t3l3m4k0 Posted March 17, 2022 Posted March 17, 2022 I am using Armbian for a long time on mi Orangepi mini (A20), board not supported but installing image Bananapi M1 it has been working very well adding fdtfile=sun7i-a20-orangepi-mini.dtb on /boot/armbianEnv.txt After running apt upgrade kernel package is upgraded from 5.10.60-sunxi to 5.15.25-sunxi i get this errors: S'està configurant linux-image-current-sunxi (22.02.1)… update-initramfs: Generating /boot/initrd.img-5.15.25-sunxi modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/drivers/cdrom/cdrom.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/isofs/isofs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/jfs/jfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/reiserfs/reiserfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/udf/udf.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/xfs/xfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/netfs/netfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/fscache/fscache.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/net/sunrpc/sunrpc.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs_common/grace.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/lockd/lockd.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs/nfs.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs/nfsv2.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs_common/nfs_acl.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs/nfsv3.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/fs/nfs/nfsv4.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/drivers/input/mouse/psmouse.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/drivers/extcon/extcon-usb-gpio.ko.xz not found. modinfo: ERROR: Module /lib/modules/5.15.25-sunxi/kernel/drivers/md/dm-mod.ko.xz not found. modules exist but system can't install. on kernel.log i see lot of messages like "Module has invalid ELF structures" uname -r sends 5.15.25-sunxi if i try via modprobe, modinfo, insmod i get error i will appreciate any guide.
rgala Posted March 18, 2022 Posted March 18, 2022 I have the same issue on Cubietruck. No modules load after reboot. When I try to load them manually using modprobe I get „exec format error”. Kern.log also contains „Module has invalid ELF structures” messages.
hal8k Posted April 10, 2022 Posted April 10, 2022 I have exactly the same but on OrangePiZero I did a manual sudo apt-get update sudo apt-get upgrade Just before I rebooted, I tried a lsmod and no modules were found with kernel 5.15.25 I tried to run modinfo and it told me could not get module info "exec format error" I posted a screenshot: https://imgur.com/a/7VBkrnt Is this a common problem with a kernel upgrade, to 5.15.25 ? This is three different boards but same kernel. I'm going to have to reload my image as I cannot access my orage pi zero now.
Werner Posted April 11, 2022 Posted April 11, 2022 Hm interesting. Modules are now xz compressed. In 5.10 they were not... can somebody try building a kernel with this change and see if the issue persists? https://github.com/armbian/build/pull/3663
hal8k Posted April 13, 2022 Posted April 13, 2022 Hi Werner, Yes I'd like to try and help out. I have OPi zero Ver1.5 and can cross compile from my linux mint 64bit desktop. Have also got a git account. Is it just a matter of: git clone https://github.com/armbian/build cd build ./compile.sh After the kernel is built is it just a matter of copying the kernel into the Orange Pi and rebooting. Or will I have to build the modules? Thanks for further advice.
Werner Posted April 13, 2022 Posted April 13, 2022 Either checkout the pull request or build from master with kernel configuration changed by yourself like mentioned here: https://github.com/armbian/build/pull/3663/files
going Posted April 19, 2022 Posted April 19, 2022 Gentlemen! Please publish the name of the OS on which you detected this error after the update.
going Posted April 19, 2022 Posted April 19, 2022 leo@bananapim3:~$ lsb_release -rc Release: 20.04 Codename: focal leo@bananapim3:~$ sudo modinfo sun4i_gpadc_iio filename: /lib/modules/5.17.3-sunxi/kernel/drivers/iio/adc/sun4i-gpadc-iio.ko.xz license: GPL v2 author: Quentin Schulz <quentin.schulz@free-electrons.com> description: ADC driver for sunxi platforms alias: of:N*T*Callwinner,sun50i-a64-thsC* alias: of:N*T*Callwinner,sun50i-a64-ths alias: of:N*T*Callwinner,sun9i-a80-thsC* alias: of:N*T*Callwinner,sun9i-a80-ths alias: of:N*T*Callwinner,sun8i-a83t-thsC* alias: of:N*T*Callwinner,sun8i-a83t-ths alias: of:N*T*Callwinner,sun8i-h3-thsC* alias: of:N*T*Callwinner,sun8i-h3-ths alias: of:N*T*Callwinner,sun8i-a33-thsC* alias: of:N*T*Callwinner,sun8i-a33-ths alias: platform:sun6i-a31-gpadc-iio alias: platform:sun5i-a13-gpadc-iio alias: platform:sun4i-a10-gpadc-iio depends: industrialio intree: Y name: sun4i_gpadc_iio vermagic: 5.17.3-sunxi SMP mod_unload ARMv7 thumb2 p2v8 I don't have such a mistake. Collected the image yesterday April 18, 2022
rgala Posted April 19, 2022 Posted April 19, 2022 7 hours ago, going said: Gentlemen! Please publish the name of the OS on which you detected this error after the update. Ubuntu 18.04 (Bionic)
going Posted April 19, 2022 Posted April 19, 2022 1 час назад, rgala сказал: Ubuntu 18.04 (Bionic) That's the problem. And I think the problem is not that it's a different OS. And the fact is that the kernel is initially assembled in the environment of another OS. Can we check it out if you agree? I will build a kernel package in this OS 18.04. Or update the operating system.
t3l3m4k0 Posted April 20, 2022 Author Posted April 20, 2022 On 4/19/2022 at 10:10 AM, going said: Gentlemen! Please publish the name of the OS on which you detected this error after the update. Sorry for delay usuari@orpimini:~$ lsb_release -rc Release: 9.13 Codename: stretch and for module sample you request: usuari@orpimini:~$ sudo modinfo sun4i_gpadc_iio [sudo] contrasenya per a usuari: filename: /lib/modules/5.10.60-sunxi/kernel/drivers/iio/adc/sun4i-gpadc-ii o.ko license: GPL v2 author: Quentin Schulz <quentin.schulz@free-electrons.com> description: ADC driver for sunxi platforms alias: of:N*T*Callwinner,sun50i-a64-thsC* alias: of:N*T*Callwinner,sun50i-a64-ths alias: of:N*T*Callwinner,sun9i-a80-thsC* alias: of:N*T*Callwinner,sun9i-a80-ths alias: of:N*T*Callwinner,sun50i-h5-thsC* alias: of:N*T*Callwinner,sun50i-h5-ths alias: of:N*T*Callwinner,sun8i-a83t-thsC* alias: of:N*T*Callwinner,sun8i-a83t-ths alias: of:N*T*Callwinner,sun8i-h3-thsC* alias: of:N*T*Callwinner,sun8i-h3-ths alias: of:N*T*Callwinner,sun8i-a33-thsC* alias: of:N*T*Callwinner,sun8i-a33-ths alias: platform:sun6i-a31-gpadc-iio alias: platform:sun5i-a13-gpadc-iio alias: platform:sun4i-a10-gpadc-iio depends: industrialio intree: Y name: sun4i_gpadc_iio vermagic: 5.10.60-sunxi SMP mod_unload ARMv7 thumb2 p2v8 signat: PKCS#7 signer: sig_key: sig_hashalgo: md4
rgala Posted April 20, 2022 Posted April 20, 2022 On 4/19/2022 at 6:59 PM, going said: Can we check it out if you agree? I will build a kernel package in this OS 18.04. Or update the operating system. Of course. I will try to help every way I can. Do you want to build it on my system or you want to build it on the same OS version and then want me to try it?
going Posted April 20, 2022 Posted April 20, 2022 17 минут назад, t3l3m4k0 сказал: Release: 9.13 Codename: stretch 19 минут назад, t3l3m4k0 сказал: filename: /lib/modules/5.10.60-sunxi/kernel/drivers/iio/adc/sun4i-gpadc-iio.ko Debian 10 and 11 are supported
going Posted April 20, 2022 Posted April 20, 2022 12 минут назад, rgala сказал: Of course. I will try to help every way I can. Do you want to build it on my system or you want to build it on the same OS version and then want me to try it? I want to test my own assumption. I will create a package for your specific OS in the environment of this OS. And I will provide you with a download link. You will install this kernel package into your system and check its operability. Ubuntu 18.04 and Debian 9. Wait for the link here. 1
going Posted April 21, 2022 Posted April 21, 2022 I have a build environment for ubuntu bionic, so the first test for this OS. The build was done in VM-qemu-x86_64: @rgala https://github.com/The-going/PKG_test/tree/master/cubietruck-bionic
rgala Posted April 21, 2022 Posted April 21, 2022 Thanks, I will do my best to test this today. Do I have to install all packages? Looks like there’s much more than just a kernel.
going Posted April 21, 2022 Posted April 21, 2022 First update u-boot and reboot. In a simple way: dpkg -i linux-u-boot-*.deb Then the dtb and the core and better on some kind of test flash drive.
Jake7 Posted April 21, 2022 Posted April 21, 2022 Device model : NanoPi NEO (armv7l) DietPi v8.3.1 # lsb_release -rc Release: 11 Codename: bullseye # dpkg --list | egrep -i 'linux-image|linux-headers' ii linux-image-current-sunxi 22.02.1 armhf Linux kernel, armbian version 5.15.25-sunxi current inxi -Fx System: Host: mhj-neo Kernel: 5.15.25-sunxi armv7l bits: 32 compiler: gcc v: 10.2.1 Console: tty 0 Distro: Armbian GNU/Linux 11 (bullseye) Machine: Type: ARM Device System: FriendlyARM NanoPi NEO details: Allwinner sun8i Family rev: N/A serial: ################ CPU: Info: Quad Core model: ARMv7 v7l variant: cortex-a7 bits: 32 type: MCP arch: v7l rev: 5 features: Use -f option to see features bogomips: 403 Speed: 648 MHz min/max: 648/1008 MHz Core speeds (MHz): 1: 1008 2: 1008 3: 1008 4: 1008 Graphics: Device-1: sun8i-h3-mali driver: lima v: kernel bus ID: N/A Device-2: sun8i-a83t-dw-hdmi driver: N/A bus ID: N/A Display: server: X.org 1.20.11 driver: loaded: modesetting tty: 194x48 Message: Advanced graphics data unavailable in console for root. Audio: Device-1: sun8i-a83t-dw-hdmi driver: N/A bus ID: N/A Sound Server: ALSA v: k5.15.25-sunxi Network: Device-1: sun8i-h3-emac driver: dwmac_sun8i v: N/A port: N/A bus ID: N/A IF: eth0 state: up speed: 100 Mbps duplex: full mac: 92:7f:86:5f:7d:ba Drives: Local Storage: total: 29.81 GiB used: 4.91 GiB (16.5%) ID-1: /dev/mmcblk0 model: 00000 size: 29.81 GiB Partition: ID-1: / size: 28.44 GiB used: 4.91 GiB (17.3%) fs: ext4 dev: /dev/mmcblk0p1 Swap: ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) file: /var/swap ID-2: swap-2 type: zram size: 256 MiB used: 512 KiB (0.2%) dev: /dev/zram0 Sensors: Missing: Required tool sensors not installed. Check --recommends Info: Processes: 130 Uptime: 4h 47m Memory: 491.7 MiB used: 231.1 MiB (47.0%) Init: systemd runlevel: 5 Compilers: gcc: 10.2.1 Packages: 985 Shell: Bash v: 5.1.4 inxi: 3.3.01
going Posted April 22, 2022 Posted April 22, 2022 9 часов назад, Jake7 сказал: Device model : NanoPi NEO (armv7l) DietPi v8.3.1 # lsb_release -rc Release: 11 Codename: bullseye sudo modinfo name_module | grep 'filename:'
going Posted April 23, 2022 Posted April 23, 2022 @rgala Can you confirm or deny the operability of the kernel package?
rgala Posted April 23, 2022 Posted April 23, 2022 Hello. I will check it today, I had a busy end of the week and could not make it.
rgala Posted April 23, 2022 Posted April 23, 2022 @going I’m trying to install the u-boot package but it’s in conflict with armbian-u-boot package. Is it safe to uninstall?
going Posted April 23, 2022 Posted April 23, 2022 1 час назад, rgala сказал: I’m trying to install the u-boot package but it’s in conflict with armbian-u-boot package. Is it safe to uninstall? Do not reinstall u-boot On board: git clone https://github.com/The-going/PKG_test cd PKG_test/cubietruck-bionic ls sudo dpkg -i linux-dtb-edge-sunxi_22.05.0-trunk_armhf.deb sudo dpkg -i linux-image-edge-sunxi_22.05.0-trunk_armhf.deb Packages must be installed from this directory. Non-system packages. If everything went without errors. Reboot
rgala Posted April 23, 2022 Posted April 23, 2022 It rebooted but modules won’t load, this time the error is different though - it cannot find any module: root@cubietruck:~# find /lib/modules/ -iname '*veth*' -type f /lib/modules/4.19.62-sunxi/kernel/drivers/net/veth.ko /lib/modules/5.17.4-sunxi/kernel/drivers/net/veth.ko.xz /lib/modules/5.10.60-sunxi/kernel/drivers/net/veth.ko root@cubietruck:~# modprobe veth modprobe: FATAL: Module veth not found in directory /lib/modules/5.17.4-sunxi
going Posted April 23, 2022 Posted April 23, 2022 A negative result is also a result. You have a choice. Update the system. Use the linux-image-legacy-sunxi system version of the package on the current system. It should be 5.10.y and the kernel modules are not compressed
rgala Posted April 23, 2022 Posted April 23, 2022 Yeah, I’ll stick with 21.08.2 version until I upgrade my Ubuntu, which I plan to do anyway. Thanks for your time
going Posted April 23, 2022 Posted April 23, 2022 @Werner Can I make a request to you? Somewhere on this page, write in large green letters the names of the operating systems that are currently supported. https://docs.armbian.com/#what-is-supported And in the section "How to report bugs" Ask to specify the minimum information about the OS: lsb_release -rc Or in some other way, the main thing is that users and you and I can understand that the question relates to a supported operating system.
Werner Posted April 24, 2022 Posted April 24, 2022 "Supported" term in this section is per SBC, not per Armbian Release but yes, it should be mentioned somewhere that the latest and greatest release only can be supported atm. The minimum is already providing armbianmonitor -u which is asked for at armbian.com/bugs. Reports that lacks this are moved to p2p. It is maintainer/developers choice then to waste time on these
