Orange Pi3 lts
igorh
On 3/26/2022 at 1:53 PM, Ukhellfire said:
SCRAP THAT!!
I missed something on that last one...
Try this one:
https://drive.google.com/drive/folders/1B7A_pc3W6GLBjt9vAkShh5scp4pQwFrc
Downloaded 2 times and checksum don't match, every time same wrong checksum. Expected:
609de716873f3c12db95878c39064d13a66e06f1e1c528e28049db9635fd4d66
got
cd721c9a1525e36072d4458e6730c1cf8774dbdffbfbf5e45601580d1cb024dd
Maybe something wrong with upload?
Link to comment
Share on other sites
got
Let me re-upload and I'll let you know
Img re-uploaded...
https://drive.google.com/file/d/1HUbTWB0GABIVviS3349FN11S0_Wy2jDN/view?usp=drivesdk
Fingers crossed!
Any chance of logs of you get to it @Kamileon
Link to comment
Img re-uploaded...
Fingers crossed!
It's still not booting. I'm not sure how to copy a dmesg from initramfs, but it looks similar to a lot of other dmesg logs posted here with those same pins.
Link to comment
OK thank you. Just now how the hell do I start Debugging this?
Random question, but do you have plugged in when you boot? And to what ports?
Link to comment
7 minutes ago, Rockford the Roe said:
I use the USB C outlet provided by the bundle I purchased. The only thing that's plugged in besides that is my keyboard on the top USB 3.0 port
OK thanks. I wanted to try and replicate this. But still booting this end.
I really don't know what to try next? It doesn't make any sense to me?
I'm now using the exact setup and files orangepi uses just with armbian. Unless orangepi have modified their kernel in someway or something.
All dts files seem good. Even all the regulators and everything.
Does anyone know anyone that can help with this?
Link to comment
I wonder if it's because of my 60Hz / 120V standard in my country. But that wouldn't make sense if the BSP debian image boots up properly.
Link to comment
I suppose it could do. I'm really at a loss here... and without being able to have the same issues this end, I'm stuffed! Haha!
Link to comment
5 часов назад, Ukhellfire сказал:
For me this your image not booting too!
3 people say that this not booting - maybe you doing some wrong?
For me linux stoping booting - cant find root partition  -and stay in initramfs
From uboot i'm dont see any partitons besides FAT partiton - this is normal?
Please make clean build without xfce desktop - only minimal rootfs.
And please activate uart in kernel to debuggin messages - current showing nothing after uboot load kernel image..
And i'm not understand what you doing - you trying porting armbian kernel for orange pi 3 to orange pi 3 lts?
Link to comment
Yup, still not booting on my end also,
Dmesg:
https://nextcloud.lodz.webredirect.org/s/et7DNigcAzrfRkq
UART boot:
picocom v3.1
port is        : /dev/ttyUSB0
flowcontrol    : none
baudrate is    : 115200
parity is      : none
databits are   : 8
stopbits are   : 1
escape is      : C-a
local echo is  : no
noinit is      : no
noreset is     : yes
hangup is      : no
nolock is      : yes
send_cmd is    : sz -vv
receive_cmd is : rz -vv -E
imap is        :
omap is        :
emap is        : crcrlf,delbs,
logfile is     : none
initstring     : none
exit_after is  : not set
exit is        : no
Type [C-a] [C-h] to see available commands
Terminal ready
U-Boot SPL 2021.10-armbian (Mar 27 2022 - 12:15:39 +0100)
DRAM: 2048 MiB
Trying to boot from MMC1
NOTICE:  BL31: v2.2(debug):a04808c1-dirty
NOTICE:  BL31: Built : 12:15:19, Mar 27 2022
NOTICE:  BL31: Detected Allwinner H6 SoC (1728)
NOTICE:  BL31: Found U-Boot DTB at 0xc07c1b0, model: OrangePi 3 LTS
INFO:    ARM GICv2 driver initialized
NOTICE:  PMIC: Probing AXP805
NOTICE:  PMIC: AXP805 detected
INFO:    BL31: Platform setup done
INFO:    BL31: Initializing runtime services
INFO:    BL31: cortex_a53: CPU workaround for 855873 was applied
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x4a000000
INFO:    SPSR = 0x3c9
U-Boot 2021.10-armbian (Mar 27 2022 - 12:15:39 +0100) Allwinner Technology
CPU:   Allwinner H6 (SUN50I)
Model: OrangePi 3 LTS
DRAM:  2 GiB
MMC:   mmc@4020000: 0, mmc@4022000: 1
Loading Environment from FAT... Unable to use mmc 0:1... In:    serial@5000000
Out:   serial@5000000
Err:   serial@5000000
Net:   No ethernet found.
Autoboot in 1 seconds, press <Space> to stop
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
3202 bytes read in 3 ms (1 MiB/s)
## Executing script at 4fc00000
U-boot loaded from SD
Boot script loaded from mmc
154 bytes read in 3 ms (49.8 KiB/s)
37751 bytes read in 6 ms (6 MiB/s)
3844 bytes read in 7 ms (536.1 KiB/s)
Applying kernel provided DT fixup script (sun50i-h6-fixup.scr)
## Executing script at 45000000
12463018 bytes read in 618 ms (19.2 MiB/s)
21735432 bytes read in 1076 ms (19.3 MiB/s)
Moving Image from 0x40080000 to 0x40200000, end=41710000
## Loading init Ramdisk from Legacy Image at 4ff00000 ...
   Image Name:   uInitrd
   Data Size:    12462954 Bytes = 11.9 MiB
   Load Address: 00000000
   Entry Point:  00000000
   Verifying Checksum ... OK
## Flattened Device Tree blob at 4fa00000
   Booting using the fdt blob at 0x4fa00000
   Loading Ramdisk to 4941d000, end 49fffb6a ... OK
   Loading Device Tree to 00000000493ab000, end 000000004941cfff ... OK
Starting kernel ...
Link to comment
3 hours ago, Rockford the Roe said:
I'm not sure how useful this would be, but I generated some patch files of the 5.16 BSP kernel and 2020.04 u-boot compared to their vanilla upstreams to try to get an idea of how those two differ. I've attached them.
Thanks! That's alot to read through! But it could help!
OK I shall do this.
I shall do this too! Haha!
No in fact, I'm trying to bring up the board as a new board. I've taken orangepis config files, and put them across to armbian.
I'll link my repos
Build:
https://github.com/afaulkner420/build
Kernel:
https://github.com/afaulkner420/linux-5.15-opi3-lts
Uboot:
https://github.com/afaulkner420/uboot
This is my progress so far... feel free to play! Haha!
Link to comment
25 минут назад, Ukhellfire сказал:
I'll link my repos
You can try orangepi-build system to build working ubuntu with desktop and with working all stuff with 5.10 kernel -
https://github.com/orangepi-xunlong/orangepi-build
But if you need armbian - yes need make proper patches to current armbian kernel for sunxi.. But with current patches for orange pi 3 - i'm think OS should booting (but without emmc wifi and ethernet,  wich simple to porting)..
Link to comment
They also have a 5.16 branch.
https://github.com/orangepi-xunlong/linux-orangepi/tree/orange-pi-5.16-sunxi64
https://github.com/orangepi-xunlong/linux-orangepi/commit/6cb6eb3553db63e80b133a13f3868f5ca8d760ab#commitcomment-69513212
I just wanted to get armbian working. I don't see any reason why it shouldn't??
Link to comment
Только что, Ukhellfire сказал:
Yout trying booting orange pi 3 armbian on lts version?
6 минут назад, Ukhellfire сказал:
Yes - take from this only wifi and ethernet driver for lts, than using armbian orange pi 3 kernel and add needed patches for emmc, wifi and ethernet - where you have problem adding this?
Link to comment
I don't have a problem at all. If you look at my repos, I've done it.
And as you can see from my dmesg, it's working! I have working ethernet, wifi, haven't checked emmc though...
Dmesg here:
https://drive.google.com/file/d/1LQ5qgTZBLdhauLeqD3OArM8ci2uzLdnb/view?usp=drivesdk
Link to comment
15 минут назад, Ukhellfire сказал:
I'm never build armbian and dont know all - but please say me - how you compile armbian system with your kernel, when armbian using 5.15 clean kernel and adding needed pacthes, which current only for orange pi 3 - you edit build scripts to using your kernel or how?
And i'm see that kernel in your repo dont have patches for sunxi_mmc.c driver - fix for h6  - emmc not working for you?
Link to comment
I'm patching the kernel that armbian downloads.
The emmc patch I'd there. I had a different repo.
I'll zip up my patches and link you.
https://drive.google.com/file/d/1oit5pTA2J68mjmsQqAnoJQIhwC-R071o/view?usp=drivesdk
They are my kernel and uboot userpatches.
Link to comment
But armbian build system clean kernel sources every time while compile  - no? And armbian make patching kernel which have your patches?
Link to comment
Yes that's right. Then my patches and all the other patches for sunxi get applied. My patches are from the orange pi 5.16 bring up. Which funnily enough, was mainline, and orangepi applied armbians patches to it.
https://github.com/orangepi-xunlong/linux-orangepi/commit/00fef0e5e3dea1a3dd45fe35a6da209d005595e6
Link to comment
1 час назад, Ukhellfire сказал:
Ok. thank. i'm try build and reply..
Link to comment
OK thanks. Will be interesting in what you find!
If you use my build repo, and then the patches I gave you, it should fully build without errors or anything. The  you should be at the same place I am...
Link to comment
17 минут назад, Ukhellfire сказал:
Ok.
What about audio codec internal - 3.5 jack working?
P.S. I'm run Glodroid :) But when enable bluetooth module - android crash and restart - without working.. ;)
Link to comment
6 minutes ago, sekil said:
Ok.
I haven't tried this yet. From my original understanding, it's never been working. But I'm not sure on what they've done in the latest months. The seem to enable ac200 audio or something?
https://github.com/orangepi-xunlong/linux-orangepi/commit/3b75d984852c04151e9bba741473d3810ab72753
I believe the Bluetooth crash is due to the macadress.
https://github.com/orangepi-xunlong/linux-orangepi/commit/d15ff3cb548f6ad056a881720cb29860226a2ab3
Link to comment
Yes enabling ac200 and axp00 audio codec.. but i'm think this is not internal h6 audio codec.. strange..
No this patch add mac randomise - because of without mac always same for all boards..
Link to comment
Yeah they told me that the driver didn't exist! Now all of a sudden it does. Like you say, strange!
Ah OK. I haven't looked into it much. And I didn't try connecting anything when i had it working. Have you tried the hciattach methods on orangepis repos?
Link to comment
3 часа назад, Ukhellfire сказал:
Not booting!
Try using stock uboot for orange pi 3 - i'm think you adding some bugs with your uboot patches or maybe build system have bugs..
after writing image to sd card - i'm cant see any partitions besides fat -
Environment size: 4621/131068 bytes
=> mmc part
Partition Map for MMC device 0  --   Partition Type: DOS
Part    Start Sector    Num Sectors     UUID            Type
  1     8192            2039808         aa174f31-01     83
But from your configs - need using partition 2!
Link to comment
