jongerenchaos 0 Posted August 29, 2016 Share Posted August 29, 2016 Is there a way to add the MXQ box to the armbian supported OS's with nand support? This is a similiar device as the S805 ODROID device and the difference is only that this device has also a nand storage on it. Link to post Share on other sites
balbes150 876 Posted September 6, 2016 Share Posted September 6, 2016 Have not tested the version of the image to run from removable media to S805. Are you interested ? 1 Link to post Share on other sites
bellad 2 Posted September 8, 2016 Share Posted September 8, 2016 hello balbes150 , i'm interested try removable media to s805 , my project : put camera usb ( uvccapture ) with zoneminder , it's possible with your releases ? and , if this correct to install on Nand thank Link to post Share on other sites
balbes150 876 Posted September 8, 2016 Share Posted September 8, 2016 Hi I have already successfully tried to use zoneminder on NAS with ARMv5. I think s805 is possible to use zoneminder. Soon I should receive a sample TV box with S805 chip, then I'll be able to check it out. Armbian install it in internal memory. In manual mode it works. Need some time to test automatic procedures for installing to the internal memory. Link to post Share on other sites
bellad 2 Posted September 9, 2016 Share Posted September 9, 2016 hi ,thank you balbes150 for your work , I'll wait your Link to post Share on other sites
bellad 2 Posted September 9, 2016 Share Posted September 9, 2016 i've try more ditri on the mxq box tv , the " Armbian_5.14_Odroidc1_Debian_jessie_3.10.102 " no start by sd card but " AlexELEC-S805.MXQ_V31.arm-1.0.6-20160515.img " start on sd card howto make sdcard armbian system with exemple alexelec ? thank Link to post Share on other sites
balbes150 876 Posted September 9, 2016 Share Posted September 9, 2016 With a multi-boot system from Alex without making significant changes to the way that Linux will not work. You can try to use a universal multiboot. If you collect the correct script (not difficult), which is responsible for system start, you can try to achieve system operation. Link to post Share on other sites
bellad 2 Posted September 9, 2016 Share Posted September 9, 2016 Thank but I'm not strong enough for this Link to post Share on other sites
mdel 8 Posted September 11, 2016 Share Posted September 11, 2016 @@balbes150i also have a few s805 boxes lying around, i wouldn't mind testing your images on hem too (i think i have at least one black mxq and one beelink s85, the two have different boards). here's the current uboot env of my s85, it was most certainly modified by an openelec boot image, through a recovery update process. I don't think i have an original uboot dump, but there should be some stock firmware around so i could restore it. 1080ioutputheight=1047 1080ioutputwidth=1863 1080ioutputx=28 1080ioutputy=16 576ioutputheight=559 576ioutputwidth=699 576ioutputx=10 576ioutputy=8 720poutputheight=719 720poutputwidth=1279 720poutputx=0 720poutputy=0 baudrate=115200 bootcmd=run storeboot bootdelay=1 bootfile=boot.img bootm_low=0x00000000 bootm_size=0x80000000 bootpath=u-boot.bin bootsd=setenv bootargs ${bootargs} reboot_mode=${reboot_mode}; if test ${reboot_mode} != switch_system; then if mmcinfo; then if fatload mmc 0 ${loadaddr} kernel.img; then setenv bootargs ${bootargs} bootfromsd; bootm; fi;fi;fi; bootsize=100000 bootstart=0 cecconfig=cec0 chipname=8726m8 console=ttyS0,115200n8 cvbs_drv=0 cvbsmode=576cvbs digitaudiooutput=PCM display_bpp=24 display_color_bg=0 display_color_fg=0xffff display_color_format_index=24 display_height=1080 display_layer=osd2 display_width=1920 ethaddr=00:15:18:01:81:31 fb_addr=0x7900000 fb_height=720 fb_width=1280 firstboot=0 gatewayip=10.18.9.1 get_dt=checkhw has.accelerometer=false hdmimode=1080p50hz hostname=arm_m8 initargs=init=/init console=ttyS0,115200n8 no_console_suspend storage=2 initrd_high=60000000 ipaddr=10.18.9.97 loadaddr=0x12000000 loadaddr_logo=0x13000000 mmcargs=setenv bootargs console=${console} boardname=m8_board netmask=255.255.255.0 normalsize=400000 normalstart=1000000 outputmode=1080p50hz p0path=uImage p0size=400000 p0start=1000000 p1path=android.rootfs p1size=8000000 p1start=1400000 partnum=2 preboot=if itest ${upgrade_step} == 3; then run prepare; run storeargs; run update; fi; if itest ${upgrade_step} == 1; then defenv; setenv upgrade_step 2; saveenv;fi; run prepare;run storeargs;get_rebootmode; clear_rebootmode; echo reboot_mode=${reboot_mode};run update_key; run switch_bootmode preloaddtb=imgread dtb boot ${loadaddr} prepare=logo size ${outputmode}; video open; video clear; video dev open ${outputmode};imgread res logo ${loadaddr_logo}; unpackimg ${loadaddr_logo}; logo source ${outputmode}; bmp display ${bootup_offset}; bmp scale; recovery=echo enter recovery;if mmcinfo; then if fatload mmc 0 ${loadaddr} recovery.img; then bootm;fi;fi; if usb start 0; then if fatload usb 0 ${loadaddr} recovery.img; then bootm; fi;fi;if imgread kernel recovery ${loadaddr}; then bootm; else echo no recovery in flash; fi; sdc_burning=sdc_burn ${sdcburncfg} sdcburncfg=aml_sdc_burn.ini serverip=10.18.9.113 store=2 storeargs=setenv bootargs ${initargs} cvbsdrv=${cvbs_drv} vdaccfg=${vdac_config} logo=osd1,loaded,${fb_addr},${outputmode},full hdmimode=${hdmimode} cvbsmode=${cvbsmode} androidboot.firstboot=${firstboot} hdmitx=${cecconfig} storeboot=echo Booting...; if unifykey get usid; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;run bootsd;imgread kernel boot ${loadaddr};bootm;run recovery switch_bootmode=if test ${reboot_mode} = factory_reset; then run recovery;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = usb_burning; then run usb_burning;else if test ${wipe_data} = failed; then echo wipe_data=${wipe_data}; run recovery;else fi;fi;fi;fi testaddr=0x12400000 update=run usb_burning; if mmcinfo; then if fatexist mmc 0 ${sdcburncfg}; then run sdc_burning; else if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;run recovery;fi;else run recovery;fi; update_key=saradc open 0; if saradc get_in_range 0 0x50; then msleep 50; if saradc get_in_range 0 0x50; then echo update by key...; run update; fi;fi upgrade_step=2 usb_burning=update 1000 vdac_config=0x10 video_dev=tvout wipe_data=success there's also a "dtb load from firmware", so universal dtb could work.. i'm not quite sure why the dtb load command here ("imgread dtb boot ${loadaddr}") is different from your autoscript one ("store dtb read $dtb_loadaddr") ? and no use of dtb specific address.. Link to post Share on other sites
balbes150 876 Posted September 11, 2016 Share Posted September 11, 2016 On platforms S805 uses an older version of u-boot and organization of memory is different from s905. Therefore, the algorithms and commands to the external load will be different. I now analyze and test different options. I would be useful to see the output of "help" from Your consoles. What would determine which commands are available in all devices (something you can use). Link to post Share on other sites
mdel 8 Posted September 12, 2016 Share Posted September 12, 2016 from which system do you want the command "help" output ? here i was in android adb, i don't have serial on that box to get into uboot command and don't really know if it can be done without it. i grab the uboot environment from "strings /dev/block/env" the s85 box as an otg port, not sure if it can be used to get into uboot. Link to post Share on other sites
bellad 2 Posted September 12, 2016 Share Posted September 12, 2016 hello, i've boot with rs232 with my mxq box, i I don't know if it helps amlnf_logic_init: START amlnf_logic_init: COMPLETE get_boot_device_flag: init_ret 0 get_boot_device_flag NAND BOOT: NAND BOOT,nand_env_relocate_spec : env_relocate_spec 49 uboot env amlnf_env_read : #### set_storage_device_flag: store 1 Multi dtb tool version: v2 . Multi dtb detected, support 2 dtbs. aml_dt soc: m8b platform: m201 variant: 1G dtb 0 soc: m8b plat: m201 vari: 1G dtb 1 soc: m8b plat: m201C vari: 512M Find match dtb: 0 vpu clk_level in dts: 3 set vpu clk: 182150000Hz, readback: 182150000Hz(0x701) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 hdmi tx power init vdac open.1 = 0x1, 0x0 mode is: 4 viu chan = 1 config HPLL config HPLL done reboot_mode=charging Hit Enter key to stop autoboot -- : 1 tstc enter exit abortboot: 1 m8b_m201_1G#b Unknown command 'b' - try 'help' m8b_m201_1G#printenv aml_dt=m8b_m201_1G baudrate=115200 bootargs=init=/init console=ttyS0,115200n8 no_console_suspend storage=1 vdaccfg=0xa000 logo=osd1,loaded,0x7900000,576cvbs,full hdmimode=1080p cvbsmode=576cvbs androidboot.firstboot=0 hdmitx=cecf bootcmd=run bootfromsd; run storeboot bootdelay=1 bootfile=boot.img bootfromnand=0 bootfromsd=if test ${bootfromnand} = 1; then setenv bootfromnand 0; saveenv; exit; fi; if mmcinfo; then if fatload mmc 0 ${loadaddr} kernel.img; then setenv bootargs ${bootargs} bootfromsd; bootm; fi; fi bootm_low=0x00000000 bootm_size=0x80000000 bootpath=u-boot.bin bootsize=100000 bootstart=0 bootup_offset=0x13000240 bootup_size=0x322c8 cecconfig=cecf chipname=8726m8 console=ttyS0,115200n8 cvbsmode=576cvbs digitaudiooutput=PCM display_bpp=16 display_color_bg=0 display_color_fg=0xffff display_color_format_index=16 display_height=576 display_layer=osd2 display_width=720 ethact=Meson_Ethernet ethaddr=00:15:18:01:81:31 fb_addr=0x7900000 fb_height=720 fb_width=1280 firstboot=0 gatewayip=10.18.9.1 get_dt=checkhw has.accelerometer=false hdmimode=1080p hostname=arm_m8 initargs=init=/init console=ttyS0,115200n8 no_console_suspend storage=1 initrd_high=60000000 ipaddr=10.18.9.97 loadaddr=0x12000000 loadaddr_logo=0x13000000 mmcargs=setenv bootargs console=${console} boardname=m8_board netmask=255.255.255.0 normalsize=400000 normalstart=1000000 outputmode=576cvbs p0path=uImage p0size=400000 p0start=1000000 p1path=android.rootfs p1size=8000000 p1start=1400000 partnum=2 preboot=if itest ${upgrade_step} == 3; then run prepare; run storeargs; run update; fi; if itest ${upgrade_step} == 1; then defenv; setenv upgrade_step 2; saveenv;fi; run prepare;run storeargs;get_rebootmode; clear_rebootmode; echo reboot_mode=${reboot_mode};run update_key; run update_ir; run switch_bootmode preloaddtb=imgread dtb boot ${loadaddr} prepare=logo size ${outputmode}; video open; video clear; video dev open ${outputmode};imgread pic logo bootup ${loadaddr_logo}; bmp display ${bootup_offset}; bmp scale; reboot_mode=charging recovery=echo enter recovery;if mmcinfo; then if fatload mmc 0 ${loadaddr} recovery.img; then bootm;fi;fi; if usb start 0; then if fatload usb 0 ${loadaddr} recovery.img; then bootm; fi;fi;if imgread kernel recovery ${loadaddr}; then bootm; else echo no recovery in flash; fi; sdc_burning=sdc_burn ${sdcburncfg} sdcburncfg=aml_sdc_burn.ini serverip=10.18.9.113 stderr=serial stdin=serial stdout=serial store=1 storeargs=setenv bootargs ${initargs} vdaccfg=${vdac_config} logo=osd1,loaded,${fb_addr},${outputmode},full hdmimode=${hdmimode} cvbsmode=${cvbsmode} androidboot.firstboot=${firstboot} hdmitx=${cecconfig} storeboot=echo Booting...; if unifykey get usid; then setenv bootargs ${bootargs} androidboot.serialno=${usid};fi;if unifykey get mac; then setenv bootargs ${bootargs} mac=${ethaddr};fi;imgread kernel boot ${loadaddr};bootm;run recovery switch_bootmode=if test ${reboot_mode} = factory_reset; then run recovery;else if test ${reboot_mode} = update; then run update;else if test ${reboot_mode} = usb_burning; then run usb_burning;else if test ${wipe_data} = failed; then echo wipe_data=${wipe_data}; run recovery;else fi;fi;fi;fi testaddr=0x12400000 update=run usb_burning; if mmcinfo; then if fatexist mmc 0 ${sdcburncfg}; then run sdc_burning; else if fatload mmc 0 ${loadaddr} aml_autoscript; then autoscr ${loadaddr}; fi;run recovery;fi;else run recovery;fi; update_ir=if irdetect; then run update; fi update_key=saradc open 0; if saradc get_in_range 0 0x50; then msleep 50; if saradc get_in_range 0 0x50; then echo update by key...; run update; fi;fi upgrade_step=0 usb_burning=update 1000 vdac_config=0xa000 video_dev=tvout wipe_data=success Link to post Share on other sites
mdel 8 Posted September 12, 2016 Share Posted September 12, 2016 @@bellad nice, it looks a lot like my box output, same dtb commands. try to get the output of the "help" command as balbes150 requested. thx Link to post Share on other sites
bellad 2 Posted September 12, 2016 Share Posted September 12, 2016 ok , my help : m8b_m201_1G#help ? - alias for 'help' adc - M6 ADC test amlnf - AMLPHYNAND sub-system amlnf_test- AMLPHYNAND sub-system autoping- do auto ping test autoscr - run script from memory base - print or set address offset bdinfo - print Board Info structure bmp - manipulate BMP image data boardid_prefetch- boardid sub-system bootm - boot application image from memory bootp - boot image via network using BOOTP/TFTP protocol cali - configure clock phare calinfo - calinfo print the chip calibration info cbusreg - cbus register read/write checkhw - Get the hardware revsion clear_rebootmode- clear rebootmode clkmsr - measure PLL clock cmp - memory compare coninfo - print console devices and information cp - memory copy crc32 - checksum calculation dcache - enable or disable data cache defenv - default environment defenv_without- defenv without environment variables dhcp - boot image via network using DHCP/TFTP protocol dtbinit - init some env by reading dtb file dtbload - load binary dtb file from a dos filesystem echo - echo args to console editenv - edit environment variable efuse - efuse version/licence/mac/hdcp/usid read/write or dump raw efuse data commands or info(display chip efuse info) env - environment handling commands ethchk - check ethernet status ethdbg - set ethernet debug level ethmode - set ethernet mac mode ethrst - reset ethernet phy exit - exit script ext2load- load binary file from a Ext2 filesystem ext2ls - list files in a directory (default /) false - do nothing, unsuccessfully fatexist- find the file from a dos filesystem fatinfo - print information about filesystem fatload - load binary file from a dos filesystem fatls - list files in a directory (default /) fdt - flattened device tree utility commands get_img_size- get img size and save the result as a environment variable get_rebootmode- get reboot mode go - start application at address 'addr' gset - gpio commands help - print command description/usage icache - enable or disable instruction cache imgread - Read the image from internal flash with actual size imxtract- extract a part of a multi-image irdetect- Detect IR Key to start recovery system irkey - irkey key_value time_value itest - return true/false on integer compare keyunify- key unify sub-system kgdb - enter gdb remote debug mode loadb - load binary file over serial line (kermit mode) loadenv - load environment at address 'addr' loads - load S-Record file over serial line loadx - load binary file over serial line (xmodem mode) loady - load binary file over serial line (ymodem mode) logo - logo sub-system loop - infinite loop on address range macreg - ethernet mac register read/write/dump md - memory display mdc_clk - do mdc clock mm - memory modify (auto-incrementing address) mmc - MMC sub system mmcinfo - mmcinfo <dev num>-- display MMC info msleep - delay execution for some time msr - Meson msr sub-system mtest - simple RAM read/write test mw - memory write (fill) netspd_f- enforce eth speed nm - memory modify (constant address) phyreg - ethernet phy register read/write/dump ping - send ICMP ECHO_REQUEST to network host printenv- print environment variables put - put storage pwm - pwm sub-system rarpboot- boot image via network using RARP/TFTP protocol reset - Perform RESET of the CPU run - run commands in an environment variable saradc - saradc sub-system saveenv - save environment variables to persistent storage sdc_burn- Burning with amlogic format package in sdmmc sdc_update- Burning a partition with image file in sdmmc card secukey - security KEY sub-system setenv - set environment variables sf - SPI flash sub-system showvar - print local hushshell variables sleep - delay execution for some time source - run script from memory ssecukey- NAND KEY sub-system store - STORE sub-system suspend - suspend test - minimal test like /bin/sh tftpboot- boot image via network using TFTP protocol true - do nothing, successfully unifykey- unifykey read/write based on the driver keymanage unpackimg- unpack imgpack to single update - Enter v2 usbburning mode usb - USB sub-system usbbc - test usb bc usbboot - boot from USB device usid_prefetch- usid sub-system uuid_prefetch- uuid sub-system version - print monitor, compiler and linker version video - video sub-system Link to post Share on other sites
balbes150 876 Posted September 12, 2016 Share Posted September 12, 2016 Thank you. Yes, this is what I need. Link to post Share on other sites
mdel 8 Posted September 13, 2016 Share Posted September 13, 2016 @@balbes150 i see that in your s805 git revision you've replaced some s812 configuration with s805, and i remembered i have an s812 box here as well, it's an M8S i think. if you want to test please let me know, it should be a 2G/8G box. Link to post Share on other sites
balbes150 876 Posted September 13, 2016 Share Posted September 13, 2016 Thank you. When will be the result, which you can check, I'll write. Link to post Share on other sites
bellad 2 Posted September 14, 2016 Share Posted September 14, 2016 thank balbes150 for your work , i wait for test Link to post Share on other sites
balbes150 876 Posted September 14, 2016 Share Posted September 14, 2016 (edited) Gathered a working version of the image armbian (console) for the s805. Checked on my existing Board with S805 (spot i5). The image starts and runs. Due to the lack of work on my Board USB connector, I was unable to test the USB flash drive. To use, you can write the image to the media, copy it to the root of the first (FAT) partition and rename "dtb.img" is needed for the Board file (from the directory dtb of the first partition of the written medium). Order of use 1. to activate your universal multiboot 2. to record an image on the medium 3. to correctly copy and rename on media suitable for Board dtb file. To build dtb files for other models, please provide to me either a dts file from need model, or provide a link to the firmware or to provide a working dtb file from the correct model. In the first stage, you can try to use the files in the dtb (don't forget to copy to the root of the FAT partition and rename to "dtb.img"). https://yadi.sk/d/DnCkh3KBvAFES Multiboot https://yadi.sk/d/c9kY4tuLuPF3Y p.s. Fixed the link to the multiboot Edited September 14, 2016 by balbes150 Link to post Share on other sites
mdel 8 Posted September 14, 2016 Share Posted September 14, 2016 nice i'll test on my beelink s85 your multiboot link is the same as the image link Link to post Share on other sites
bellad 2 Posted September 15, 2016 Share Posted September 15, 2016 hi , thank , my english it's very bad , can you howto step for sdcard ? Link to post Share on other sites
balbes150 876 Posted September 15, 2016 Share Posted September 15, 2016 Method using the standard firmware. This procedure needs to be performed once. 1. to format the SD card to FAT 2. to download two of the file aml_autoscript aml_autoscript.zip 3. to record these files on a prepared map 4. start TV box 5. to connect the prepared map (with two files) 6. open the installed app Update&Backup 7. to choose as a local update files on the SD card (aml_autoscript.zip) 8. Run update 9, TV box to reboot two times and again will load the regular firmware. 10. pull the card From that moment on the TV console activated universal multiboot and you can run it on a different system from external media. The internal system remains unchanged and no it does not suffer from this. To use the image Armbian. 1. Download image 2. Write him a special program on the carrier 3. copy and rename "dtb.img" in the root of the FAT partition media that is appropriate for your set-top box dtb file (from the directory of the first partition dtb prepared media). At the moment there are three files, you can try all three files. If the system fails to boot, you need to collect suitable for your TV box new dtb file. For this you need to send me the relevant information. On these links, you can read the details on how you can capture the image on the medium. http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/tronsmart-ac/firmware-roms-tools-at/565449-running-linux-from-sd-card-or-usb-flash-drive-using-balbes150-method-and-files If you have any questions, feel free to ask questions, I will try to explain. Link to post Share on other sites
balbes150 876 Posted September 15, 2016 Share Posted September 15, 2016 Upload a revised version. Fixed extension section in the firstrun script. Armbian_5.17_Vegas85_Debian_jessie_3.10.102_20160915.img Link to post Share on other sites
bellad 2 Posted September 16, 2016 Share Posted September 16, 2016 hello, , thank , but i busy work , when time more i test Link to post Share on other sites
mdel 8 Posted September 16, 2016 Share Posted September 16, 2016 @@balbes150 i'm having trouble installing your aml_autoscript on my s85 box, when it reboots in recovery i get the following errors : E:footer is wrong E:signature verification failed Installation aborted. I see this is a common error, but i don't know much about android an didn't find an easy trick to fix that myself. The update files are on the root of my USB stick, and tried again from within recovery (update from external -> udisk) but got the same error. thx Link to post Share on other sites
balbes150 876 Posted September 16, 2016 Share Posted September 16, 2016 This is a common mistake. Usually it is associated with a media error. Sometimes this error is related to a bad download of the file (error when downloading). First check how to prepare the media. Must be FAT system. The media is better to have no more than 2 GB. For the S805 is better to use SD card, because in many models of u-boot S805 not working install updates from a USB. They can only use the SD card activate the multi-boot. Alternatively, download the special image at the link. Burn it to the media. To replace the files on those that are designed to S805. PLEASE NOTE the files in the original image state is designed to S905 they need to replace the files for the S805. https://yadi.sk/d/FcNyXwmhurN2D Added in GIT a few new dtb files for multiple models (which found in free access). Please to those who have the opportunity to check their performance on these models. MXQ HD180 M808 M201. https://github.com/150balbes/Amlogic_s905/tree/master/dtb_file/S805 Link to post Share on other sites
mdel 8 Posted September 16, 2016 Share Posted September 16, 2016 ok thx for the explanation, sorry i should have tried from sd card and it did work fine. Your s805_autoscript udpate is okay now and i've checked my /dev/block/env to make sure your modifications are there. now i'm trying to boot your image Armbian_5.17_Vegas85_Debian_jessie_3.10.102_20160915.img i get two behaviors depending on which dtb.img file i'm using : - when using your m201_1G/dtb.img, or my box dtb.img (with stripped headers, i'll explain below), i get no hdmi output (monitor says "no input") an no boot as far as i can tell, network light is on (not active), no dhcp request sent by the box. - when i use my "split_bootimg.pl" dtb.img, taken from the /dev/block/boot of my box, or from a stock image, android boots as if no sd card was inserted. here's the some firmware data for that box : Beelink s85 firmwares and my dump i'm feeling that split_bootimg.pl tool does not extract dtb.img properly for those s805 boot blob. When i use it, the boot-second.gz generated is larger and has some kind of header at the beginning which makes dtc send "bad magic number" error when trying to decompile to dts. i did find a workaround (remove hex header, that's why i called it "stripped"), then dtc works fine and dts output is clean and i get the "no hdmi" boot as described above. Link to post Share on other sites
balbes150 876 Posted September 16, 2016 Share Posted September 16, 2016 (edited) Share the link to Your dtb file. It is necessary to try to collect all variant dtb file based on the Assembly environment and the kernel sources , which in Armbian. Maybe it will help to start the system. It is advisable to try all the dtb files that are in the directory and on the website. Sometimes it helps initial boot (not all hardware will work, but the main thing is to find a basic piece of data). In the last images added two scripts to perform a full backup and restore the entire internal memory (ddBR). It is convenient to use in front of various experiments with the contents of the internal memory. Edited September 16, 2016 by balbes150 Link to post Share on other sites
mdel 8 Posted September 17, 2016 Share Posted September 17, 2016 i will do more tests tomorrow the firmware images for my box are on the Mega.cz link above. i did not put the dtb directly there yet, because i don't know if my dtb extraction tool works or not. You'll find a "boot.img" in the "dump" and "firmwares/extract" directories which are the /dev/block/boot blob that contain the dtb bin. i use "split_bootimg.pl" script from cnxsoft tutorial to extract the dtb.img but as i tried to explain above, i'm not sure the dtb blob is good. Link to post Share on other sites
balbes150 876 Posted September 18, 2016 Share Posted September 18, 2016 I uploaded the new images. Try them. You need to try everything available in the catalog of dtb files (from all models). I have oddly enough, the i5 is better earned the console image file from hq18. When using native dtb files (from version) i5) was the problem. The system did not boot (had a kernel panic) with the native tether 1Gb, which runs Android. With dtb file 512MB the system was started and worked, but was determined only 350 MB of memory. And file from hq18, it works correctly, the memory was 790 MB and the system was stably run. By the way, I downloaded the desktop Ubuntu image. It works for me, there is a Desk XFCE , but the colors are not correct and can not see the cursor. Have to move the fly at random. I downloaded the firmware for the MXQ S85 and soon will try to get all dtb files and I'll post it on the website. Link to post Share on other sites
