Goerlitzer Posted May 31, 2022 Posted May 31, 2022 After upgrade at 30.5. I can't boot the orangepi zero 2 (4.9 kernel). Is there any possibility to reload the old kernel or other ways to fix it? Thanks in advance for answering. config-4.9.255-sun50iw9 0 Quote
Werner Posted May 31, 2022 Posted May 31, 2022 It might be easier to debug if you attach an actual boot log rather than an kernel config we already know... 0 Quote
Goerlitzer Posted May 31, 2022 Author Posted May 31, 2022 Thanks Werner for the quick answer! I have problems to connect the uart. I try it and send the boot log. 0 Quote
Goerlitzer Posted May 31, 2022 Author Posted May 31, 2022 Just got my uart to work. Attached the boot log. boot-log-orangepizero2 0 Quote
Werner Posted May 31, 2022 Posted May 31, 2022 Did you try a new image to see if that boots correctly? 0 Quote
Goerlitzer Posted May 31, 2022 Author Posted May 31, 2022 I just tried it. The same error messages in the boot log (attached). Boot-log-orangepizero2-2 0 Quote
ALIGMSTEN Posted May 31, 2022 Posted May 31, 2022 I seem to recall somewhere here about 'booti' and 'bootm' change, sorry its just vague memory! ** File not found /boot/Image ** Unknown command 'booti' - try 'help' 0 Quote
Pabloscotty Posted June 1, 2022 Posted June 1, 2022 9 hours ago, ALIGMSTEN said: I seem to recall somewhere here about 'booti' and 'bootm' change, sorry its just vague memory! ** File not found /boot/Image ** Unknown command 'booti' - try 'help' maybye this is the problem but I don't know how to fix it: "The problem is caused by typo in default_bootcmd booti should be modified to bootm" default_bootcmd=run uenvboot; run cp_kernel2ram && run cp_dtb2ram && booti ${netstart} - ${dtbnetstart} 0 Quote
Werner Posted June 3, 2022 Posted June 3, 2022 Not sure. The only file I could find containing booti is here: https://github.com/armbian/build/blob/master/config/bootscripts/boot-sun50i-next.cmd Other files are unrelated to H616 aka sun50iw9 Try edit this file and then build an image from it to see if changes something. 0 Quote
ALIGMSTEN Posted June 4, 2022 Posted June 4, 2022 @Werner is right you need to try changing bootm - booti Unfortunately I dont have time to test this, that was the change in the various sources I had picked up during my attempts at trying to get things working on the modern kernels. build/config/bootscripts/boot-sun50iw9.cmd is bootm build/config/bootscripts/boot-sun50i-next.cmd is booti I am assuming legacy is using sun50iw9.cmd If so and in which case you should the change there... from: bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} to: booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} 0 Quote
Pabloscotty Posted June 4, 2022 Posted June 4, 2022 Can I change it on actual system (fixing it) or do I have to make all image build? etc. Sorry for dumb question but I'm not best in Linux territory. I'm using it just for PiHole and it worked great until this update (EDIT) I think I found the answer https://docs.armbian.com/User-Guide_Recovery/ 0 Quote
ALIGMSTEN Posted June 4, 2022 Posted June 4, 2022 correct try that with setenv mainline arm64 uboot uses booti, boot.cmd suggests making the change. 0 Quote
ALIGMSTEN Posted June 7, 2022 Posted June 7, 2022 (edited) It seems that legacy uboot is overwritten. Not entirely sure what the update/upgrade circumstances were with the previous posters. Unfortunately I dont have usb debugging in set-up right now, have to dismantle cluster build. Here is my experience latest official download: Armbian 22.05 Bullseye Kernel 4.9.y, Size: 344Mb, Updated: May 28, 2022 SHA hash | PGP signature stable user space packages Red light-on and nothing further! Similar outcome to what updating my previous test download! PROCEED WITH FOLLOWING: Armbian_22.02.22_Orangepizero2_bullseye_legacy_4.9.255.img downloaded 04/18/2022, flashed to sd card and follow usual formalities username/pwd/locales etc While root, install desktop from Armbian-config REBOOT: 1 NOTE this gives me [No end-user support: untested automated build] clarification, I need to check exactly which image this is, as have built and downloaded quite a few in my various processes! login as: root root@10.0.0.17's password: ___ ____ _ _____ ____ / _ \| _ \(_) |__ /___ _ __ ___|___ \ | | | | |_) | | / // _ \ '__/ _ \ __) | | |_| | __/| | / /| __/ | | (_) / __/ \___/|_| |_| /____\___|_| \___/_____| Welcome to Armbian 22.02.0-trunk.0046 with Linux 4.9.255-sun50iw9 No end-user support: untested automated build System load: 34% Up time: 1 min Memory usage: 11% of 965M IP: 10.0.0.17 CPU temp: 52°C Usage of /: 5% of 29G [ 0 security updates available, 2 updates total: apt upgrade ] Last check: 2022-06-07 11:41 Last login: Tue Jun 7 11:37:12 2022 from 10.0.0.5 root@orangepizero2:~# apt list --upgradable Listing... Done libsasl2-2/stable-security 2.1.27+dfsg-2.1+deb11u1 arm64 [upgradable from: 2.1.27+dfsg-2.1] libsasl2-modules-db/stable-security 2.1.27+dfsg-2.1+deb11u1 arm64 [upgradable from: 2.1.27+dfsg-2.1] root@orangepizero2:~# apt upgrade REBOOT: 2 root@orangepizero2:~# reboot login as: root root@10.0.0.17's password: ___ ____ _ _____ ____ / _ \| _ \(_) |__ /___ _ __ ___|___ \ | | | | |_) | | / // _ \ '__/ _ \ __) | | |_| | __/| | / /| __/ | | (_) / __/ \___/|_| |_| /____\___|_| \___/_____| Welcome to Armbian 22.02.0-trunk.0046 with Linux 4.9.255-sun50iw9 No end-user support: untested automated build System load: 32% Up time: 1 min Memory usage: 11% of 965M IP: 10.0.0.17 CPU temp: 56°C Usage of /: 5% of 29G [ General system configuration (beta): armbian-config ] Last login: Tue Jun 7 11:41:45 2022 from 10.0.0.5 root@orangepizero2:~# cat /boot/boot.cmd # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # # default values setenv load_addr "0x45000000" setenv rootdev "/dev/mmcblk0p1" setenv verbosity "1" setenv rootfstype "ext4" setenv console "both" setenv docker_optimizations "off" setenv bootlogo "false" # Print boot source itest.b *0x10028 == 0x00 && echo "U-boot loaded from SD" itest.b *0x10028 == 0x02 && echo "U-boot loaded from eMMC or secondary SD" itest.b *0x10028 == 0x03 && echo "U-boot loaded from SPI" echo "Boot script loaded from ${devtype}" if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt env import -t ${load_addr} ${filesize} fi if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=ttyS0,115200 console=tty1"; fi if test "${console}" = "serial"; then setenv consoleargs "console=ttyS0,115200"; fi if test "${bootlogo}" = "true"; then setenv consoleargs "bootsplash.bootfile=bootsplash.armbian ${consoleargs}"; fi # get PARTUUID of first partition on SD/eMMC it was loaded from # mmc 0 is always mapped to device u-boot (2016.09+) was loaded from if test "${devtype}" = "mmc"; then part uuid mmc 0:1 partuuid; fi setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} disp_reserve=${disp_reserve} ${extraargs} ${extraboardargs}" if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=memory swapaccount=1"; fi #load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} #fdt addr -c ${fdt_addr_r} #fdt addr ${fdt_addr_r} #fdt resize 65536 fdt set disp boot_fb0 ${boot_fb0} fdt set disp boot_disp <${boot_disp}> fdt set disp boot_disp1 <${boot_disp1}> fdt set disp boot_disp2 <${boot_disp2}> fdt set disp tv_vdid <${tv_vdid}> fdt set disp fb0_width <${fb0_width}> fdt set disp fb0_height <${fb0_height}> for overlay_file in ${user_overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overlay_file}.dtbo; then echo "Applying user provided DT overlay ${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}uImage bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr root@orangepizero2:~# BOOT: Here is legacy build/config/bootscripts/boot-sun50iw9.cmd DOCKER FORCE CGROUPS: build/config/bootenv/sun50iw9.txt root@orangepizero2:~# nano /boot/armbianEnv.txt verbosity=1 console=both disp_mode=1080p60 fb0_width=1280 fb0_height=720 #added extraargs=systemd.unified_cgroup_hierarchy=0 REBOOT: 3 login as: root root@10.0.0.17's password: ___ ____ _ _____ ____ / _ \| _ \(_) |__ /___ _ __ ___|___ \ | | | | |_) | | / // _ \ '__/ _ \ __) | | |_| | __/| | / /| __/ | | (_) / __/ \___/|_| |_| /____\___|_| \___/_____| Welcome to Armbian 22.02.0-trunk.0046 with Linux 4.9.255-sun50iw9 No end-user support: untested automated build System load: 41% Up time: 1 min Memory usage: 12% of 965M IP: 10.0.0.17 CPU temp: 55°C Usage of /: 10% of 29G [ 0 security updates available, 56 updates total: apt upgrade ] Last check: 2022-06-07 12:18 [ General system configuration (beta): armbian-config ] Last login: Tue Jun 7 11:52:57 2022 from 10.0.0.5 root@orangepizero2:~# apt list --upgradable Listing... Done Calculating upgrade... Done The following packages will be upgraded: armbian-bsp-cli-orangepizero2 armbian-config armbian-firmware armbian-zsh base-files bind9-dnsutils bind9-host bind9-libs chrony dirmngr dnsutils dpkg dpkg-dev gnupg gnupg-l10n gnupg-utils gnupg2 gpg gpg-agent gpg-wks-client gpg-wks-server gpgconf gpgsm gpgv gzip hostapd libc-bin libc-dev-bin libc-l10n libc6 libc6-dev libdpkg-perl libexpat1 libldap-2.4-2 liblzma5 libnss-myhostname libpam-systemd libssl-dev libssl1.1 libsystemd0 libudev1 libxml2 linux-dtb-legacy-sun50iw9 linux-image-legacy-sun50iw9 linux-libc-dev linux-u-boot-orangepizero2-legacy locales openssl rsyslog systemd systemd-sysv sysvinit-utils tzdata udev xz-utils zlib1g 56 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. 933 not fully installed or removed. Need to get 67.4 MB of archives. After this operation, 4,610 kB disk space will be freed. Do you want to continue? [Y/n] y HERE I CONTINUE WITH UPDATE KNOWING IT WILL BREAK: SOME RELEVANT PARTS OF UPDATE PROCESS; Setting up armbian-bsp-cli-orangepizero2 (22.05.1) ... NOTE: You can find previous bootscript versions in /usr/share/armbian ! Recreating boot script Setting up linux-image-legacy-sun50iw9 (22.05.1) ... dkms: running auto installation service for kernel 4.9.255-sun50iw9:. update-initramfs: Generating /boot/initrd.img-4.9.255-sun50iw9 cp: cannot stat '/etc/fonts/fonts.conf': No such file or directory E: /usr/share/initramfs-tools/hooks/plymouth failed with return 1. update-initramfs: failed for /boot/initrd.img-4.9.255-sun50iw9 with 1. run-parts: /etc/kernel/postinst.d/initramfs-tools exited with return code 1 Setting up usbmuxd (1.1.1-2) ... Warning: The home dir /var/lib/usbmux you specified can't be accessed: No such file or directory Adding system user `usbmux' (UID 114) ... Adding new user `usbmux' (UID 114) with group `plugdev' ... Not creating home directory `/var/lib/usbmux'. usbmuxd.service is a disabled or a static unit, not starting it. Processing triggers for initramfs-tools (0.140) ... update-initramfs: Generating /boot/initrd.img-4.9.255-sun50iw9 update-initramfs: Converting to u-boot format UPDATE COMPLETE: Here boot.cmd is mainline build/config/bootscripts/boot-sun50i-next.cmd root@orangepizero2:~# cat /boot/boot.cmd # DO NOT EDIT THIS FILE # # Please edit /boot/armbianEnv.txt to set supported parameters # # default values setenv load_addr "0x45000000" setenv overlay_error "false" setenv rootdev "/dev/mmcblk0p1" setenv verbosity "1" setenv rootfstype "ext4" setenv console "both" setenv docker_optimizations "on" setenv bootlogo "false" # Print boot source itest.b *0x10028 == 0x00 && echo "U-boot loaded from SD" itest.b *0x10028 == 0x02 && echo "U-boot loaded from eMMC or secondary SD" itest.b *0x10028 == 0x03 && echo "U-boot loaded from SPI" echo "Boot script loaded from ${devtype}" if test -e ${devtype} ${devnum} ${prefix}armbianEnv.txt; then load ${devtype} ${devnum} ${load_addr} ${prefix}armbianEnv.txt env import -t ${load_addr} ${filesize} fi if test "${console}" = "display" || test "${console}" = "both"; then setenv consoleargs "console=ttyS0,115200 console=tty1"; fi if test "${console}" = "serial"; then setenv consoleargs "console=ttyS0,115200"; fi if test "${bootlogo}" = "true"; then setenv consoleargs "bootsplash.bootfile=bootsplash.armbian ${consoleargs}"; fi # get PARTUUID of first partition on SD/eMMC it was loaded from # mmc 0 is always mapped to device u-boot (2016.09+) was loaded from if test "${devtype}" = "mmc"; then part uuid mmc 0:1 partuuid; fi setenv bootargs "root=${rootdev} rootwait rootfstype=${rootfstype} ${consoleargs} consoleblank=0 loglevel=${verbosity} ubootpart=${partuuid} usb-storage.quirks=${usbstoragequirks} ${extraargs} ${extraboardargs}" if test "${docker_optimizations}" = "on"; then setenv bootargs "${bootargs} cgroup_enable=memory swapaccount=1"; fi load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} fdt addr ${fdt_addr_r} fdt resize 65536 for overlay_file in ${overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/allwinner/overlay/${overlay_prefix}-${overlay_file}.dtbo; then echo "Applying kernel provided DT overlay ${overlay_prefix}-${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done for overlay_file in ${user_overlays}; do if load ${devtype} ${devnum} ${load_addr} ${prefix}overlay-user/${overlay_file}.dtbo; then echo "Applying user provided DT overlay ${overlay_file}.dtbo" fdt apply ${load_addr} || setenv overlay_error "true" fi done if test "${overlay_error}" = "true"; then echo "Error applying DT overlays, restoring original DT" load ${devtype} ${devnum} ${fdt_addr_r} ${prefix}dtb/${fdtfile} else if load ${devtype} ${devnum} ${load_addr} ${prefix}dtb/allwinner/overlay/${overlay_prefix}-fixup.scr; then echo "Applying kernel provided DT fixup script (${overlay_prefix}-fixup.scr)" source ${load_addr} fi if test -e ${devtype} ${devnum} ${prefix}fixup.scr; then load ${devtype} ${devnum} ${load_addr} ${prefix}fixup.scr echo "Applying user provided fixup script (fixup.scr)" source ${load_addr} fi fi load ${devtype} ${devnum} ${ramdisk_addr_r} ${prefix}uInitrd load ${devtype} ${devnum} ${kernel_addr_r} ${prefix}Image booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} # Recompile with: # mkimage -C none -A arm -T script -d /boot/boot.cmd /boot/boot.scr root@orangepizero2:~# LOGS ADDED: root@orangepizero2:~# uname -a Linux orangepizero2 4.9.255-sun50iw9 #1 SMP PREEMPT Tue Mar 1 23:28:34 UTC 2022 aarch64 GNU/Linux root@orangepizero2:~# root@orangepizero2:~# armbianmonitor -u System diagnosis information will now be uploaded to http://ix.io/3ZBT Please post the URL in the forum where you've been asked for. Edited June 7, 2022 by ALIGMSTEN clarification 0 Quote
cristobalgh Posted June 8, 2022 Posted June 8, 2022 On 6/3/2022 at 7:58 AM, Werner said: Not sure. The only file I could find containing booti is here: https://github.com/armbian/build/blob/master/config/bootscripts/boot-sun50i-next.cmd Other files are unrelated to H616 aka sun50iw9 Try edit this file and then build an image from it to see if changes something. hey! this worked, changed line #73: booti ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} to bootm ${kernel_addr_r} ${ramdisk_addr_r} ${fdt_addr_r} build a minimal focal image, and it booted. Trying now to build a normal focal image... thanks! 0 Quote
cristobalgh Posted June 9, 2022 Posted June 9, 2022 Armbian_22.08.0-trunk_Orangepizero2_focal_current_5.15.45 this doesn't work. Armbian_22.08.0-trunk_Orangepizero2_focal_legacy_4.9.255_minimal this DOES work. 0 Quote
cristobalgh Posted June 9, 2022 Posted June 9, 2022 35 minutes ago, cristobalgh said: Armbian_22.08.0-trunk_Orangepizero2_focal_current_5.15.45 this doesn't work. Armbian_22.08.0-trunk_Orangepizero2_focal_legacy_4.9.255_minimal this DOES work. ok it must be focal legacy, this works also with the fix: Armbian_22.08.0-trunk_Orangepizero2_focal_legacy_4.9.255 Thanks! 0 Quote
Pabloscotty Posted June 9, 2022 Posted June 9, 2022 This one works to: Armbian_22.05.1_Orangepizero2_focal_current_5.15.43.img 0 Quote
ALIGMSTEN Posted June 10, 2022 Posted June 10, 2022 Hi could you please provide the output of # cat /boot/boot.cmd, from the 'fixed' booted 4.9 legacy kernels 0 Quote
ALIGMSTEN Posted June 13, 2022 Posted June 13, 2022 Changes which look to be causing the boot from memory issue on legacy update build/config/boards/orangepizero2.conf FORCE_BOOTSCRIPT_UPDATE="yes" config/sources/families/sun50iw9.conf BOOTSCRIPT='boot-sun50i-next.cmd:boot.cmd' 0 Quote
ALIGMSTEN Posted June 16, 2022 Posted June 16, 2022 Refrained from stating the obvious here, @armbianorange2hero is a good strategy or armbian-config freeze, as a workaround. 0 Quote
