CloudShell2 LCD non-functional under Armbian - missing XU4 kernel module.
Well,
I just bought a CloudShell direct from HarkKernel in South Korea. It was delivered and assembled. However, the LCD display - a major selling point - is non-functional. It appears to require a kernel module specific to the odroid xu4 specific kernel, that isn't available in the stock kernel.
I am attempting to compile a 4.x.y kernel from hardkernel sources. So far, 4.14 doesn't appear to work. I want to run Open Media Vault 6, but currently, it only supports Armbian Bullseye, not any Ubuntu, etc. Armbian/OMV works for everything except he LCD.
I am attempting to remedy the issue, but it will mean downgrading my kernel, which may cause other issues. Fingers crossed. Going to try an even older 4.x.y kernel.
Moved to Common issues / peer to peer technical support
Take note that, bug tracker forums - as clearly shown - are dedicated for hardware issues with official Armbian images only.
I forgot to get back here sooner.
It turns out, I didn't need to mess with kernels at all.
I just needed to edit boot.ini, and change the variable cs2enable from false to true. This causes a few overlay files to be loaded and from there, the display and fan work fine.
