I'm running Armbian from a emmc 16GB card. When I use the web browser the mouse constantly flickers, is there any way to get this to stop? Is there a graphics driver I should have enabled? When I select Additional Hardware Drivers none show up, so maybe there isnt a GPU accelerated driver available. Also switching between desktops feels sluggish. Maybe Im expecting too much performance from a $50 SBC.
Thanks for your help & time in making this distribution. Im just looking to make the best user experience possible.
Armbian uses the mainline kernel and open drivers....  Amlogic has some issues with accelerated desktop... especially with GPU... search the forum and you should find some workarounds for other amlogic boards such as Odroidn2 and Khadas Vim3
If its available you can try the "legacy" kernel via armbian config.... or you might just have to use odroid's image... hope this is helpful.
45 minutes ago, meadrocks said:
Is there any way to install panfrost, the open source mali GPU driver?
Exactly that one has issues, which is why we simply disable it. This way you can at least use it to some degree.
@meadrocks - in xorg something called glamor is used to do acceleration of things you mentioned and glamor is using the opengl functionality of mesa - you can see something like "glamor initialized" in the xorg logs if it was properly enabled
best wishes - hexdump
ps: in case you want to look deeper into this, then having a look at the following links might be interesting
https://forum.odroid.com/viewtopic.php?p=335755&sid=636e08b7c2fd692b0b6a81dbc318741f#p335755
https://github.com/tobetter/linux/commit/a026e2e9f55116e81ed49f48d918fdb91e28eff6
not sure if this will work on the c4 too ...
