Hi forum members,
the apt utility in my bpi m2 zero can't find neither dnsutil nor bind9-dnsutil for bullseye, here the output:
pi@fewo-relais:~$ sudo apt install bind9-dnsutils
Paketlisten werden gelesen… Fehler!
E: Encountered a section with no Package: header
E: Problem with MergeList /var/lib/apt/lists/deb.debian.org_debian_dists_bullseye_main_binary-armhf_Packages
E: Die Paketliste oder die Statusdatei konnte nicht eingelesen oder geöffnet werden.
pi@fewo-relais:~$
pi@fewo-relais:~$ cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=bananapim2zero
BOARD_NAME="Banana Pi M2 Zero"
BOARDFAMILY=sun8i
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=735eff9
DISTRIBUTION_CODENAME=bullseye
DISTRIBUTION_STATUS=csc
VERSION=21.08.0-trunk
LINUXFAMILY=sunxi
ARCH=arm
IMAGE_TYPE=user-built
BOARD_TYPE=csc
INITRD_ARCH=arm
KERNEL_IMAGE_TYPE=Image
BRANCH=current
Can someone help how to update the repository to have also bind9-dnsutils included ?
Regards
wollik
