rodrigobrochado Posted November 1, 2022 Posted November 1, 2022 Hi guys, First of all, thank you for this amazing project. Armbian rulez. Do you guys have any update on this "reboot" issue? Quote What I did notice when using the Armbian build compared to the official Orange PI 3 LTS Debian build is that sometimes when I use "sudo reboot" the Armbian system wouldn't come back online. Other times the ETH port lights doesn't come on and doesn't work when the system starts up. There seems to be some extra u-boot config needed in the Armbian build to reliably reboot. I see this is a fairly common problem that happened with many other Orange PI boards on Armbian and have been fixed. I have some boards that execute "sudo shutdown -r now" command some times and they also doesn't come back sometimes. I've also seen that there is a Jira ticket open that probably relates to this. I didn't found how Armbian uses Jira and the Jira issue doesn't have any description, so not sure if I can dig more information there. The issue: https://armbian.atlassian.net/browse/AR-1157 I was also having this problem with and old OPI stock OS (downloaded on June of this year so is not the overhauled OPI OS) but couldn't debug it as it was remote. I've have a board locally now, flashed an Armbian 22.08.02 image on the SD Card with bullseye current 5.15.69-sunxi64 and plugged an HDMI monitor. I've made the `update` and `apt upgrade` on it and the distro upgraded to 22.08.08. I've add a crontab that restarts the SBC every 5 minutes. After some minutes, it doesn't restart anymore. I could experience two situations with this problem: 1) The board turn off the green led and the screen keeps black forever. The CPU and the power supply case keeps hot, above normal operation. If I hold power button for 5 seconds (so I think it forces cold shutdown) and then hold again for 2 seconds, the boards then starts normally (turn on the green led and the screen show boot log) 2) The screen show the shutdown log but stop forever and the two last messages are always the same (below). Temperature and restart button behavior is equal to situation "1". The messages: [uptime..] systemd-shutdown[1]: Waiting for process: grep, lscpu [uptime..] systemd-shutdown[1]: Waiting for process: lscpu, grep The problem on 2 is reported for Linux mainstream in many places on internet, but all related to slow shutdown process, not shutdown hanging. Any tips here? It seems that @Ukhellfire is away. 0 Quote
pierre-pret Posted August 11, 2023 Posted August 11, 2023 On 11/1/2022 at 5:59 PM, rodrigobrochado said: 1) The board turn off the green led and the screen keeps black forever. The CPU and the power supply case keeps hot, above normal operation. If I hold power button for 5 seconds (so I think it forces cold shutdown) and then hold again for 2 seconds, the boards then starts normally (turn on the green led and the screen show boot log) I found the same restart problem. If I take the latest official Orange PI debian bullseye image and copy /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb and the /boot/dtb/allwinner/overlay/*h6* files to the Armbian debian bullseye image (5.1 kernel downloadable under archive, not latest) then the reboot problem is resolved. 0 Quote
Igor Posted August 11, 2023 Posted August 11, 2023 2 hours ago, pierre-pret said: then the reboot problem is resolved. Now unpack both files (DTB to DTS) and run diff on files. That might reveal some clues. 0 Quote
Aleksey Vasenev Posted June 15, 2024 Posted June 15, 2024 (edited) Can't up ethernet link in some kernels. 6.1.92 work 6.6.16 don't work 6.6.31 don't work 6.7.4 don't work 6.7.12 don't work In dmesg last line missing when don't work: [ 11.875133] dwmac-sun8i 5020000.ethernet eth0: Register MEM_TYPE_PAGE_POOL RxQ-0 [ 12.125838] dwmac-sun8i 5020000.ethernet eth0: PHY [stmmac-0:01] driver [YT8531 Gigabit Ethernet] (irq=POLL) [ 12.125907] dwmac-sun8i 5020000.ethernet eth0: No Safety Features support found [ 12.125917] dwmac-sun8i 5020000.ethernet eth0: No MAC Management Counters available [ 12.125925] dwmac-sun8i 5020000.ethernet eth0: PTP not supported by HW [ 12.126603] dwmac-sun8i 5020000.ethernet eth0: configuring for phy/rgmii-id link mode [ 15.202402] dwmac-sun8i 5020000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx But in very rare cases the link still goes up. There is also a remote second similar device, it works without problems. Incompatibility with router? The USB network card works without problems. Edited June 15, 2024 by Aleksey Vasenev 0 Quote
Asanali Bulatov Posted October 5, 2025 Posted October 5, 2025 Small guide for fixing Ethernet on the latest Armbian. 1. Make sure you have the correct device: cat /proc/device-tree/model → OrangePi 3 LTS 2. Decompile the dtb to dts: dtc -I dtb -O dts /boot/dtb/allwinner/sun50i-h6-orangepi-3-lts.dtb -o ./sun50i-h6-orangepi-3-lts.dts 3. Check the correct pins (yours may differ): grep -i reset-gpio sun50i-h6-orangepi-3-lts.dts | head -n 1 → reset-gpios = <0x1e 0x03 0x0e 0x01>; 4. Create the file sun50i-h6-ethernet.dts. Use the provided template and substitute your pin values. My file for example: /dts-v1/; /plugin/; / { compatible = "allwinner,sun50i-h6"; fragment@0 { target = <&emac>; __overlay__ { snps,reset-gpio = <0x1e 0x03 0x0e 0x01>; snps,reset-delays-us = <0 10000 1000000>; snps,reset-active-low; mdio { ethernet-phy@1 { reset-gpios; reset-assert-us; reset-deassert-us; }; }; }; }; }; 5. Add your overlay: armbian-add-overlay sun50i-h6-ethernet.dts 6. Reboot and enjoy working Ethernet: reboot 2 Quote
