/var/log is 100% full - how to move to HDD?
Schlotze83!
Gents,
installed Armbian Bullseye successfully to my Banana Pi M2 Berry. In second step i moved the OS to my attached 2,5 WD RED Sata Harddrive. This was easily possible with the command "sudo nand-sata-install".
But now, i see that my /var/log is full, because its located in ZRAM.
root@BananaPiM2Berry:/etc/systemd/system# df -h
Filesystem      Size  Used Avail Use% Mounted on
udev            431M     0  431M   0% /dev
tmpfs           100M   11M   90M  11% /run
/dev/sda1       687G  1,3G  651G   1% /
tmpfs           500M     0  500M   0% /dev/shm
tmpfs           5,0M  4,0K  5,0M   1% /run/lock
tmpfs           500M     0  500M   0% /tmp
/dev/mmcblk0p1  1,7G  1,3G  385M  77% /media/mmcboot
/dev/zram1       49M   48M     0 100% /var/log
tmpfs           100M     0  100M   0% /run/user/1000
As you can see i hve more than 650 GB avail in my root parttiion on /dev/sda1. But how can i setup /var/log to wirte on /dev/sda1 ?
i believed to find it in /etc/fstab, but its not there.
# <file system>                                 <mount point>   <type>  <options>                                                       <dump>  <pass>
tmpfs                                           /tmp            tmpfs   defaults,nosuid                                                 0       0
UUID=7fe45d82-d362-438a-9b7a-baa3678fcab4       /media/mmcboot  ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide       0       1
/media/mmcboot/boot                             /boot           none    bind                                                            0       0
UUID=614c4feb-de66-4b2c-a046-ce72aaf2e600       /               ext4    defaults,noatime,commit=600,errors=remount-ro,x-gvfs-hide       0       1
Right now, the device is unuseable, i cant even install system updates, since no more logs can be written. Since i have so much storage avail on my HDD, i wonder how to move /var/log there...
Greatings
Schlotze
Link to comment
Share on other sites
Thanks so much, looks like i made it , wa?
tmpfs           100M    724K  100M    1% /run
tmpfs           500M    4,0K  500M    1% /tmp
Link to comment
