Atreyo tech Posted October 5, 2021 Posted October 5, 2021 Hello, I am using Allwinner A64 processor for my use case. In that, I want to flash my custom os into emmc memory which is alredy worked in SD card. Currenlty we go thorugh below link: https://wiki.pine64.org/index.php/NOOB#Instructions_to_Flashing_eMMC_Modules we follow "xzcat imagename.img.xz | sudo dd of=/dev/mmcblk1 bs=1M status=progress conv=fsync" this command but we got input/out error while reading memory. Please check below screenshot.
Werner Posted October 5, 2021 Posted October 5, 2021 Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs). With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported. Your report is invalid for one or more of the following reasons (non-exhaustive list): it is for an unsupported board or image (CSC/EOS/WIP/edge) it is for software that is not supported (such as userspace modules installed on top of the core operating system) it has been logged in the wrong forum (for example requests for help that are not actual bug reports) it lacks requested data (armbianmonitor output) it could have been easily solved by a quick search and/or reading documentation Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
