Henrique Fernandes Posted April 6, 2022 Share Posted April 6, 2022 Armbianmonitor: http://paste.debian.net/1236940/ Hello, [short version] My expresso bin V5 only boots from the micro sd card and I would like it to boot from the EMMC module. [long version] My old old expresso bin V5 did not came with a pre installed EMMC module, I had a 16gb kingston EMMC module from aliexpress soldered onto it, the EMMC module is correctly detected by armbian bionic as seen from the output of blkid as /dev/mmcblk0p1: /dev/mmcblk0p1: UUID="dc265376-877d-40a1-9417-7379fb332efe" TYPE="ext4" PARTUUID="36c210f9-01" /dev/mmcblk1p1: LABEL="root" UUID="621decff-6765-4dbd-ae8c-c7e2d5c0193d" TYPE="ext4" PARTUUID="04b226a1-01" /dev/mmcblk1p3: LABEL="home" UUID="df5bfbe2-de80-49b4-ac8f-2378fd736e4f" TYPE="ext4" PARTUUID="04b226a1-03" /dev/zram0: LABEL="log2ram" UUID="1d15f838-3c4d-4acf-a58c-fde890ecdea9" TYPE="ext4" /dev/mmcblk0: PTUUID="36c210f9" PTTYPE="dos" /dev/mmcblk1: PTUUID="04b226a1" PTTYPE="dos" /dev/zram1: UUID="c759b67d-75a8-4452-95a8-fe45f11d1e4c" TYPE="swap" I can mount, read and write on /dev/mmcblk0p1, initially I ran armbian-config to install armbian on the EMMC module and it worked with a weird shortcoming, it would only boot from the EMMC module if a micro SD card was inserted on the board, I could tell right away from the "Usage of /:" field on the amrbian prompt from which storage device I had booted but I also checked the UUID on fstab and boot.cmd to make sure. uboot threw an error message saying Card did respond to voltage select! whenever I tried to boot without a micro SD card on the expresso bin From here on out what I did made matters much worse, I figured uboot was the problem and decided to update it to a newer version without backing up the on I had on the board from February 2019(stupid of me), so I downloaded and installed the lastest version I could find on https://xogium.performanceservers.nl/archive/espressobin/u-boot/ Ever since I cannot boot from the EMMC module with or without a micro SD card on the expressobin and uboot does not detect it at all, since the following command only prints one device when it used to print 2: Marvell>> mmc list sdhci@d0000: 0 I'm still able to mount and write stuff to the EMMC storage while on bionic as before, but on uboot it's like it doesen't exist. The uboot environment is like this: Marvell>> env print arch=arm baudrate=115200 board=mvebu_armada-37xx board_name=mvebu_armada-37xx boot_a_script=ext4load ${boot_interface} ${devnum}:1 ${scriptaddr} ${prefix}boot.scr;source ${scriptaddr}; boot_interface=mmc boot_prefixes=/ /boot/ boot_targets=usb sata mmc1 mmc0 bootargs=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 root=UUID=dc265376-877d-40a1-9417-7379fb332efe rootfstype=ext4 rootwait loglevel=1 usb-storage.quirks=0x2537:0x1066:u,0x2537:0x1068:u mtdparts=spi0.0:1536k(uboot),64k(uboot-environment),-(reserved) bootcmd=for target in ${boot_targets}; do run bootcmd_${target}; done bootcmd_mmc0=setenv devnum 0; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_mmc1=setenv devnum 1; setenv boot_interface mmc; run scan_dev_for_boot; bootcmd_sata=setenv devnum 0; scsi scan; scsi dev 0; setenv boot_interface scsi; run scan_dev_for_boot; bootcmd_usb=setenv devnum 0; usb start;setenv boot_interface usb; run scan_dev_for_boot; bootdelay=2 console=console=ttyMV0,115200 earlycon=ar3700_uart,0xd0012000 cpu=armv8 devnum=0 emmc_fix=on eth1addr=06:8E:A0:24:0F:88 eth2addr=00:50:43:84:25:2f eth3addr=00:50:43:0d:19:18 ethact=neta@30000 ethaddr=F0:AD:4E:03:64:7F ethprime=eth0 extra_params=pci=pcie_bus_safe fdt_addr=0x6000000 fdt_addr_r=0x6f00000 fdt_high=0xffffffffffffffff fdt_name=fdt.dtb fdt_name_a=dtb/marvell/armada-3720-community.dtb fdt_name_b=dtb/marvell/armada-3720-espressobin.dtb fdtcontroladdr=3f62d490 fileaddr=6d00000 filesize=ea gatewayip=10.4.50.254 get_images=tftpboot $kernel_addr_r $image_name; tftpboot $fdt_addr_r $fdt_name; run get_ramfs get_ramfs=if test "${ramfs_name}" != "-"; then setenv ramdisk_addr_r 0x8000000; tftpboot $ramdisk_addr_r $ramfs_name; else setenv ramdisk_addr_r -;fi hostname=marvell image_name=Image initrd_addr=0x1100000 initrd_image=uInitrd initrd_size=0x2000000 ipaddr=0.0.0.0 kernel_addr=0x7000000 kernel_addr_r=0x7000000 loadaddr=0x8000000 netdev=eth0 netmask=255.255.255.0 ramdisk_addr_r=0x8000000 ramfs_name=- root=root=/dev/nfs rw rootdev=UUID=dc265376-877d-40a1-9417-7379fb332efe rootfstype=ext4 rootpath=/srv/nfs/ scan_dev_for_boot=for prefix in ${boot_prefixes}; do echo ${prefix};run boot_a_script; done scriptaddr=0x6d00000 serverip=0.0.0.0 set_bootargs=setenv bootargs $console $root ip=$ipaddr:$serverip:$gatewayip:$netmask:$hostname:$netdev:none nfsroot=$serverip:$rootpath,tcp,v3 $extra_params $cpuidle soc=mvebu stderr=serial@12000 stdin=serial@12000 stdout=serial@12000 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u vendor=Marvell verbosity=1 Environment size: 2655/65532 bytes While booting, uboot throws these errors: / ** Bad device usb 0 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device usb 0 ** ## Executing script at 06d00000 Wrong image format for "source" command scanning bus for devices... Device 0: unknown device / ** Bad device scsi 0 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device scsi 0 ** ## Executing script at 06d00000 Wrong image format for "source" command / ** Bad device mmc 1 ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ ** Bad device mmc 1 ** ## Executing script at 06d00000 Wrong image format for "source" command / ** File not found /boot.scr ** ## Executing script at 06d00000 Wrong image format for "source" command /boot/ Any help in getting amrbian booting from the recently soldered EMMC module would be greatly appreciated. 0 Quote Link to comment Share on other sites More sharing options...
ManoftheSea Posted April 6, 2022 Share Posted April 6, 2022 Welcome, and I'm sorry to hear your troubles. If I were guessing, I would guess it's because the DTS in u-boot says the emmc is disabled, while the DTS in linux says its enabled. I would suggest that you need to get something like the file at linux-mainline/linux-*/arch/arm64/boot/dts/marvell/armada-3720-espressobin-emmc.dts into u-boot/arch/arm/dts, and then tell u-boot to use it. The difference appears to be &sdhci0 { status = "okay"; }; instead of status="disabled" But also, if you would like to have the SD card bring up linux from the eMMC, I believe you'd need to change your armbianEnv.txt so that the rootdev is "dc265376-877d-40a1-9417-7379fb332efe". This ought to be detected by u-boot and passed to the kernel cmdline. 0 Quote Link to comment Share on other sites More sharing options...
Henrique Fernandes Posted April 6, 2022 Author Share Posted April 6, 2022 7 hours ago, ManoftheSea said: But also, if you would like to have the SD card bring up linux from the eMMC, I believe you'd need to change your armbianEnv.txt so that the rootdev is "dc265376-877d-40a1-9417-7379fb332efe". This ought to be detected by u-boot and passed to the kernel cmdline. NO JOY 🙁 I also reran the amrbian-config utility to reintall armbian on the emmc, hence the UUID change, but changing amrbianEnv.txt rootdev booted in initramsfs: Begin: Will now check root file system ... fsck from util-linux 2.31.1 Checking all file systems. done. mount: mounting 0c7e2e6c-ee84-4ec3-9971-27e6020600cf on /root failed: No such file or directory done. Begin: Running /scripts/local-bottom ... done. Begin: Running /scripts/init-bottom ... mount: mounting /dev on /root/dev failed: No such file or directory mount: mounting /dev on /root/dev failed: No such file or directory done. mount: mounting /run on /root/run failed: No such file or directory run-init: current directory on the same filesystem as the root: error 0 Target filesystem doesn't have requested /sbin/init. run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 run-init: current directory on the same filesystem as the root: error 0 No init found. Try passing init= bootarg. BusyBox v1.27.2 (Ubuntu 1:1.27.2-2ubuntu3.4) built-in shell (ash) Enter 'help' for a list of built-in commands. (initramfs) I chrooted, reverted to the previous UUID and rebooted, could this error mean something else is broken? 7 hours ago, ManoftheSea said: Welcome, and I'm sorry to hear your troubles. If I were guessing, I would guess it's because the DTS in u-boot says the emmc is disabled, while the DTS in linux says its enabled. I would suggest that you need to get something like the file at linux-mainline/linux-*/arch/arm64/boot/dts/marvell/armada-3720-espressobin-emmc.dts into u-boot/arch/arm/dts, and then tell u-boot to use it. The difference appears to be &sdhci0 { status = "okay"; }; instead of status="disabled" Pardon my ignorance, but I don't know how to tell uboot to use it 😐 Also I don't know how to edit the dtb file outside of armbian-config. 0 Quote Link to comment Share on other sites More sharing options...
ManoftheSea Posted April 7, 2022 Share Posted April 7, 2022 You have `rootdev=UUID=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`, right, and not just `rootdev=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`? Or if the filesystem on emmc has changed, you'll need to write the new UUID. I'm second-guessing my earlier guess. It looks like recent u-boot have sdhci0 status as "okay", while the default linux dts has it disabled. Which is the opposite of your problem. 0 Quote Link to comment Share on other sites More sharing options...
Henrique Fernandes Posted April 9, 2022 Author Share Posted April 9, 2022 On 4/7/2022 at 4:41 PM, ManoftheSea said: You have `rootdev=UUID=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`, right, and not just `rootdev=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`? Or if the filesystem on emmc has changed, you'll need to write the new UUID. I'm second-guessing my earlier guess. It looks like recent u-boot have sdhci0 status as "okay", while the default linux dts has it disabled. Which is the opposite of your problem. Thanks alot for the help so far. You were right after all, by mistake I wrote `rootdev=0c7e2e6c-ee84-4ec3-9971-27e6020600cf` on armbianEnv.txt instead of `rootdev=UUID=0c7e2e6c-ee84-4ec3-9971-27e6020600cf`, after changing like you suggested armbian does boot on the EMMC module, as long the microSD is inserted with said line on armbianEnv.txt. I'm still at a loss on how to make uboot recognize the emmc storage and boot armbian without the microSD card. 0 Quote Link to comment Share on other sites More sharing options...
ManoftheSea Posted April 10, 2022 Share Posted April 10, 2022 21 hours ago, Henrique Fernandes said: I'm still at a loss on how to make uboot recognize the emmc storage and boot armbian without the microSD card. Currently, I'm building and using U-boot 2022.04, though 2022.01 also works. I'm a new maintainer, so I haven't quite figured out how to claim the board such that recent builds get published and the espressobin returns to first-rate service. But once we do, I'd expect that updating u-boot to the latest may allow it to detect the eMMC, and therefore load the kernel and early runtime. Beware that your current setup has kernel and early runtime on SD, while your system thinks the packages for such are on eMMC. If you update your kernel (modules) package, you may break things. 0 Quote Link to comment Share on other sites More sharing options...
Henrique Fernandes Posted April 10, 2022 Author Share Posted April 10, 2022 3 hours ago, ManoftheSea said: Currently, I'm building and using U-boot 2022.04, though 2022.01 also works. I'm a new maintainer, so I haven't quite figured out how to claim the board such that recent builds get published and the espressobin returns to first-rate service. But once we do, I'd expect that updating u-boot to the latest may allow it to detect the eMMC, and therefore load the kernel and early runtime. Beware that your current setup has kernel and early runtime on SD, while your system thinks the packages for such are on eMMC. If you update your kernel (modules) package, you may break things. I'd help if I could but I don't understand anything about low level coding and building U-boot. Glad to see your stepping up to become a maintainer of the board, I'm sure you will do great. 0 Quote Link to comment Share on other sites More sharing options...
ManoftheSea Posted April 11, 2022 Share Posted April 11, 2022 @Henrique Fernandes https://imola.armbian.com/apt/pool/main/l/linux-u-boot-espressobin-current/ or https://imola.armbian.com/beta/pool/main/l/linux-u-boot-espressobin-current/ Will give you deb packages for a more recent u-boot if you'd like to try it. 0 Quote Link to comment Share on other sites More sharing options...
Pali Posted April 11, 2022 Share Posted April 11, 2022 Ad eMMC detection in U-Boot: It is enabled by default and disabled+removed at runtime if no eMMC module is detected. See code: https://source.denx.de/u-boot/u-boot/-/blob/v2022.04/board/Marvell/mvebu_armada-37xx/board.c#L125-134 https://source.denx.de/u-boot/u-boot/-/blob/v2022.04/arch/arm/dts/armada-3720-espressobin-u-boot.dtsi#L32-38 0 Quote Link to comment Share on other sites More sharing options...
Henrique Fernandes Posted April 14, 2022 Author Share Posted April 14, 2022 I'm actually more confused now, I thought U-Boot had to be flashed, didn't know you could just install it via .deb package. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted April 14, 2022 Share Posted April 14, 2022 Both things are kind a right. With the installation of the deb package the boot loader is not automatically rewritten. This has been disabled years ago IIRC. It just contains the code/files that are needed to flash the bootloader at need. You can use armbian-config -> system -> Install to actually reflash the boot loader if necessary. 0 Quote Link to comment Share on other sites More sharing options...
