IgorS Posted February 19, 2022 Posted February 19, 2022 Hi, Please help. I am building kernel using armbian build system for a long time, but in past two releases of current kernel (5.15.23 and 5.15.53) I am getting errors while installing: modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/drivers/cdrom/cdrom.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/isofs/isofs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/jfs/jfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/reiserfs/reiserfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/udf/udf.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/xfs/xfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/netfs/netfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/fscache/fscache.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/net/sunrpc/sunrpc.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs_common/grace.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/lockd/lockd.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs/nfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs/nfsv2.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs_common/nfs_acl.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs/nfsv3.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nfs/nfsv4.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/drivers/input/mouse/psmouse.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/fs/nls/nls_iso8859-1.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/drivers/extcon/extcon-usb-gpio.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/lib/842/842_decompress.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.24-sunxi/kernel/drivers/md/dm-mod.ko.xz not found. but kernel works and all listed modules are in place when I look with ls. Is this kernel corrupt or can I ignore this messages?
Igor Posted March 3, 2022 Posted March 3, 2022 On 2/19/2022 at 12:42 PM, IgorS said: I am building kernel using armbian build system There were some changes in the packaging process, but we didn't notice this kind of troubles. Can you provide more info - are you changing anything in the build process and what? How to reproduce this? @goingAny clues?
IgorS Posted March 3, 2022 Author Posted March 3, 2022 I tested today with same result. My machine is virtual machine under proxmox: igor@armbian:~/trash$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.4 LTS Release: 20.04 Codename: focal igor@armbian:~/trash$ uname -a Linux armbian 5.4.0-102-generic #115-Ubuntu SMP Wed Feb 23 14:57:18 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux igor@armbian:~/trash$ free total used free shared buff/cache available Mem: 8149732 282268 1862724 2488 6004740 7553428 Swap: 8388604 3584 8385020 igor@armbian:~/trash$ All OS updates are installed To be sure, I started from the begiining with: rm -rf build git clone --depth 1 https://github.com/armbian/build cd build ./compile.sh I choose: U-boot and kernel packages Do not change the kernel configuration orangepione Allwinner H3 quad core 512MB RAM SoC current Recommended. Come with best support After compilation done, copied packages to my test system and installed them: igor@honeypot:~/trash/kernel$ ls -1 armbian-config_22.05.0-trunk_all.deb armbian-firmware_22.05.0-trunk_all.deb linux-dtb-current-sunxi_22.05.0-trunk_armhf.deb linux-headers-current-sunxi_22.05.0-trunk_armhf.deb linux-image-current-sunxi_22.05.0-trunk_armhf.deb linux-libc-dev_22.05.0-trunk_armhf.deb linux-u-boot-current-orangepione_22.05.0-trunk_armhf.deb igor@honeypot:~/trash/kernel$ sudo dpkg -i * [sudo] password for igor:............. (Reading database ... 77393 files and directories currently installed.) Preparing to unpack armbian-config_22.05.0-trunk_all.deb ... Unpacking armbian-config (22.05.0-trunk) over (22.02.18) ... Preparing to unpack armbian-firmware_22.05.0-trunk_all.deb ... Unpacking armbian-firmware (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-dtb-current-sunxi_22.05.0-trunk_armhf.deb ... Unpacking linux-dtb-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-headers-current-sunxi_22.05.0-trunk_armhf.deb ... Unpacking linux-headers-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-image-current-sunxi_22.05.0-trunk_armhf.deb ... update-initramfs: Deleting /boot/initrd.img-5.10.96-sunxi Removing obsolete file uInitrd-5.10.96-sunxi Unpacking linux-image-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-libc-dev_22.05.0-trunk_armhf.deb ... Unpacking linux-libc-dev:armhf (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-u-boot-current-orangepione_22.05.0-trunk_armhf.deb ... Unpacking linux-u-boot-orangepione-current (22.05.0-trunk) over (22.02.18) ... Setting up armbian-config (22.05.0-trunk) ... Setting up armbian-firmware (22.05.0-trunk) ... Setting up linux-dtb-current-sunxi (22.05.0-trunk) ... Setting up linux-headers-current-sunxi (22.05.0-trunk) ... Compiling headers - please wait ... Setting up linux-image-current-sunxi (22.05.0-trunk) ... update-initramfs: Generating /boot/initrd.img-5.15.26-sunxi modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/cdrom/cdrom.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/isofs/isofs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/jfs/jfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/reiserfs/reiserfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/udf/udf.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/xfs/xfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/netfs/netfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/fscache/fscache.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/net/sunrpc/sunrpc.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs_common/grace.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/lockd/lockd.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv2.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs_common/nfs_acl.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv3.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv4.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/input/mouse/psmouse.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nls/nls_iso8859-1.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/extcon/extcon-usb-gpio.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/lib/842/842_decompress.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/md/dm-mod.ko.xz not found. update-initramfs: Converting to u-boot format Setting up linux-libc-dev:armhf (22.05.0-trunk) ... Setting up linux-u-boot-orangepione-current (22.05.0-trunk) ... igor@honeypot:~/trash/kernel$ My test system is OrangePi One: igor@honeypot:~/trash$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.6 LTS Release: 18.04 Codename: bionic So, I have no idea whats's wrong. Attached please find compressed build/debug directory if this can help to identify problem. debug.tgz
Werner Posted March 3, 2022 Posted March 3, 2022 Retried with Hirsute or Impish? Focal is not a supported build environment. https://docs.armbian.com/Developer-Guide_Build-Preparation/
IgorS Posted March 3, 2022 Author Posted March 3, 2022 Ok. Il try, but I didn't have problems until 5.15 becomes current branch.
IgorS Posted March 3, 2022 Author Posted March 3, 2022 Unfortunatelly same story. Built in clean impish install: igor@honeypot:~/trash/kernel$ ls -1 armbian-config_22.05.0-trunk_all.deb armbian-firmware_22.05.0-trunk_all.deb linux-dtb-current-sunxi_22.05.0-trunk_armhf.deb linux-headers-current-sunxi_22.05.0-trunk_armhf.deb linux-image-current-sunxi_22.05.0-trunk_armhf.deb linux-libc-dev_22.05.0-trunk_armhf.deb linux-u-boot-current-orangepione_22.05.0-trunk_armhf.deb igor@honeypot:~/trash/kernel$ sudo dpkg -i * [sudo] password for igor: (Reading database ... 77393 files and directories currently installed.) Preparing to unpack armbian-config_22.05.0-trunk_all.deb ... Unpacking armbian-config (22.05.0-trunk) over (22.02.18) ... Preparing to unpack armbian-firmware_22.05.0-trunk_all.deb ... Unpacking armbian-firmware (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-dtb-current-sunxi_22.05.0-trunk_armhf.deb ... Unpacking linux-dtb-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-headers-current-sunxi_22.05.0-trunk_armhf.deb ... Unpacking linux-headers-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-image-current-sunxi_22.05.0-trunk_armhf.deb ... update-initramfs: Deleting /boot/initrd.img-5.10.96-sunxi Removing obsolete file uInitrd-5.10.96-sunxi Unpacking linux-image-current-sunxi (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-libc-dev_22.05.0-trunk_armhf.deb ... Unpacking linux-libc-dev:armhf (22.05.0-trunk) over (22.02.18) ... Preparing to unpack linux-u-boot-current-orangepione_22.05.0-trunk_armhf.deb ... Unpacking linux-u-boot-orangepione-current (22.05.0-trunk) over (22.02.18) ... Setting up armbian-config (22.05.0-trunk) ... Setting up armbian-firmware (22.05.0-trunk) ... Setting up linux-dtb-current-sunxi (22.05.0-trunk) ... Setting up linux-headers-current-sunxi (22.05.0-trunk) ... Compiling headers - please wait ... Setting up linux-image-current-sunxi (22.05.0-trunk) ... update-initramfs: Generating /boot/initrd.img-5.15.26-sunxi modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/cdrom/cdrom.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/isofs/isofs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/jfs/jfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/reiserfs/reiserfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/udf/udf.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/xfs/xfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/netfs/netfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/fscache/fscache.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/net/sunrpc/sunrpc.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs_common/grace.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/lockd/lockd.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv2.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs_common/nfs_acl.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv3.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nfs/nfsv4.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/input/mouse/psmouse.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/fs/nls/nls_iso8859-1.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/extcon/extcon-usb-gpio.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/lib/842/842_decompress.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.26-sunxi/kernel/drivers/md/dm-mod.ko.xz not found. update-initramfs: Converting to u-boot format Setting up linux-libc-dev:armhf (22.05.0-trunk) ... Setting up linux-u-boot-orangepione-current (22.05.0-trunk) ...
IgorS Posted March 3, 2022 Author Posted March 3, 2022 Well, some progress made... It is something related to distribution. Same kernel on focal installs without errors, while on bionic errors appeared. ???
Igor Posted March 3, 2022 Posted March 3, 2022 18 minutes ago, IgorS said: while on bionic errors appeared. https://github.com/armbian/build/blob/master/config/distributions/bionic/support Bionic has no more support status from our perspective. We don't test it anymore nor fix bugs. Focal is going to be old stable in 2 months after Jammy got out. We can't deal with that many options ...
IgorS Posted March 3, 2022 Author Posted March 3, 2022 Thanks. Just writting this because somebody will faced same problem.
going Posted March 4, 2022 Posted March 4, 2022 03.03.2022 в 13:17, IgorS сказал: My machine is virtual machine under proxmox: igor@armbian:~/trash$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 20.04.4 LTS Release: 20.04 Codename: focal 03.03.2022 в 13:17, IgorS сказал: My test system is OrangePi One: igor@honeypot:~/trash$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 18.04.6 LTS Release: 18.04 Codename: bionic I think you were lucky and you saw the tip of the iceberg and changed course at the right moment. 03.03.2022 в 09:32, Igor сказал: @goingAny clues? @Igor I can only say what is the logic of building a package in another build system. The first thing I have to specify is the name and version of the OS for which I need to build the package. Secondly, I have to choose the virtual machine option. Next, a clean build environment for this particular operating system will be created inside the specified VM. And I see all the build errors and dependency issues. It is this logic that is implemented in the current Armbian for assembly in a chroot environment.
