bellad Posted September 1, 2015 Posted September 1, 2015 hello, thank you for your image for olimex A10 it's perfect on sd card but i want put in the sata drive i start command ./nand-sata-install and when finish , reboot but reboot , reboot , reboot , etc.... i not understand can you help , thank you
Igor Posted September 1, 2015 Posted September 1, 2015 Hmm. Do you have NAND too?Was there any error during installation. Can you mount image on some linux comp and show the content of /boot/boot.cmd ?
bellad Posted September 1, 2015 Author Posted September 1, 2015 thank you for your reply, i no NAND for on directory /boot with cd rescue , i cannot mount /dev/sda1 ( sdcard ) error EXT4-fs : bad geometry : block count 953088 exceeds size of device (953087 blocks
Igor Posted September 1, 2015 Posted September 1, 2015 Perhaps your SD card is bad or file-system corrupted. Try again with fresh install / new SD card.
bellad Posted September 1, 2015 Author Posted September 1, 2015 i've find ( I think I know why ) before : image on the sd card , i change ( ip interface , keyboard , time ..... for the France ) and after i start ./nand-sata-install now : new image on the sd card , i start nand-sata-install and after i change ( ip interface , keyboard , time ..... for the France ) is gooood can be as chance thank you 1
