balbes150 Posted October 18, 2017 Share Posted October 18, 2017 On 16.10.2017 at 4:05 PM, verb said: Can you help me to install armbian with the USB stick ? Write the steps you did to install the LE from the USB flash drive. Link to comment Share on other sites More sharing options...
verb Posted October 19, 2017 Share Posted October 19, 2017 Hello balbes150 Thanks for replying me . Link to comment Share on other sites More sharing options...
verb Posted October 25, 2017 Share Posted October 25, 2017 Hello community Anyone who have tried to migrate from Libreelec to armbian ? or install armbian only via flash drive ??? Link to comment Share on other sites More sharing options...
ztof Posted November 26, 2017 Share Posted November 26, 2017 Hello balbes150, I would like to thank you for your work. I have an Inphic SPOT i5 S805 without USB port (well, it had micro-USB at first but this port fell down litterally, due to really bad soldering). With the files you provided and the comment both on this topic and the one from freaktab forum ( http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s805/others-ab/534054-inphic-spot-i5-s805-media-player ), I've managed to install and make run Ubuntu Xenial Server (Armbian_5.32_S805_Ubuntu_xenial_3.10.33_server_20170821.img). It works, thanks ! This little box will now be dedicated to some networked tasks. For the moment I've installed Pi-Hole to get an Ad-blocker for my whole private network. There are some alerts that hostname service doesn't work but here is a manual fix : https://github.com/openbmc/openbmc/issues/1949#issuecomment-315020684 Do you know if there is any plan to release an image with mainline kernel for this box ? Link to comment Share on other sites More sharing options...
balbes150 Posted November 27, 2017 Share Posted November 27, 2017 20 hours ago, ztof said: Do you know if there is any plan to release an image with mainline kernel for this box ? There are plans, but until I have enough free time. Link to comment Share on other sites More sharing options...
balbes150 Posted December 27, 2017 Share Posted December 27, 2017 update image 5.37_20171227 add new image IceWM Link to comment Share on other sites More sharing options...
verb Posted January 8, 2018 Share Posted January 8, 2018 Hello can anyone explain me what does this two scripts do -> s805_autoscript and aml_autoscript Link to comment Share on other sites More sharing options...
balbes150 Posted January 9, 2018 Share Posted January 9, 2018 10 hours ago, verb said: Hello can anyone explain me what does this two scripts do -> s805_autoscript and aml_autoscript aml_autoscript - enables multi-upload (one time procedure). s805_autoscript script that starts the system from removable media, taking into account the particularities of each system. Link to comment Share on other sites More sharing options...
balbes150 Posted January 12, 2018 Share Posted January 12, 2018 Image update S805 20180112. Updated kernel to version 3.10.99. Added screen mode 1080p. This mode is enabled by default. To switch to 720p you need to edit first line of script /boot/hdmi.sh. For smooth playback of test video I recommend to reduce the window size of the reproduced video to the size that would have enough system resources for smooth video playback. 1 Link to comment Share on other sites More sharing options...
verb Posted January 14, 2018 Share Posted January 14, 2018 balbes150 please suggest any method to install aml_autoscript from usb flash drive . I have tried https://yadi.sk/d/c9kY4tuLuPF3Y/v04 and i have ended with "E:footer is wrong ; signature verification failed" ps: I don;t need to multiboot ( i need to install armbian to nand and no need to keep android) Link to comment Share on other sites More sharing options...
roel Posted January 14, 2018 Share Posted January 14, 2018 Hello balbes150, you last image works a lot better then the previous one. Although my wifi is not working, but now it boot's a lot faster and sounds works. I'm on a mk808b plus and the needed dtb is M201-1G. Link to comment Share on other sites More sharing options...
balbes150 Posted January 15, 2018 Share Posted January 15, 2018 On 14.01.2018 at 11:34 AM, verb said: please suggest any method to install aml_autoscript from usb flash drive . I have tried https://yadi.sk/d/c9kY4tuLuPF3Y/v04 and i have ended with "E:footer is wrong ; signature verification failed" ps: I don;t need to multiboot ( i need to install armbian to nand and no need to keep android) There are only two options 1. With SD card in automatic mode 2. From the console UART in the manual you can run all the commands from any media (SD or USB). 18 hours ago, roel said: you last image works a lot better then the previous one. Although my wifi is not working, but now it boot's a lot faster and sounds works. I'm on a mk808b plus and the needed dtb is M201-1G. Have you tried to load the WiFi module ? Link to comment Share on other sites More sharing options...
verb Posted January 15, 2018 Share Posted January 15, 2018 Hello balbes150 i have managed to boot from UART and here is the output : Spoiler ##### VDDEE voltage = 0x044c1100 CPU clock is 792MHz board_id :00000000 DDR mode: 32 bit mode (auto) DDR size: 1GB (auto) DDR check: Pass! DDR clock: 636MHz with 2T mode DDR pll bypass: Disabled DDR init use : 17434 us HHH ucl decompress...pass 0x12345678 Boot from internal device 1st NAND TE : 219798 System Started U-boot-00000-gcc16b01(m8b_m201_v1@) (Apr 18 2016 - 10:52:29) clr h-ram DRAM: 1 GiB relocation Offset is: 0feb8000 show partition table: part: 0, name : logo, size : 2000000 part: 1, name : recovery, size : 2000000 part: 2, name : misc, size : 2000000 part: 3, name : boot, size : 2000000 part: 4, name : system, size : 40000000 part: 5, name : cache, size : 20000000 part: 6, name : data, size : end aml_card_type=0x100 MMC: [mmc_register] add mmc dev_num=0, port=1, if_type=6 [mmc_register] add mmc dev_num=1, port=2, if_type=6 SDIO Port B: 0, SDIO Port C: 1 power init out reg=c110804c,value=dfffffff IR init done! register usb cfg[0][1] = 1ff67b64 register usb cfg[2][0] = 1ff6ab00 NAND: NAND BOOT: boot_device_flag 1 Nand PHY driver Version: 2.01.001.0004 (c) 2013 Amlogic Inc. amlnf_phy_init : amlnf init flag 0 NAND device id: 2c 68 4 4a a9 0 0 0 detect NAND device: C revision NAND 4GiB MT29F32G-C nand chip ce mask 1 bus_cycle=6, bus_timing=8,system=3.9ns,flash->T_REA =16,flash->T_RHOH=15 NAND CKECK : arg nbbt: arg_valid= 1, valid_blk_addr = 4, valid_page_addr = 0 NAND CKECK : arg ncnf: arg_valid= 1, valid_blk_addr = 6, valid_page_addr = 0 NAND CKECK : arg nkey: arg_valid= 1, valid_blk_addr = 5, valid_page_addr = 22 i=0,register --- nand_key NAND CKECK : arg nenv: arg_valid= 1, valid_blk_addr = 9, valid_page_addr = 238 NAND CKECK : arg phyp: arg_valid= 1, valid_blk_addr = 7, valid_page_addr = 1 amlnand_phydev_init,1172,phydev->offset=0,phydev->size=400000 amlnand_phydev_init,1172,phydev->offset=3400000,phydev->size=23c00000 amlnand_phydev_init,1172,phydev->offset=27000000,phydev->size=4fc00000 amlnand_phydev_init,1172,phydev->offset=76c00000,phydev->size=89400000 nfboot : offset: 0x000000000000 -0x000000400000 : partitons 0 : single_chip single_plane nfcache : offset: 0x000003400000 -0x000023c00000 : partitons 1 : single_chip multi_plane nfcode : offset: 0x000027000000 -0x00004fc00000 : partitons 5 : single_chip multi_plane nfdata : offset: 0x000076c00000 -0x000089400000 : partitons 1 : single_chip multi_plane bad block count = 0 bad block count = 0 bad block count = 0 bad block count = 0 amlnf_logic_init: START amlnf_logic_init: COMPLETE get_boot_device_flag: init_ret 0 get_boot_device_flag NAND BOOT: NAND BOOT,nand_env_relocate_spec : env_relocate_spec 49 uboot env amlnf_env_read : #### set_storage_device_flag: store 1 vpu clk_level in dts: 3 set vpu clk: 182150000Hz, readback: 182150000Hz(0x701) Net: Meson_Ethernet init suspend firmware done. (ret:0) cvbs trimming.1.v5: 0xa0, 0x0 hdmi tx power init TV mode 576cvbs selected. vdac open.1 = 0x1, 0x0 mode is: 4 viu chan = 1 config HPLL config HPLL done reboot_mode=charging efuse version is not selected. Hit Enter key to stop autoboot -- : 0 exit abortboot: 0 (Re)start USB(0)... USB0: dwc_usb driver version: 2.94 6-June-2012 USB (1) peri reg base: c1108820 USB (1) use clock source: XTAL input USB (1) base addr: 0xc90c0000 Force id mode: Host dwc_otg: Highspeed device found ! scanning bus 0 for devices... 1 USB Device(s) found scanning usb for storage devices... 1 Storage Device(s) found reading s805_autoscript 1991 bytes read ## Executing script at 11000000 MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 0 ** ** Unable to use mmc 0:1 for fatload ** reading uInitrd 3331991 bytes read reading uImage i guess there is something wrong with my s805_autoscript ?? ( i have waited for more then 30min and nothing outputs) Also i have burned this image on my flash drive and i have copy paste meson8b_m201_1G.dtb to the root dir as dtb.img Link to comment Share on other sites More sharing options...
Andy Dawson Posted January 15, 2018 Share Posted January 15, 2018 Hi All, I hope someone can help me here, I have Armbian_5.37_S805_Ubuntu_xenial_3.10.99_server_20180112.img running on my MXQ box and installed all dev tools to build crypto coins but when I try to build one the system freezes and I have to reboot to get it working again, I would like to run the crypto coin deamon on the mxq but can't get it to build, it's seems like its running out of ram to build the project. Regards, Andy. Link to comment Share on other sites More sharing options...
balbes150 Posted January 16, 2018 Share Posted January 16, 2018 16 hours ago, verb said: i guess there is something wrong with my s805_autoscript ?? ( i have waited for more then 30min and nothing outputs) Also i have burned this image on my flash drive and i have copy paste meson8b_m201_1G.dtb to the root dir as dtb.img The system hangs on reading uImage from a USB drive. Try to stop the launch in the console UART and execute manually the command "printenv" and "help". The result show here. Link to comment Share on other sites More sharing options...
Andy Dawson Posted January 16, 2018 Share Posted January 16, 2018 16 hours ago, Andy Dawson said: Hi All, I hope someone can help me here, I have Armbian_5.37_S805_Ubuntu_xenial_3.10.99_server_20180112.img running on my MXQ box and installed all dev tools to build crypto coins but when I try to build one the system freezes and I have to reboot to get it working again, I would like to run the crypto coin deamon on the mxq but can't get it to build, it's seems like its running out of ram to build the project. Regards, Andy. I have also tried to setup zram but I get the following :- sudo modprobe zram modprobe: FATAL: Module zram not found in directory /lib/modules/3.10.99 Please Help. Link to comment Share on other sites More sharing options...
verb Posted January 18, 2018 Share Posted January 18, 2018 On 1/16/2018 at 11:34 AM, balbes150 said: The system hangs on reading uImage from a USB drive. Try to stop the launch in the console UART and execute manually the command "printenv" and "help". The result show here. here is the output of printenv : Link here is the output of help : Link and these are the commands i execute from UART: defenv setenv bootfromnand 0 setenv start_usb_autoscript "if fatload usb 0 11000000 s805_autoscript; then autoscr 11000000; fi; if fatload usb 1 11000000 s805_autoscript; then autoscr 11000000; fi; if fatload usb 2 11000000 s805_autoscript; then autoscr 11000000; fi; if fatload usb 3 11000000 s805_autoscript; then autoscr 11000000; fi;" setenv start_autoscript 'if usb start; then run start_usb_autoscript; fi; ' setenv bootcmd 'run start_autoscript; run storeboot' setenv reboot_mode normal saveenv reset Link to comment Share on other sites More sharing options...
balbes150 Posted January 19, 2018 Share Posted January 19, 2018 Connect the flash drive with Armbian (don't forget to add correct dtb file) and run the UART in the console these commands. usb start fatload usb 0 11000000 aml_autoscript autoscr 11000000 The execution result of the show here. Link to comment Share on other sites More sharing options...
verb Posted January 19, 2018 Share Posted January 19, 2018 10 hours ago, balbes150 said: Connect the flash drive with Armbian (don't forget to add correct dtb file) and run the UART in the console these commands. usb start fatload usb 0 11000000 aml_autoscript autoscr 11000000 The execution result of the show here. Here is the output link i havent tried with other dtb images but i guess meson8b_m201_1G.dtb should be mine i have tried dtb for m201 on Libreelec and it works also i have copied the meson8b_m201_1G.dtb from the dtb folder in the provided image. 1991 bytes read ## Executing script at 11000000 MMC: block number 0x1 exceeds max(0x0) ** Can't read from device 0 ** ** Unable to use mmc 0:1 for fatload ** reading uInitrd after 1hour the box outputted this : reading uInitrd 3331991 bytes read reading uImage 5694137 bytes read reading dtb.img 23306 bytes read ## Booting kernel from Legacy Image at 14000000 ... Image Name: Linux-3.10.99 Image Type: ARM Linux Kernel Image (gzip compressed) Data Size: 5694073 Bytes = 5.4 MiB Load Address: 00208000 Entry Point: 00208000 Verifying Checksum ... OK ## Loading init Ramdisk from Legacy Image at 15000000 ... Image Name: uInitrd Image Type: ARM Linux RAMDisk Image (gzip compressed) Data Size: 3331927 Bytes = 3.2 MiB Load Address: 00000000 Entry Point: 00000000 Verifying Checksum ... OK ## Flattened Device Tree blob at 11800000 Booting using the fdt blob at 0x11800000 board_usb_stop cfg: 0 Uncompressing Kernel Image ... OK uboot time: -1804819678 us. EFUSE machid is not set. Using machid 0xf81 from environment From device tree /memory/ node aml_reserved_end property, for relocate ramdisk and fdt, relocate_addr: 0x5337001 Loading Ramdisk to 05009000, end 05336757 ... OK Loading Device Tree to 05000000, end 05008b09 ... OK Starting kernel ... Link to comment Share on other sites More sharing options...
balbes150 Posted January 20, 2018 Share Posted January 20, 2018 The log shows that the file is loaded (but the download is too slow) and the engine is running. Try to start the system manually. Using different dtb. Try checking two options (with different data for the used RAM). 1. options usb start setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0" setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}" fatload usb 0 0x14000000 uImage fatload usb 0 0x15000000 uInitrd fatload usb 0 0x11800000 dtb.img fdt addr 0x11800000 bootm 0x14000000 0x15000000 0x11800000 2. options usb start setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0" setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}" fatload usb 0 0x21000000 uImage fatload usb 0 0x22000000 uInitrd fatload usb 0 0x21800000 dtb.img fdt addr 21800000 bootm 0x21000000 0x22000000 0x21800000 Link to comment Share on other sites More sharing options...
verb Posted January 23, 2018 Share Posted January 23, 2018 On 1/20/2018 at 8:34 AM, balbes150 said: The log shows that the file is loaded (but the download is too slow) and the engine is running. Try to start the system manually. Using different dtb. Try checking two options (with different data for the used RAM). 1. options usb start setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0" setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}" fatload usb 0 0x14000000 uImage fatload usb 0 0x15000000 uInitrd fatload usb 0 0x11800000 dtb.img fdt addr 0x11800000 bootm 0x14000000 0x15000000 0x11800000 2. options usb start setenv condev "console=ttyS0,115200n8 console=tty0 no_console_suspend consoleblank=0" setenv bootargs "root=LABEL=ROOTFS rootflags=data=writeback rw ${condev} fsck.repair=yes net.ifnames=0 mac=${mac}" fatload usb 0 0x21000000 uImage fatload usb 0 0x22000000 uInitrd fatload usb 0 0x21800000 dtb.img fdt addr 21800000 bootm 0x21000000 0x22000000 0x21800000 balbes150 thank you very much for your help . I have finally managed to install armbian on s805 . I have burned armbian on another flash drive and it has booted much faster unfortunately it stucked on Starting kernel ... After that i have changed the dtb . Now it boots Ok Link to comment Share on other sites More sharing options...
arimak Posted February 10, 2018 Share Posted February 10, 2018 On 1/12/2018 at 2:33 PM, balbes150 said: Image update S805 20180112. Updated kernel to version 3.10.99. Added screen mode 1080p. This mode is enabled by default. To switch to 720p you need to edit first line of script /boot/hdmi.sh. For smooth playback of test video I recommend to reduce the window size of the reproduced video to the size that would have enough system resources for smooth video playback. Where can I get linux-headers for this 3.10.99 version? My reason is, that I will probably need aml_i2c.ko driver, which is not unfortunately in modules... So I hope I will be able build the driver alone. Link to comment Share on other sites More sharing options...
balbes150 Posted February 11, 2018 Share Posted February 11, 2018 deb for s805 https://yadi.sk/d/UVhUb9pV3SHAWh Link to comment Share on other sites More sharing options...
temizel Posted March 5, 2018 Share Posted March 5, 2018 On 11.02.2018 at 9:58 AM, balbes150 said: deb for s805 https://yadi.sk/d/UVhUb9pV3SHAWh Hello, I have tested your Ubuntu server image on my MXQ S85 black. This is my first Linux test on this box. First impression is okay but ethernet seems not working. Anyone has same issue? Any workaround? Thank you for work. Link to comment Share on other sites More sharing options...
trulio Posted March 25, 2018 Share Posted March 25, 2018 On 1/15/2018 at 1:31 PM, balbes150 said: Have you tried to load the WiFi module ? Hi, i just tried ubuntu mate and debian stretch icewm on mk808b plus but no wifi availlable. I added an usb dongle to get wifi. iwconfig gives me : wlan0 IEEE 802.11bgn ESSID:"xxxxxx" Nickname:"<WIFI@REALTEK>" Mode:Managed Frequency:2.412 GHz Access Point: 00:24:xxxxx Bit Rate:72.2 Mb/s Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:****-****-****-****-****-****-****-**** Security mode:open Power Management:off Link Quality=98/100 Signal level=-60 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 sit0 no wireless extensions. lo no wireless extensions. ip6tnl0 no wireless extensions. tunl0 no wireless extensions. Regards, Trulio Link to comment Share on other sites More sharing options...
trulio Posted March 25, 2018 Share Posted March 25, 2018 13 minutes ago, trulio said: Hi, i just tried ubuntu mate and debian stretch icewm on mk808b plus but no wifi availlable. I added an usb dongle to get wifi. iwconfig gives me : wlan0 IEEE 802.11bgn ESSID:"xxxxxx" Nickname:"<WIFI@REALTEK>" Mode:Managed Frequency:2.412 GHz Access Point: 00:24:xxxxx Bit Rate:72.2 Mb/s Sensitivity:0/0 Retry:off RTS thr:off Fragment thr:off Encryption key:****-****-****-****-****-****-****-**** Security mode:open Power Management:off Link Quality=98/100 Signal level=-60 dBm Noise level=0 dBm Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0 Tx excessive retries:0 Invalid misc:0 Missed beacon:0 sit0 no wireless extensions. lo no wireless extensions. ip6tnl0 no wireless extensions. tunl0 no wireless extensions. Regards, Trulio Ok, just tried to launch: "sudo modprobe dhd" now wifi works. Thanks for your hard work Link to comment Share on other sites More sharing options...
balbes150 Posted March 29, 2018 Share Posted March 29, 2018 Assembled a test image Volumio for the S805. The first start of the image can take up to 10-15 minutes. https://yadi.sk/d/VYYzN2Hh3Tr8SX The system will be ready for use (login to the web interface) after the login prompt appears on the monitor\TV screen. Link to comment Share on other sites More sharing options...
trulio Posted March 29, 2018 Share Posted March 29, 2018 Hi, i have one question. Can you explain why armbian is not able to boot just using the right dtb.img like would do Libreelec or Lakka? (i was only able to launch the distribution launching first an update with the aml zip file) Thanks, Trulio Link to comment Share on other sites More sharing options...
balbes150 Posted March 30, 2018 Share Posted March 30, 2018 13 hours ago, trulio said: Hi, i have one question. Can you explain why armbian is not able to boot just using the right dtb.img like would do Libreelec or Lakka? (i was only able to launch the distribution launching first an update with the aml zip file) I don't understand your question. Write much detail, what steps you perform. Link to comment Share on other sites More sharing options...
balbes150 Posted March 30, 2018 Share Posted March 30, 2018 Update images 5.41 20180330. The updated kernel. Pay attention, changed the structure of the placement of the images on the website. They are now located in the version directories. Link to comment Share on other sites More sharing options...
