How to build latest ffmpeg with hardware acceleration
I'm running the latest XU4 focal and ffmpeg doesn't support the latest H265+ codec even though I'm only doing a copy (no transcoding). Is there a way to build latest ffmpeg without losing hardware accelration?
[rtsp @ 0x556f60] [warning] Multi-layer HEVC coding is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented.
BOARD=odroidxu4
BOARD_NAME="Odroid XU4"
BOARDFAMILY=odroidxu4
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=428a20876-dirty
DISTRIBUTION_CODENAME=focal
DISTRIBUTION_STATUS=supported
VERSION=21.05.6
LINUXFAMILY=odroidxu4
ARCH=arm
IMAGE_TYPE=stable
BOARD_TYPE=conf
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
BRANCH=current
Moved to Common issues / peer to peer technical support since 3rd party software issue.
