arimak Posted June 27, 2018 Share Posted June 27, 2018 35 minutes ago, balbes150 said: I put together a version Libreelec KODI-18 for S805 and Linux images with the main kernel, but I have only one "half-dead" device s805, at which the run system to panics (perhaps because of hardware faults). I am interested in the process of running these systems (with full logs from the start of u-boot) on other Board options. To enable USB, try to decompile (in dts format) with utilite DTC, your dtb, where USB works and compare it with the decompiled dtb version from the latest image. If there is a difference, try to make the necessary changes to the new file and build the dtb from it. That older Android 4.4.2 (kernel 3.10.33) had in its device tree: usb_con { lm-compatible = "logicmodule-bus"; usb_b { lm-compatible = "amlogic,usb"; lm-periph-id = <0x1>; clock-src = "usb1"; port-id = <0x1>; port-type = <0x1>; port-speed = <0x0>; port-config = <0x0>; port-dma = <0x0>; port-id-mode = <0x1>; status = "okay"; }; usb_a { lm-compatible = "amlogic,usb"; lm-periph-id = <0x0>; clock-src = "usb0"; port-id = <0x0>; port-type = <0x1>; port-speed = <0x0>; port-config = <0x0>; port-dma = <0x0>; port-id-mode = <0x0>; gpio-vbus-power = "GPIOAO_5"; gpio-work-mask = <0x1>; status = "okay"; }; }; So through usb_a which is seen in system as lm0 is driven gpio-vbus-power = "GPIOAO_5" Question is, how can I drive that gpio-vbus-power in newer kernels? My MXQ box is (I think) very inspired by Odroid C1, they use only GPIOAO_4 (instead of GPIOAO_5) for driving internal USB hubs RESET signal. Link to comment Share on other sites More sharing options...
balbes150 Posted June 27, 2018 Share Posted June 27, 2018 Remove the comment and use the desired value. https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_m201_1G.dts#L583 in dtb meson8b_mxq value is enable https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_mxq.dts#L514 change from 0 to 1 https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_mxq.dts#L509 Link to comment Share on other sites More sharing options...
arimak Posted June 27, 2018 Share Posted June 27, 2018 5 hours ago, balbes150 said: Remove the comment and use the desired value. https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_m201_1G.dts#L583 in dtb meson8b_mxq value is enable https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_mxq.dts#L514 change from 0 to 1 https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805-LE/arch/arm/boot/dts/meson8b_mxq.dts#L509 I tried all this before already There must be something more I think, maybe in some script, switching that gpio-vbus-power or so... Link to comment Share on other sites More sharing options...
Titot Posted June 28, 2018 Share Posted June 28, 2018 23 hours ago, arimak said: I tried all this before already There must be something more I think, maybe in some script, switching that gpio-vbus-power or so... My box use the gpioao_5 usb bus and I use the attached dtb and all the usb works. Remove .txt and test it! meson8b_mxv-u-j.dtb.txt Link to comment Share on other sites More sharing options...
arimak Posted June 29, 2018 Share Posted June 29, 2018 23 hours ago, Titot said: My box use the gpioao_5 usb bus and I use the attached dtb and all the usb works. Remove .txt and test it! meson8b_mxv-u-j.dtb.txt Thanks, but this dtb doesn't work too. Still can't see the hub and other devices hanged on it. Could you link me pics of your box inside, with little description? How many USBs, what chip for internal USB hub,... There's a lot of versions of these S805 boxes, MXV, MXQ - I've seen about 5 versions of MXQs with different PCBs, USB hubs, wifi chips,... For inspiration I'm attaching the .dts which worked for me in an old android (but is not working for Armbian at all, can't boot ). meson8mediamanv2.dts Link to comment Share on other sites More sharing options...
Titot Posted June 30, 2018 Share Posted June 30, 2018 13 hours ago, arimak said: Thanks, but this dtb doesn't work too. Still can't see the hub and other devices hanged on it. Could you link me pics of your box inside, with little description? How many USBs, what chip for internal USB hub,... There's a lot of versions of these S805 boxes, MXV, MXQ - I've seen about 5 versions of MXQs with different PCBs, USB hubs, wifi chips,... For inspiration I'm attaching the .dts which worked for me in an old android (but is not working for Armbian at all, can't boot ). meson8mediamanv2.dts I use your dts compiled to dtb and my box and boot, but off course no wifi and only 3of the 4 usb working. One thing I use the kernel 3.10.61 . I dont know is that could make the difference?? Link to comment Share on other sites More sharing options...
arimak Posted June 30, 2018 Share Posted June 30, 2018 4 hours ago, Titot said: I use your dts compiled to dtb and my box and boot, but off course no wifi and only 3of the 4 usb working. One thing I use the kernel 3.10.61 . I dont know is that could make the difference?? Your MXV doesn't have wifi inside? As we know, S805 have 2 USBs on-chip (OTG and HOST), OTG is mainly for flashing and usually works always, on some boxes is marked as USB-1, next 3 USBs (USB-2,..,USB-4) are connected to internal USB hub. Differences among kernels can be important reasons, why some things works or not. As I wrote I'm now with Ubuntu Mate with 3.10.108 kernel, and don't want go to older versions. Link to comment Share on other sites More sharing options...
Titot Posted June 30, 2018 Share Posted June 30, 2018 7 hours ago, arimak said: Your MXV doesn't have wifi inside? As we know, S805 have 2 USBs on-chip (OTG and HOST), OTG is mainly for flashing and usually works always, on some boxes is marked as USB-1, next 3 USBs (USB-2,..,USB-4) are connected to internal USB hub. Differences among kernels can be important reasons, why some things works or not. As I wrote I'm now with Ubuntu Mate with 3.10.108 kernel, and don't want go to older versions. My MXV comes with wifi inside . With your posted dtb file I cant only use 3 of the usb , the OTG not active. You use Ubuntu Mate ... with what dtb file? Link to comment Share on other sites More sharing options...
arimak Posted June 30, 2018 Share Posted June 30, 2018 2 hours ago, Titot said: My MXV comes with wifi inside . With your posted dtb file I cant only use 3 of the usb , the OTG not active. You use Ubuntu Mate ... with what dtb file? For now with this my experimental, but still not working USB hub (and its 3 USBs + wifi). I'm trying use the GPIOAO_5, but still without success :/ mxqPR011.dts mxqPR011.dtb Link to comment Share on other sites More sharing options...
Titot Posted July 1, 2018 Share Posted July 1, 2018 7 hours ago, arimak said: For now with this my experimental, but still not working USB hub (and its 3 USBs + wifi). I'm trying use the GPIOAO_5, but still without success :/ mxqPR011.dts mxqPR011.dtb I use the dtb from my MXV box android OS . and all works. You post the "meson8mediamanv2.dts" used by android . Right? and that dts dont have the gpioao_5 on the usb part? Also like I said , your android dts file boot my device but with other kernel , so here is the kernel : https://mega.nz/#!VSYF1aLI!OvuLNW1Lg1YH5S0UY33vCPyGaWs0Ac90D4m_t-V940g Link to comment Share on other sites More sharing options...
l m m Posted August 5, 2018 Share Posted August 5, 2018 Hi balbes150, I'm trying to reuse my old OTT S805 box and succeeded in getting the 5.37 build to install to nand, but can't get either of the later ones 5.41 or 5.44 to run after they seem to install. I need to install to nand on this box as it seems to have a faulty sd card slot and not always reading correctly. I've used the method ./install.sh to do the install to nand, as the othet method doesn't seem to be installed in these builds (nand-sata-install) Is there a way to update to a later build straight from the running nand install or does it have to be a fresh install from the sd card? Link to comment Share on other sites More sharing options...
balbes150 Posted August 6, 2018 Share Posted August 6, 2018 10 hours ago, l m m said: I'm trying to reuse my old OTT S805 box and succeeded in getting the 5.37 build to install to nand, but can't get either of the later ones 5.41 or 5.44 to run after they seem to install. I need to install to nand on this box as it seems to have a faulty sd card slot and not always reading correctly. I've used the method ./install.sh to do the install to nand, as the othet method doesn't seem to be installed in these builds (nand-sata-install) Is there a way to update to a later build straight from the running nand install or does it have to be a fresh install from the sd card? If you are running version 5.37, you can upgrade packages in the standard way without running a new installation. Link to comment Share on other sites More sharing options...
l m m Posted August 6, 2018 Share Posted August 6, 2018 (edited) 11 hours ago, balbes150 said: If you are running version 5.37, you can upgrade packages in the standard way without running a new installation. That would be great but I can't find any details on how to do an in-line upgrade. Have you mentioned before? I want to try ang get to build 5.44 as it has Plex server embedded Edited August 6, 2018 by l m m Forgot to mention why I'm trying to upgrade Link to comment Share on other sites More sharing options...
balbes150 Posted August 7, 2018 Share Posted August 7, 2018 8 hours ago, l m m said: That would be great but I can't find any details on how to do an in-line upgrade. Have you mentioned before? I want to try ang get to build 5.44 as it has Plex server embedded 1. The update is performed on all Debian\Ubuntu, the command "apt update" "apt upgrade". 2. The composition of packages in 5.37 and 5.44 does not contain Plex. You install and configure it yourself. Link to comment Share on other sites More sharing options...
Milan Kragujevic Posted August 7, 2018 Share Posted August 7, 2018 Hi, balbes150, I was wondering, could you either show me the tools needed to build Armbian for Meson8b/S805 on m201d MXQ with 512MB RAM, or build an image with included support for UVC/Video4Linux2, because I need to have TV capture / web camera with USB device and the current builds do not support UVC... Thanks so much for your work! :) Link to comment Share on other sites More sharing options...
balbes150 Posted August 7, 2018 Share Posted August 7, 2018 1 hour ago, Milan Kragujevic said: I was wondering, could you either show me the tools needed to build Armbian To build for S805, use this GIT. https://github.com/150balbes/build Link to comment Share on other sites More sharing options...
Milan Kragujevic Posted August 7, 2018 Share Posted August 7, 2018 Yes, thank you. I managed to build it, so I'll be testing it out. I enabled multimedia, usb web camera and v4l2 support in amlogic drivers section. So I think it should work.. We'll see... Link to comment Share on other sites More sharing options...
Johan1985 Posted September 5, 2018 Share Posted September 5, 2018 Hi, Hope someone can point me in the right direction, I downloaded the Armbian_5.44_S805_Ubuntu_bionic_3.10.108_server_20180521.img image and booted successfully from an sd card and executed /root/install.sh as the root user, but when I remove the sd card and reboot, the s805 boots into busybox. Have anyone successfully installed it onto their system without the need to have the sd card in the whole time? Link to comment Share on other sites More sharing options...
Иван Тотев Posted September 11, 2018 Share Posted September 11, 2018 Hi Can someone give me the link of the kernel source code and the config for Armbian_5.44_S805_Ubuntu_xenial_3.10.108_server_20180521.img Armbian_5.41_S805_Ubuntu_xenial_3.10.108_server_20180330.img I want to recompile the kernel inside the device root@vegas805:/usr/src# uname -r 3.10.108 root@vegas805:/usr/src# mkimage -l /boot/uImage Image Name: Linux-3.10.108 Created: Fri Mar 30 09:19:14 2018 best regards Link to comment Share on other sites More sharing options...
balbes150 Posted September 12, 2018 Share Posted September 12, 2018 15 hours ago, Иван Тотев said: Can someone give me the link of the kernel source code and the config for src https://github.com/150balbes/Amlogic_s8xx-kernel/tree/S8xx The config can be found in the /boot directory of the recorded image. Link to comment Share on other sites More sharing options...
Иван Тотев Posted September 12, 2018 Share Posted September 12, 2018 2 hours ago, balbes150 said: src https://github.com/150balbes/Amlogic_s8xx-kernel/tree/S8xx The config can be found in the /boot directory of the recorded image. Thank you ! Link to comment Share on other sites More sharing options...
Иван Тотев Posted September 13, 2018 Share Posted September 13, 2018 On 9/12/2018 at 9:02 AM, balbes150 said: src https://github.com/150balbes/Amlogic_s8xx-kernel/tree/S8xx The config can be found in the /boot directory of the recorded image. Hi I can't manage to boot the device. My box is MXQ S805 I recompiled the kernel in my Linux PC. Used your link but branch S805. The config which I used was https://github.com/150balbes/Amlogic_s8xx-kernel/blob/S805/config_20170815 I'll write my steps: - I downloaded gcc 4 from here https://releases.linaro.org/components/toolchain/binaries/4.9-2017.01/arm-linux-gnueabihf/ - git clone -b S805 https://github.com/150balbes/Amlogic_s8xx-kernel/tree/S8xx - I made the .config file from your file (config_20170815) cp config_20170815 .config - I made a script: set_make2 (edited your script with my gcc path) export ARCH=arm export CROSS_COMPILE=arm-linux-gnueabihf- export PATH=/home/marabej/Downloads/Armbian_S805/kernel/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/:$PATH make -j6 uImage modules dtbs - I made another script "set_modules_install" export ARCH=arm export CROSS_COMPILE=arm-linux-gnueabihf- export PATH=/home/marabej/Downloads/Armbian_S805/kernel/gcc-linaro-4.9.4-2017.01-x86_64_arm-linux-gnueabihf/bin/:$PATH make -j6 modules_install - ./set_make2 - ./set_modules_install Compilation is OK " Image Name: Linux-3.10.33 Created: Thu Sep 13 12:44:24 2018 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 6168724 Bytes = 6024.14 kB = 5.88 MB Load Address: 00208000 Entry Point: 00208000 " - After that I overwrite the box's /boot/uImage with arch/boot/uImage from the kernel - I copied my PC /lib/modules/3.10.33 (these are the compiled ARM modules) to the box's /lib/modules Turned on the device and MXQ logo appeared. After 3-4 sec. the logo dissapeared and the device hangs, no video, keyboard not working etc. Note: the original image 3.10.108 is workign without dtb.img file on my device. I tried the new kernel with or without dtb file - the same result Can you help me with advice? Best Regards Link to comment Share on other sites More sharing options...
balbes150 Posted September 13, 2018 Share Posted September 13, 2018 Kernel configuration. https://github.com/150balbes/build/blob/amlogic/config/kernel/linux-vegas805-default.config GCC which is needed for Assembly https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L20 https://github.com/150balbes/build/blob/amlogic/lib/general.sh#L645 src https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L21 branch https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L23 Build uInitrd (many manuals on the Internet). Link to comment Share on other sites More sharing options...
Иван Тотев Posted September 13, 2018 Share Posted September 13, 2018 2 hours ago, balbes150 said: Kernel configuration. https://github.com/150balbes/build/blob/amlogic/config/kernel/linux-vegas805-default.config GCC which is needed for Assembly https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L20 https://github.com/150balbes/build/blob/amlogic/lib/general.sh#L645 src https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L21 branch https://github.com/150balbes/build/blob/amlogic/config/sources/vegas805.conf#L23 Build uInitrd (many manuals on the Internet). Thank You Link to comment Share on other sites More sharing options...
mcc05 Posted October 15, 2018 Share Posted October 15, 2018 On 4/1/2018 at 2:12 PM, verb said: I have problems after instaling 5.41 20180330. ubuntu server image here is the log from uart : https://pastebin.com/raw/qLb4Kd9M and here some pics from console : https://pasteboard.co/HeBhPXa.jpg -> https://pasteboard.co/HeBjEwq.jpg Sorry for bad pic quality . Also i do the install via uart with these commands : usb start fatload usb 0 11000000 aml_autoscript autoscr 11000000 ps : the installtonand script goes without any issue but after that i am not able to boot from nand if i remove the flash drive On 4/1/2018 at 3:59 PM, balbes150 said: You do not have root mounted, so the system does not start. On 4/1/2018 at 6:49 PM, verb said: I saw that but i dont understand why it fails to mount /dev/data and i go through the same steps with armbian 5.37 and it works fine. All just started with this, have a MXQ S805, m201d, device, I can get it working on 5.37, onto eMMC, with wifi, but I like above can't get any later version to successfully install onto the eMMC. What is required to get it working for the later versions after ./install.sh is run, why are the mounts not working, and how do I do this manually if required? @balbes150 any thought pleeese? Link to comment Share on other sites More sharing options...
greenais Posted October 17, 2018 Share Posted October 17, 2018 First - great job @balbes150, thank you! My issue is that I can't get wifi working - tried all builds and all dtb-s... I know that armbian-config clearly says regarding drivers "...if not - you are on your own", but what can be done then? My board: MXQ S85 MB: AM_MXQ_A 20150825 rev. MXQ_S805_V03 WiFi: RTL8189ETV NAND: H27UCG8T2ETR BC Ethernet: IC IP101GR Install to eMMC doesn't work too (same way fails to mount /dev/data after all) but it doesn't matter, no wifi is more pain for me. I'd greatly appreciate any tips in what direction to dig further - got stuck without ideas... Thank you in advance. Link to comment Share on other sites More sharing options...
mcc05 Posted October 18, 2018 Share Posted October 18, 2018 On 10/17/2018 at 4:29 AM, greenais said: First - great job @balbes150, thank you! My issue is that I can't get wifi working - tried all builds and all dtb-s... I know that armbian-config clearly says regarding drivers "...if not - you are on your own", but what can be done then? My board: MXQ S85 MB: AM_MXQ_A 20150825 rev. MXQ_S805_V03 WiFi: RTL8189ETV NAND: H27UCG8T2ETR BC Ethernet: IC IP101GR Install to eMMC doesn't work too (same way fails to mount /dev/data after all) but it doesn't matter, no wifi is more pain for me. I'd greatly appreciate any tips in what direction to dig further - got stuck without ideas... Thank you in advance. So my wifi is RTL8189, I tried modprobe 8189es and it worked so put that in /etc/modules, and wifi up and running, might be worth a try 1 Link to comment Share on other sites More sharing options...
mcc05 Posted October 20, 2018 Share Posted October 20, 2018 @balbes150 thanks you for all you have done on this, its great to find I can use an old S805 box for something useful again. I'm using theArmbian_5.44_S805_Debian_stretch_3.10.108_server_20180521.img, and now running OctoPrint on it to control my 3D printer. Wifi is up and working using 8189es driver etc. Only two things I wish I could sort: 1) getting it to install on the eMMC, I know you say the mounting is broken how do I fix 2) download of the Kernel headers doesn't work from armbian-config, so I am a bit lost in where to get the right source from to add in a driver I need to run a webcam for the OctoPrint server. Anyone help? Many thanks this is a great project Link to comment Share on other sites More sharing options...
mcc05 Posted October 21, 2018 Share Posted October 21, 2018 On 8/7/2018 at 10:18 AM, Milan Kragujevic said: Yes, thank you. I managed to build it, so I'll be testing it out. I enabled multimedia, usb web camera and v4l2 support in amlogic drivers section. So I think it should work.. We'll see... Hi @Milan Kragujevic, did you get your kernel build to work, and is it 3.10.108 variant, I would like web cam etc and my board is the same as yours m201d MXQ, if so can you share? Link to comment Share on other sites More sharing options...
Milan Kragujevic Posted October 27, 2018 Share Posted October 27, 2018 On 10/21/2018 at 7:05 PM, mcc05 said: Hi @Milan Kragujevic, did you get your kernel build to work, and is it 3.10.108 variant, I would like web cam etc and my board is the same as yours m201d MXQ, if so can you share? Hi, send me an email at milankragujevic [at] gmail [dot] com, and I will try to help you. In any case, I will publish my build here, for lazy people who don't wanna build it themselves. Btw, I just tonight build a new one. Link to comment Share on other sites More sharing options...
