  • 0
No way to get device serial number from /proc/cpuinfo or elsewhere.
Alexey Guskov
Question
Hey guys, looks like there's no support for board serial number in latest images for Station M2.
Serial number on rk356x is coming from otp memory, so:
1) there are no bindings for `otp` and `cpuinfo` devices in .dts, like here
2) there are no kernel driver to extract data from otp memory, like here
I'm ready to contribute, but not sure what's the future plan for those.
Edited by Alexey Guskov
adding links
Link to comment
Share on other sites
10 answers to this question
Open source development is fun. Join Armbian Linux development team today!
  • 0
2 часа назад, balbes150 сказал:
There is no support for this driver in the main kernel, it is only in the old BSP.
I know there's no support, I checked the sources. But the driver seems to be simple enough and .dts changes are trivial. I can port the code from firefly kernel and create PR, but will probably need some help.
Link to comment
  • 0
16 минут назад, balbes150 сказал:
Ok
I'll start with questions then:
1) i got the armbian 5.17 kernel, patched the dts file, built a new .dtd, tried that on my device
2) Now i can see OTP device:
# find /sys/firmware/devicetree/base/otp\@fe38c000/
/sys/firmware/devicetree/base/otp@fe38c000/
/sys/firmware/devicetree/base/otp@fe38c000/#address-cells
/sys/firmware/devicetree/base/otp@fe38c000/cpu-leakage@1a
/sys/firmware/devicetree/base/otp@fe38c000/cpu-leakage@1a/reg
and cpuinfo device:
# find /sys/firmware/devicetree/base/cpuinfo
/sys/firmware/devicetree/base/cpuinfo/nvmem-cells
/sys/firmware/devicetree/base/cpuinfo/compatible
/sys/firmware/devicetree/base/cpuinfo/nvmem-cell-names
/sys/firmware/devicetree/base/cpuinfo/name
But if I understand correctly, devices with NVMEM cells should be exposed to userspace as /sys/bus/nvmem/devices/somethingsomething/nvmem, but i got nothing there:
# find /sys/bus/nvmem/
/sys/bus/nvmem/
/sys/bus/nvmem/uevent
/sys/bus/nvmem/drivers_autoprobe
/sys/bus/nvmem/drivers_probe
So, am I doing something wrong or this is expected behaviour? Do I need a loaded and active device driver for nvmem cells to be available via /sys/bus/nvmem or correct device tree definition should be enough?
Link to comment
  • 0
16 минут назад, 9bx154 сказал:
This should work:
# cat /proc/device-tree/serial-number
Nope
# find /proc/device-tree/serial-number
find: ‘/proc/device-tree/serial-number’: No such file or directory
Don't see a 'serial-number' device in .dts files for rk356x, are you sure it works on Station M2 for you?
Link to comment
  • 0
4 hours ago, Alexey Guskov said:
sorry, a typo. Of course i meant
/proc/cpuinfo
/proc/cpuinfo
I've corrected the topic subject for you.
Link to comment
Answer this question...
