Dear Friends,
I have been testing Armbian 22.04 Current CLI version and 22.01 Edge Jammy CLI and both does not reboot.
When I reboot Armbian the LEDs stop to blinking but I can clearly listen the rust-drives spinning, also the LCD is still active.
Initially I though it was because the software that handles the LCD but I made a test without it and it was the same. I also thought that was because the spin drives, but when I did the test I made it without the disks as well, therefore I excluded both cases.
Since I didn't read anything about it, I think this issue is affecting just me, any idea where I may look to find out what is preventing the board to reboot properly?
Thanks in advance!
Freezr
  • Werner changed the title to Armbian 22.04 does not reboot
It always helps to see full logs to understand. Even that doesn't tell everything, but helps. Here are mine: http://ix.io/3ZDX
I have update mine and it went well. Even ZFS modules has successfully recompiled upon kernel change:
  ___      _           _     _   _   _  ____ _  _
 / _ \  __| |_ __ ___ (_) __| | | | | |/ ___| || |
| | | |/ _` | '__/ _ \| |/ _` | | |_| | |   | || |_
| |_| | (_| | | | (_) | | (_| | |  _  | |___|__   _|
 \___/ \__,_|_|  \___/|_|\__,_| |_| |_|\____|  |_|
Welcome to Armbian 22.02.1 Jammy with bleeding edge Linux 5.15.30-meson64
No end-user support: unsupported (jammy) userspace!
System load:   2%           	Up time:       7 days 8:49
Memory usage:  11% of 3.70G  	IP:
CPU temp:      47°C           	Usage of /:    3% of 58G
ZFS pool:      Online
[ 19 security updates available, 134 updates total: apt upgrade ]
Last check: 2022-06-07 00:00
Last login: Tue May 31 15:24:08 2022 from 10.0.10.2
Welcome to Armbian 22.05.1 Jammy with bleeding edge Linux 5.17.13-meson64
System load:   42%           	Up time:       0 min
Memory usage:  13% of 3.70G  	IP:
CPU temp:      52°C           	Usage of /:    3% of 58G
ZFS pool:      Online
Boot stability on Amlogic boards has been a long standing battle and I am not sure its over ...
Thank you Igor you are always pretty kind here as well as in the Odroid forum. I hope to find time to get out those information quickly.
I also noticed that shutdown the board doesn't power off the LCD, those are small paper-cuts by the way, also I do not use the Armbian code for the LCD but a GO binary made by a super dude!
Here my log file...
Welcome to Armbian 22.05.1 Jammy with bleeding edge Linux 5.17.5-meson64
System load:   18%           	Up time:       2 min
Memory usage:  7% of 3.70G  	IP:	       10.0.0.203
CPU temp:      33°C           	Usage of /:    3% of 58G
ZFS pool:      Online
Last login: Thu Jun  9 18:32:44 2022 from 10.0.0.154
hc4.log
