Which driver uses Armbian for Realtek ID 0bda:b812 USB3 WiFi N/AC card?
OrangePi 4,
Question in subject as I found at least 3:
- https://github.com/morrownr/88x2bu
- https://github.com/fastoe/RTL8812BU
- # REALTEK RTL88x2B USB Linux Driver
**Current Driver Version**: 5.13.1
**Support Kernel**: 2.6.24 ~ 5.17 (with unofficial patches) (forgot URL).
On Armbian system "automagically" configures card after inserting, can configure as AP, only iwconfig shows as follow:
wlxb44bd62f536b  IEEE 802.11bgn  ESSID:"ARMBIAN"  Nickname:"<WIFI@REALTEK>"
          Mode:Master  Frequency:5.2 GHz  Access Point: B4:4B:D6:2F:53:6B
          Bit Rate:300 Mb/s   Sensitivity:0/0
          Retry:off   RTS thr:off   Fragment thr:off
          Encryption key:off
          Power Management:off
          Link Quality=1/100  Signal level=1/100  Noise level=0/100
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0   Missed beacon:0
No mention of A / AC.
root@orangepi4:~# lsmod | grep 88
88x2bu               2506752  0
Driver (both Realtek and "morrownr") on x86_64 is much bigger - 3MB+.
root@orangepi4:~# armbianmonitor -u
System diagnosis information will now be uploaded to no results to fetchPlease post the URL in the forum where you've been asked for.
System diagnosis information will now be uploaded to curl: (52) Empty reply from server
System diagnosis information will now be uploaded to http://ix.io/3RPY
Edited by laurentppol
Added armbianmonitor -u output.
Pls move BACK, just provided armbianmonitor -u output!.
And my question is NOT a bug report, "3rd party HW" WORKS, but I have some questions. And help choosing right driver on x86_64 PC.
Thanks for clarifying.
However First Bug tracker is - as the name implies- for bugs  only and second these [bug tracker] forums also cannot cover anything beyond integrated board hardware functions.
Therefore I am sorry but the topic will not be moved back. Thanks for understanding.
Ok, You want to be "strict":
- it IS a bug report:
- look at the output of iwconfig!
Card is WiFi AC and utility shows 300Mbps! It N, not AC troughtput!
Also, I have connected 2 of such cards, and iperf shows ONLY <150Mbps! Both on USB3. 2m apart.
I want to do some investigation, but question in subject remains also.
