damien78 Posted September 21, 2016 Posted September 21, 2016 Hi, I updated my system to version 5.20. This version is supposed to solve the problem of bluetooth.But this is not the case. Can you help me? thanks. ps : dmesg | grep ap6210 : 8.054958] [ap6210] select wifi ap6210 [ 8.058372] [ap6210] Initializing ap6210. [ 8.063627] [ap6210] platform device registered successfully. [ 8.067651] [ap6210] Using ap6210 configuration. [ 8.288340] [ap6210] WLAN placed in POWER ON [ 8.559560] [ap6210] Linux Kernel SDIO/MMC Driver [ 8.582485] [ap6210] Broadcom Dongle Host Driver: register interface [wlan0] MAC: 00:90:4c:11:22:33 [ 8.947049] [ap6210] WLAN placed in RESET [ 10.468573] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 10.487291] ap6211: exports duplicate symbol bcmsdh_probe (owned by ap6210) [ 10.792652] [ap6210] Using ap6210 configuration. [ 32.955882] [ap6210] dhd_check_hang: Event HANG send up due to re=0 te=0 e=-36 s=0 [ 32.959999] [ap6210] In : chip crash eventing [ 32.975217] Modules linked in: disp_ump mali_drm drm mali ump bnep cpufreq_userspace btusb ap6210 sunxi_ir hidp rfcomm hci_uart bluetooth sg [last unloaded: scsi_wait_scan] [ 33.024617] [<c0706ea8>] (cfg80211_disconnected+0xc0/0xc4) from [<bf0da1ac>] (wl_cfg80211_hang+0x44/0xb4 [ap6210]) [ 33.034502] [<bf0da1ac>] (wl_cfg80211_hang+0x44/0xb4 [ap6210]) from [<c004cef0>] (process_one_work+0x138/0x3cc) [ 33.121388] [ap6210] reg_notifier for intiator:0 not supported
Igor Posted September 22, 2016 Posted September 22, 2016 Probably something is missing, a script for loading Bluetooth firmware, firmware or Bluetooth stack. Try with clean image - it should work out of the box.
damien78 Posted October 12, 2016 Author Posted October 12, 2016 Ok I tested. bluethoot ok. but the function I want to use, loudspeaker emulator, does not work properly. the sound is constantly cut, choppy. it's not an armbian problem...
