[Invalid] - Rock64 Focal /usr/lib/xorg/Xorg segmentation fault
Updated Armbian on Rock64 today, then lightdm stopped working.  After peeling the layers it appears to come down to Xorg giving signal 11 "Segmentation fault"
/usr/sbin/lightdm --debug
            [+0.12s] DEBUG: XServer 0: Launching X Server
            [+0.12s] DEBUG: Launching process 2575: /usr/bin/X -core :0 -seat seat0 -auth /var/run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
            [+0.12s] DEBUG: XServer 0: Waiting for ready signal from X server :0
            [+0.12s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
            [+0.13s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
            [+0.15s] DEBUG: Process 2575 terminated with signal 11
root@rock:~# whoami
            root
cd /usr/lib/xorg
file Xorg
            Xorg: ELF 64-bit LSB shared object, ARM aarch64, version 1 (SYSV), dynamically linked, interpreter /lib/ld-linux-aarch64.so.1, BuildID[sha1]=f42da704ae0d3ae4698db2960364a313b08e111f, for GNU/Linux 3.7.0, stripped
root@rock:/usr/lib/xorg# Xorg
            Segmentation fault
root@rock:/usr/lib/xorg$ sudo Xorg --configure
            Segmentation fault
uname -a
5.10.63-rockchip64 #21.08.2 SMP PREEMPT Wed Sep 8 10:57:23 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
apt-cache show xserver-xorg | grep Version
            Version: 1:7.7+22
            Version: 1:7.7+19ubuntu14
Is there a way to fix this without downgrading?
Your issue report is not a valid bug report per the Armbian bug reporting instructions (https://www.armbian.com/bugs).  With limited resources the Armbian project is only able to spend time on issues where all the requested information has been provided and for only the boards/images/software that are supported.  Your report is invalid for one or more of the following reasons (non-exhaustive list):
  • it is for an unsupported board or image (CSC/EOS/WIP/edge)
  • it is for software that is not supported (such as userspace modules installed on top of the core operating system)
  • it has been logged in the wrong forum (for example requests for help that are not actual bug reports)
  • it lacks requested data (armbianmonitor output)
  • it could have been easily solved by a quick search and/or reading documentation
Please review what you have submitted and the bug logging instructions (https://www.armbian.com/bugs) and either add the required information or open a new topic in the correct forum (such as Common issues / peer to peer technical support or General chit chat)
