Dams2000 Posted March 10, 2022 Share Posted March 10, 2022 Hello everyone, i'm a noob, can you tell me the step by step procedure to launch this version in good condition for the Ugoos am6B plus please? Thank you Cordially 1 Link to comment Share on other sites More sharing options...
NicoD Posted March 10, 2022 Share Posted March 10, 2022 I moved this to the correct place. 14 часов назад, Dams2000 сказал: can you tell me the step by step procedure to launch this version in good condition for the Ugoos am6B plus please ? I have not used Armbian on tv-box in a long time. My guess. 1. Write image to sd-card. 2. Mount sd-card in a Linux environment. 3. Change the armbianEnv.txt (or another Env file in the /boot directory) to point towards the correct dtb file for your device. (4) Might be needed that you press a boot button to boot it. That might be in the 2.5mm audio connector. Use a toothpick to press it and power the board. Read around in the TV-box club for more info. Link to comment Share on other sites More sharing options...
SteeMan Posted March 10, 2022 Share Posted March 10, 2022 @Dams2000 There is no one involved in the ophub project that participates in these armbian forums. I don't know why they refer to those builds as armbian as they have no tie to the armbian project, other than they have forked off of armbian. You will need to contact the authors of that code to get an answer to your question. Link to comment Share on other sites More sharing options...
