Guest Posted May 8, 2022 Posted May 8, 2022 (edited) Hello armbian friends, I am not really a beginner but I don't find a fitting forum to ask this. Having manually upgraded the first day it was possible to Bullseye, my MOTD and armbian-release got stuck on the old version. Everything runs very very good, I have a very up-to-date kernel and love it. Any chance I can repair my broken MOTD? What did I do wrong when I changed my sources.list and armbian.list? Kind greetings Edited May 8, 2022 by garak
Solution Werner Posted May 8, 2022 Solution Posted May 8, 2022 Userspace upgrades (Buster->Bullseye or Focal->Jammy) are neither tested nor supported. Try replacing rootfs package.
Guest Posted May 9, 2022 Posted May 9, 2022 Hello Werner, thanks for the reply. I immediately could check for the packages but they were for dev and next branches of outdated Debian releases only. My second Odroid HC1 has an official Bullseye Armbian installed and has not any rootfs package. So no "transplant" from there either. The userspace I hacked together will work for now, but I understand I maybe was just lucky that it turned out to be stable, since 14. August 2021 so to say. This is good enough for me. In the future I will use the properly built Armbian releases and just re-install, however I made since 2019 many changes, most of which I forgot as my .bash_history self truncated. A slow migration to the 2nd Odroid, careful testing and documenting what I did is my only way to reproduce it I have full SD card backups and all the code I wrote too. There are just differences what the other Bullseye image will accept for kernels. Signal-cli only runs on one of the Odroids, due to unknown reasons, but these are excuses why I find no time.
3735943886 Posted May 9, 2022 Posted May 9, 2022 I upgraded my Nanopi from buster to bullseye recently. It looks like that your armbian version is not up to date. And please check your armbian.list is also pointing bullseye.
Guest Posted May 11, 2022 Posted May 11, 2022 @3735943886 Thanks, though I mentioned in the opening post I edited this file as well. They are in fact identical to the later released official Armbian Bullseye. I currently see no way to mitigate this.
