  • SoC: Rockchip RK3568B2
    • CPU: Quad-core ARM Cortex-A55 CPU, up to 2.0GHz
    • GPU: Mali-G52 1-Core-2EE,supports OpenGL ES 1.1, 2.0, and 3.2, Vulkan 1.0 and 1.1, OpenCL 2.0 Full Profile
    • VPU: 4KP60 H.265/H.264/VP9 video decoder, 1080P60 H.264/H.265 video encoder
    • NPU: Support 0.8T
  • RAM: 2GB LPDDR4X
  • Flash: 8GB eMMC
  • Ethernet: one Native Gigabit Ethernet, and two PCIe 2.5Gbps Ethernet
  • USB: two USB 3.2 Gen 1 Type-A ports
  • HDMI:
    • support HDMI1.4 and HDMI2.0 operation
    • support up to 10 bits Deep Color modes
    • support up to 1080p@120Hz and 4096x2304@60Hz
    • support 3-D video formats
  • PCIe: M.2 Key M, PCIe2.1 x1, support NVME, PCIe WiFi etc
  • microSD: support UHS-I
  • GPIO:
    • 12-pin 0.5mm FPC connector
    • up to 1x SPI, up to 3x UARTs, up to 4x PWMs, up to 8x GPIOs
  • SD/MMC/SDIO/I2S:
    • 2x8-pin 1.27mm connector
    • Compatible with SDIO3.0 protocol
    • Compatible with SD3.0, MMC ver4.51
    • 4bits data bus widths
    • 1x I2S with 2x SDO and 3x SDI
  • Debug: one Debug UART, 3 Pin 2.54mm header, 3.3V level, 1500000bps
  • LEDs: 4 x GPIO Controlled LED (SYS, WAN, LAN1, LAN2)
  • others:
    • 2 Pin 1.27/1.25mm RTC battery input connector for low power RTC IC HYM8563TS
    • MASK button for eMMC update
    • one 5V Fan connector
    • Power supply: USB-C, support PD, 5V/9V/12V input
  • PCB: 8 Layer, 62x90x1.6mm
  • Ambient Operating Temperature: 0℃ to 70℃
https://wiki.friendlyelec.com/wiki/index.php/NanoPi_R5S#Hardware_Spec
  • Igor pinned and locked this topic
  • Igor unpinned this topic
