pipi Posted May 4, 2022 Share Posted May 4, 2022 Hello. I am finished Armbian Jammy 22.05 Bulseye edge 5.16.20 gnome desktop on a Rockpi4 (rk3399). When I try to overclock from Armbian-config, it doesn't work. That is, I can enter the application, apply rockchip-rk3399-opp-2ghz.dtbo. Then reboot, go to armbian-config and set a new unlocked CPU clock speed of 2.2Ghz. But instead it is only available up to a maximum of 1.8hz. How can this be fixed? Do I have to create an image from scratch, or maybe there is some trick? 0 Quote Link to comment Share on other sites More sharing options...
firedgje Posted May 8, 2022 Share Posted May 8, 2022 Hello, I have exactly the same issue with orange pi 4. I think that the option is not enabled in the new kernel for rk3399 or something like that. 0 Quote Link to comment Share on other sites More sharing options...
pipi Posted May 8, 2022 Author Share Posted May 8, 2022 ok, it's like a kind of plus option for vip users. ha ha ha 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 8, 2022 Share Posted May 8, 2022 IIRC 2.2GHz overlay should not be available at all due to stability issues 2.0GHz should run fine though. armbian-config is undergoing major rewrite anyways atm so do not expect fixes for that soon. Keep in mind that everything that armbian-config does can be done manually too. Just check the source code how its functions work and execute commands by hand. 0 Quote Link to comment Share on other sites More sharing options...
pipi Posted May 8, 2022 Author Share Posted May 8, 2022 In any case, if I use Armbian for something, it is precisely because it has some tools that other systems do not have. That said, any guide to verify and run the commands by hand? But if you mean armbianenv.txt in boot, the overlays were enabled. 0 Quote Link to comment Share on other sites More sharing options...
Werner Posted May 9, 2022 Share Posted May 9, 2022 No guide, just the source code:https://github.com/armbian/config/ 0 Quote Link to comment Share on other sites More sharing options...
MichaIng Posted May 15, 2022 Share Posted May 15, 2022 This affects all RK3399 SBCs btw, the related overclocking device tree overlays have no effect since Linux v5.15. 0 Quote Link to comment Share on other sites More sharing options...
Vverve Posted December 5, 2022 Share Posted December 5, 2022 (edited) orange pi 4 kinetic xcfe 6.0.11 the opp20 from build dont work!!?!! but got overclock to 1.7 1.7 1.7 2.18?? ..tought it was kernel specific but took overlays occ22 from bionic legacy img and it works, it say so ....it wont survive update ,you just need to put them back in your/boot/overlays & re-enable it. Stress test with heatsink+fan 85°C...hot.. i dont see instability here , just a little more speed. But its at your own risk. Edited December 5, 2022 by Vverve 0 Quote Link to comment Share on other sites More sharing options...
Chuckufarley Posted October 31, 2023 Share Posted October 31, 2023 I am new to Linux and the Pi environment. I am using an Orange Pi 5B and the armbian-config will no long save CPU frequency or governor setting after update/upgrade the packages via "apt" command line. I have tried manually changing some of the config files only to be told by the OS that it will not save due to permissions, even when longed in as ROOT. is there a working ARMBIAN-CONFIG that can fix this issue? 0 Quote Link to comment Share on other sites More sharing options...
