No hdmi sound on vim3l khadas
Go to solution Solved by NicoD,
Hi, everyone!
Khadas Vim3l on Ubuntu, armbian.
No hdmi sound, boot without any changes, fully stock!
Tried to boot on 4.9 image from khadas and android pie - success.
Imagies that is no hdmi sound only dummy output:
Armbian_22.02.1_Khadas-vim3l_jammy_edge_5.15.25_xfce_desktop.img
Armbian_22.02.1_Khadas-vim3l_focal_current_5.10.102_xfce_desktop.img
Armbian_22.05.1_Khadas-vim3l_jammy_edge_5.17.5_xfce_desktop.img
Armbian_22.05.1_Khadas-vim3l_focal_current_5.10.110_xfce_desktop.img
How to fix?
  • Solution
This might be a fix. I haven't had the time to test and implement.
Steps used to fix audio on Armbian
    Clone @Spikerguy Repository From Manjaro Gitlab
    Ensure you have git installed with,
pi@twisteros:~$ sudo apt install git
Make a destination subdirectory under /home/pi for git pulls and builds,
pi@twisteros:~$ mkdir ~/builds
Change to your new ‘builds’ directory,
pi@twisteros:~$ cd ~/builds
Clone local copies of the Manjaro files:
pi@twisteros:~$ git clone manjaro-arm / packages / community / khadas-utils · GitLab
    Copy Files to Their Correct Locations
pi@twisteros:~$ sudo cp ~/builds/khadas-utils/g12_sound.sh /usr/bin
pi@twisteros:~$ sudo cp ~/builds/khadas-utils/sound.service /usr/lib/systemd/system/
pi@twisteros:~$ sudo cp ~/builds/khadas-utils/G12B-KHADAS-VIM3.conf /usr/share/alsa/cards/
pi@twisteros:~$ sudo ln -s /usr/share/alsa/cards/G12B-KHADAS-VIM3.conf /usr/share/alsa/cards/G12BKHADASVIM3.conf
pi@twisteros:~$ sudo cp ~/builds/khadas-utils/G12B-KHADAS-VIM3.conf /etc/asound.conf
Make sure that /usr/bin/g12_sound.sh is executable. It should already be, and you can check with,
pi@twisteros:~$ ls -l /usr/bin/g12_sound.sh
Otherwise a quck chmod won’t hurt:
pi@twisteros:~$ sudo chmod a+x /usr/bin/g12_sound.sh
    Initialize the Systemd Sound Service Unit
pi@twisteros:~$ sudo systemctl enable sound.service
3 минуты назад, NicoD сказал:
Thank you very much, i will try it.
12 минут назад, Igor сказал:
Yes, I'm understand that newer kernel not so compitebly like older. Ive already read faq, and fine tuning, and search it on forum, and khadas forum...
