sunxi
boot.cmd                        dtb-5.10.34-sunxi         vmlinuz-5.10.34-sunxi
boot.cmd.bak                    dtb-5.4.20-sunxi          zImage
boot-desktop.png                initrd.img-5.10.34-sunxi
root@pi-nas:~# mount | grep boot
/dev/mmcblk0p1 on /media/mmcboot type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600,x-gvfs-hide)
/dev/mmcblk0p1 on /boot type ext4 (rw,noatime,nodiratime,errors=remount-ro,commit=600)
  • jofland changed the title to [solved] BananaPi Pro: boot directory still on sd card after moving to sata ssd
