dkebler Posted May 28, 2022 Posted May 28, 2022 Getting stuck out of the gate (of course never goes as documented🤣) https://puhoy.github.io/posts/armbian_on_espressobin/ While attempting to flash the required uboot update I keep getting a "permission" type error I've tried with usb stick and sd card, formated ext4, formatted fat and various permutations including simple filename....all give the same error even though usb and mmc commands say the media is there This is a v5. I have an identical one I set up a few years ago with ubuntu 18 but I did not have to flash this new uboot. Any thoughts? Do one of the jumpers have to be set in order to flash? Marvell>> usb info 1: Hub, USB Revision 3.0 - U-Boot XHCI Host Controller - Class: Hub - PacketSize: 9 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 1.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Setting 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms 1: Hub, USB Revision 2.0 - u-boot EHCI Host Controller - Class: Hub - PacketSize: 64 Configurations: 1 - Vendor: 0x0000 Product 0x0000 Version 1.0 Configuration: 1 - Interfaces: 1 Self Powered 0mA Interface: 0 - Alternate Setting 0, Endpoints: 1 - Class Hub - Endpoint 1 In Interrupt MaxPacket 8 Interval 255ms 2: Mass Storage, USB Revision 2.0 - SanDisk Corporation Staples Relay SNDK7E38850327C07602 - Class: (from Interface) Mass Storage - PacketSize: 64 Configurations: 1 - Vendor: 0x0781 Product 0x5202 Version 0.32 Configuration: 1 - Interfaces: 1 Bus Powered 200mA Interface: 0 - Alternate Setting 0, Endpoints: 2 - Class Mass Storage, Transp. SCSI, Bulk only - Endpoint 1 In Bulk MaxPacket 512 - Endpoint 1 Out Bulk MaxPacket 512 Marvell>> bubt flash-image-DDR3-2g_2cs_7-1000_800.bin spi usb Burning U-BOOT image "flash-image-DDR3-2g_2cs_7-1000_800.bin" from "usb" to "spi" USB0: Register 2000104 NbrPorts 2 Starting the controller USB XHCI 1.00 USB1: USB EHCI 1.00 scanning bus 0 for devices... 1 USB Device(s) found scanning bus 1 for devices... 2 USB Device(s) found ** File not found flash-image-DDR3-2g_2cs_7-1000_800.bin ** Error: Failed to read file flash-image-DDR3-2g_2cs_7-1000_800.bin from usb exit not allowed from main input shell. Marvell>> mmc info Device: sdhci@d0000 Manufacturer ID: 3 OEM: 5344 Name: SU08G Tran Speed: 50000000 Rd Block Len: 512 SD version 3.0 High Capacity: Yes Capacity: 7.4 GiB Bus Width: 4-bit Erase Group Size: 512 Bytes Marvell>> bubt flash-image-DDR3-2g_2cs_7-1000_800.bin spi mmc Burning U-BOOT image "flash-image-DDR3-2g_2cs_7-1000_800.bin" from "mmc" to "spi" Card did not respond to voltage select! mmc_init: -95, time 42 MMC Device 1 not found No SD/MMC/eMMC card found Error: Failed to read file flash-image-DDR3-2g_2cs_7-1000_800.bin from mmc exit not allowed from main input shell.
dkebler Posted May 28, 2022 Author Posted May 28, 2022 Nevermind, 😙 kept trying reformatted stick again and it worked. So for those having this issue make sure to format your stick to MBR not GPT and then make a FAT32 partition.
Igor Posted May 28, 2022 Posted May 28, 2022 5 hours ago, dkebler said: Nevermind, 😙 kept trying reformatted stick again and it worked. So for those having this issue make sure to format your stick to MBR not GPT and then make a FAT32 partition. Yes, those has to be fat32. Strange. Otherwise instructions on download pages are working - but with most recent images only.
ManoftheSea Posted May 28, 2022 Posted May 28, 2022 15 hours ago, dkebler said: format your stick to MBR not GPT and then make a FAT32 partition If you had a recent u-boot, you wouldn't have this problem. It can read gpt, it can read ext4. Of course, you can't flash recent u-boot until you solve this problem.
ManoftheSea Posted May 28, 2022 Posted May 28, 2022 Also, the "new bootscript" is no longer required with u-boot 2022.04. They include the distro_boot method which finds the boot.scr, and that loads the kernel. env default -a saveenv 1
lampra Posted May 28, 2022 Posted May 28, 2022 5 hours ago, ManoftheSea said: env default -a Could you please share or point to this default environment, as I don't have the board available for tests at the moment?
ManoftheSea Posted May 31, 2022 Posted May 31, 2022 I believe this is the default environment, which is compiled into u-boot so the command "env default -a" will set it: Spoiler boot_a_script=load ${devtype} ${devnum}:${distro_bootpart} ${scriptaddr} ${prefix}${script}; source ${scriptaddr} boot_efi_binary=load ${devtype} ${devnum}:${distro_bootpart} ${kernel_addr_r} efi/boot/bootaa64.efi; if fdt addr ${fdt_addr_r}; then bootefi ${kernei boot_efi_bootmgr=if fdt addr ${fdt_addr_r}; then bootefi bootmgr ${fdt_addr_r};else bootefi bootmgr;fi boot_extlinux=sysboot ${devtype} ${devnum}:${distro_bootpart} any ${scriptaddr} ${prefix}${boot_syslinux_conf} boot_net_usb_start=usb start boot_pci_enum=pci enum boot_prefixes=/ /boot/ boot_script_dhcp=boot.scr.uimg boot_scripts=boot.scr.uimg boot.scr boot_syslinux_conf=extlinux/extlinux.conf boot_targets=usb0 mmc1 mmc0 bootcmd=run distro_bootcmd bootcmd_dhcp=devtype=dhcp; run boot_net_usb_start; run boot_pci_enum; if dhcp ${scriptaddr} ${boot_script_dhcp}; then source ${scriptaddr}; fi;seten; bootcmd_mmc0=devnum=0; run mmc_boot bootcmd_mmc1=devnum=1; run mmc_boot bootcmd_pxe=run boot_net_usb_start; run boot_pci_enum; dhcp; if pxe get; then pxe boot; fi bootcmd_scsi0=devnum=0; run scsi_boot bootcmd_usb0=devnum=0; run usb_boot bootfstype=ext4 scriptaddr=0x6d00000 distro_bootcmd=scsi_need_init=; setenv nvme_need_init; for target in ${boot_targets}; do run bootcmd_${target}; done efi_dtb_prefixes=/ /dtb/ /dtb/current/ eth1addr=00:51:82:11:22:01 eth2addr=00:51:82:11:22:02 eth3addr=00:51:82:11:22:03 ethaddr=00:51:82:11:22:00 fdt_addr=0x6f00000 fdt_addr_r=0x6f00000 fdtfile=marvell/armada-3720-espressobin-v7.dtb kernel_addr=0x7000000 kernel_addr_r=0x7000000 load_efi_dtb=load ${devtype} ${devnum}:${distro_bootpart} ${fdt_addr_r} ${prefix}${efi_fdtfile} mmc_boot=if mmc dev ${devnum}; then devtype=mmc; run scan_dev_for_boot_part; fi nvme_boot=run boot_pci_enum; run nvme_init; if nvme dev ${devnum}; then devtype=nvme; run scan_dev_for_boot_part; fi nvme_init=if ${nvme_need_init}; then setenv nvme_need_init false; nvme scan; fi pxefile_addr_r=0x6e00000 ramdisk_addr_r=0xa000000 sata_boot=if sata dev ${devnum}; then devtype=sata; run scan_dev_for_boot_part; fi scan_dev_for_boot=echo Scanning ${devtype} ${devnum}:${distro_bootpart}...; for prefix in ${boot_prefixes}; do run scan_dev_for_extlinux; run scan_d; scan_dev_for_boot_part=part list ${devtype} ${devnum} -bootable devplist; env exists devplist || setenv devplist 1; for distro_bootpart in ${devplist scan_dev_for_efi=setenv efi_fdtfile ${fdtfile}; for prefix in ${efi_dtb_prefixes}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${e scan_dev_for_extlinux=if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${boot_syslinux_conf}; then echo Found ${prefix}${boot_syslinux_coi scan_dev_for_scripts=for script in ${boot_scripts}; do if test -e ${devtype} ${devnum}:${distro_bootpart} ${prefix}${script}; then echo Found U-Boote scsi_boot=run boot_pci_enum; run scsi_init; if scsi dev ${devnum}; then devtype=scsi; run scan_dev_for_boot_part; fi scsi_init=if ${scsi_need_init}; then scsi_need_init=false; scsi scan; fi usb_boot=usb start; if usb dev ${devnum}; then devtype=usb; run scan_dev_for_boot_part; fi
