mrneilypops Posted October 4, 2016 Posted October 4, 2016 Hi, I am on my third attempt at running armbian on my C2. 16GB eMMC (purchased through Hardkernel) card. The image is; Armbian_5.20_Odroidc2_Debian_jessie_3.14.79_desktop.img On the last two attempts I have followed the getting started guide and performed an update/upgrade after install; apt-get update apt-get upgrade All setup proceeded without issue. However, the C2 refused to restart with a steady blue light on the board (no heartbeat). This is my third attempt and so far I have not upgraded and have tested restart and shutdown a few times...all working well. Can you give me any advice on this issue? Should I wait for a new image?
gahabana Posted October 4, 2016 Posted October 4, 2016 Hi, I am on my third attempt at running armbian on my C2. 16GB eMMC (purchased through Hardkernel) card. The image is; Armbian_5.20_Odroidc2_Debian_jessie_3.14.79_desktop.img On the last two attempts I have followed the getting started guide and performed an update/upgrade after install; apt-get update apt-get upgrade All setup proceeded without issue. However, the C2 refused to restart with a steady blue light on the board (no heartbeat). This is my third attempt and so far I have not upgraded and have tested restart and shutdown a few times...all working well. Can you give me any advice on this issue? Should I wait for a new image? Hi, i haven't had any such issues ... it happened on few occasions (3 out of 50+) that remote restart (sudo reboot via ssh) didn't work and i had to unplug and poweroff C2 and powerit on again. I think either your SD card has problems or board has problems. The only issue (maybe) after sudo apt-get upgrade to do sudo apt-get dist-upgrade (or 1st see if you have any issues) I always - 1. boot fresh image, let initial boot resize root partition (few sseconds), change root password and create additional user id 2. then i reboot 3. only then i do 1st update/upgrade/dist-upgradew 4. reboot try that if it doesnt work i think your SD card is faulty or the board itself
mrneilypops Posted October 4, 2016 Author Posted October 4, 2016 @gahabana Thanks for your reply. I have my doubts about your thoughts 1.This C2 board runs fine with the stock Hardkernel Ubuntu 16.04 image. 2. This eMMC card has had; Ubuntu 16.04 running fine. Arch ARM runnIng fine. 3. Armbian restarts/shutsdown no problem if I do not upgrade. I do note your point; The only issue (maybe) after sudo apt-get upgrade to do sudo apt-get dist-upgrade (or 1st see if you have any issues) I always - 1. boot fresh image, let initial boot resize root partition (few sseconds), change root password and create additional user id 2. then i reboot 3. only then i do 1st update/upgrade/dist-upgradew 4. reboot I will maybe consider this but I will also consider waiting for the next image release...
gahabana Posted October 4, 2016 Posted October 4, 2016 @gahabana Thanks for your reply. I have my doubts about your thoughts 1.This C2 board runs fine with the stock Hardkernel Ubuntu 16.04 image. 2. This eMMC card has had; Ubuntu 16.04 running fine. Arch ARM runnIng fine. 3. Armbian restarts/shutsdown no problem if I do not upgrade. I do note your point; I will maybe consider this but I will also consider waiting for the next image release... hi @mrneilypops , well , i think then you must be right i built images for jessie while 5.17 release and since have been on ubuntu/Xenial ... once i did have a problem when kernel did not upgrade properly but that got fixed by Armbian team next day. I also have not experimented with GUI/X-Windows - i just used bare/console which may have contributed to your problems. Solid blue light usually means u-boot doesnt move on to the kernel ... .maybe after you do upgrade but before booting see what is the difference between then /boot/boot.ini file and what you had before. Beyond that it gets too 'geeky' for me and only Armbian folks may be able to help
mrneilypops Posted October 4, 2016 Author Posted October 4, 2016 @ gahabana Thanks again for the input. No 'biggy' for me as this board is my personal dev/project board...happy to wait for a new image to test.
smn Posted November 13, 2016 Posted November 13, 2016 I am experiencing the same or at least very similar problem. Setup: Odroid C2 with 8GB eMMC module from Hardkernel Armbian image downloaded via website (5.21 it claims) since I am not able to compile it myself on Yakkety. Procedure: Flash img on eMMC via SD card adapter Boot Ordroid C2, login as root, create user, login with new credentials Run: sudo apt-get update sudo apt-get upgrade Output as follows: ___ _ _ _ ____ ____ / _ \ __| |_ __ ___ (_) __| | / ___|___ \ | | | |/ _` | '__/ _ \| |/ _` | | | __) | | |_| | (_| | | | (_) | | (_| | | |___ / __/ \___/ \__,_|_| \___/|_|\__,_| \____|_____| Welcome to ARMBIAN Debian GNU/Linux 8 (jessie) 3.14.79-odroidc2 System load: 0.02 Up time: 2 min Memory usage: 3 % of 1976Mb IP: 192.168.2.22 CPU temp: 42°C Usage of /: 15% of 7.0G Last login: Sun Nov 13 22:46:49 2016 from ssp-poseidon.fritz.box smn@odroidc2:~$ less /boot/boot.ini smn@odroidc2:~$ sudo apt-get upgrade [sudo] password for smn: Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done 0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. smn@odroidc2:~$ sudo apt-get update Get:1 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates InRelease [63.1 kB] Get:2 [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie InRelease [8683 B] Ign [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie InRelease Get:3 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/main arm64 Packages [301 kB] Get:4 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates InRelease [145 kB] Get:5 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports InRelease [166 kB] Get:6 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/contrib arm64 Packages [1138 B] Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie Release.gpg Get:7 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/non-free arm64 Packages [14 B] Get:8 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/contrib Translation-en [1211 B] Get:9 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/main Translation-en [170 kB] Get:10 [url=http://security.debian.org]http://security.debian.org[/url]jessie/updates/non-free Translation-en [14 B] Get:11 [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/main arm64 Packages [8532 B] Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie Release Get:12 [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/utils arm64 Packages [2407 B] Get:13 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/main arm64 Packages/DiffIndex [6424 B] Get:14 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/contrib arm64 Packages [32 B] Get:15 [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/jessie-desktop arm64 Packages [14 B] Get:16 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/non-free arm64 Packages/DiffIndex [736 B] Get:17 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/contrib Translation-en [14 B] Get:18 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/main Translation-en/DiffIndex [2704 B] Get:19 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/non-free Translation-en/DiffIndex [736 B] Get:20 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/main arm64 2016-10-25-2111.01.pdiff [524 B] Get:21 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/main arm64 2016-11-07-2025.04.pdiff [532 B] Get:22 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-updates/main arm64 2016-11-07-2025.04.pdiff [532 B] Get:23 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main arm64 Packages/DiffIndex [27.8 kB] Get:24 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 Packages/DiffIndex [19.0 kB] Get:25 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib Translation-en/DiffIndex [6484 B] Get:26 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free arm64 Packages/DiffIndex [5086 B] Get:27 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main Translation-en/DiffIndex [27.8 kB] Get:28 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free Translation-en/DiffIndex [10.8 kB] Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/main arm64 Packages Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/non-free arm64 Packages Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/contrib Translation-en Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/contrib arm64 Packages Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/non-free Translation-en Hit [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie/main Translation-en Get:29 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 2016-10-28-0401.32.pdiff [241 B] Get:30 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 2016-11-03-1428.04.pdiff [1006 B] Get:31 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 2016-11-04-1427.43.pdiff [1009 B] Get:32 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 2016-11-04-2028.25.pdiff [54 B] Get:33 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib arm64 2016-11-04-2028.25.pdiff [54 B] Get:34 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib 2016-11-03-1428.04.pdiff [408 B] Get:35 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib 2016-11-04-2028.25.pdiff [29 B] Get:36 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/contrib 2016-11-04-2028.25.pdiff [29 B] Get:37 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free arm64 2016-10-09-1513.45.pdiff [634 B] Get:38 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free arm64 2016-11-06-1425.06.pdiff [518 B] Ign [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/jessie-desktop Translation-en Get:39 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free arm64 2016-11-06-1425.06.pdiff [518 B] Get:40 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-09-1513.45.pdiff [4398 B] Get:41 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-10-1510.00.pdiff [943 B] Ign [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/main Translation-en Get:42 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-11-1019.06.pdiff [110 B] Ign [url=http://apt.armbian.com]http://apt.armbian.com[/url]jessie/utils Translation-en Get:43 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-13-0920.21.pdiff [320 B] Get:44 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-13-2121.18.pdiff [343 B] Get:45 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-17-0322.17.pdiff [137 B] Get:46 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-17-1512.33.pdiff [6447 B] Get:47 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-18-0313.17.pdiff [425 B] Get:48 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-22-0328.41.pdiff [33 B] Get:49 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-30-0228.03.pdiff [140 B] Get:50 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-10-26-1509.08.pdiff [181 B] Get:51 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-02-0827.56.pdiff [13.2 kB] Get:52 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-02-1427.32.pdiff [626 B] Get:53 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-06-1425.06.pdiff [7587 B] Get:54 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-06-2026.47.pdiff [516 B] Get:55 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-07-0825.43.pdiff [338 B] Get:56 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main 2016-11-07-0825.43.pdiff [338 B] Get:57 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free 2016-10-09-1513.45.pdiff [2468 B] Get:58 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free 2016-10-11-1019.06.pdiff [85 B] Get:59 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free 2016-11-02-0827.56.pdiff [2253 B] Get:60 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free 2016-11-06-1425.06.pdiff [330 B] Get:61 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/main arm64 Packages [722 kB] Get:62 [url=http://httpredir.debian.org]http://httpredir.debian.org[/url]jessie-backports/non-free 2016-11-06-1425.06.pdiff [330 B] Fetched 1742 kB in 4s (412 kB/s) Reading package lists... Done smn@odroidc2:~$ sudo apt-get upgrade Reading package lists... Done Building dependency tree Reading state information... Done Calculating upgrade... Done The following packages will be upgraded: armbian-firmware bind9-host curl dnsutils hostapd libbind9-90 libcurl3 libcurl3-gnutls libdns-export100 libdns100 libirs-export91 libisc-export95 libisc95 libisccc90 libisccfg-export90 libisccfg90 liblwres90 libmysqlclient18 linux-dtb-odroidc2 linux-headers-odroidc2 linux-image-odroidc2 linux-jessie-root-odroidc2 linux-libc-dev linux-u-boot-odroidc2-default mysql-common sunxi-tools tar tzdata 28 upgraded, 0 newly installed, 0 to remove and 0 not upgraded. Need to get 27.6 MB of archives. After this operation, 79.9 kB of additional disk space will be used. Do you want to continue? [Y/n] y Get:1 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main tar arm64 1.27.1-2+deb8u1 [653 kB] Get:2 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main curl arm64 7.38.0-4+deb8u5 [194 kB] Get:3 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main armbian-firmware arm64 5.22 [1308 kB] Get:4 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libcurl3 arm64 7.38.0-4+deb8u5 [227 kB] Get:5 [url=http://httpredir.debian.org/debian/]http://httpredir.debian.org/debian/[/url]jessie-updates/main tzdata all 2016i-0+deb8u1 [186 kB] Get:6 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libcurl3-gnutls arm64 7.38.0-4+deb8u5 [221 kB] Get:7 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libisc-export95 arm64 1:9.9.5.dfsg-9+deb8u8 [118 kB] Get:8 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libdns-export100 arm64 1:9.9.5.dfsg-9+deb8u8 [376 kB] Get:9 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libisccfg-export90 arm64 1:9.9.5.dfsg-9+deb8u8 [37.5 kB] Get:10 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libirs-export91 arm64 1:9.9.5.dfsg-9+deb8u8 [36.1 kB] Get:11 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main mysql-common all 5.5.53-0+deb8u1 [75.5 kB] Get:12 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libmysqlclient18 arm64 5.5.53-0+deb8u1 [617 kB] Get:13 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main dnsutils arm64 1:9.9.5.dfsg-9+deb8u8 [111 kB] Get:14 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main bind9-host arm64 1:9.9.5.dfsg-9+deb8u8 [63.1 kB] Get:15 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libisc95 arm64 1:9.9.5.dfsg-9+deb8u8 [142 kB] Get:16 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libdns100 arm64 1:9.9.5.dfsg-9+deb8u8 [555 kB] Get:17 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libisccc90 arm64 1:9.9.5.dfsg-9+deb8u8 [34.0 kB] Get:18 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libisccfg90 arm64 1:9.9.5.dfsg-9+deb8u8 [50.7 kB] Get:19 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main liblwres90 arm64 1:9.9.5.dfsg-9+deb8u8 [47.4 kB] Get:20 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/utils hostapd arm64 1:2.5~armbian5.23+1 [295 kB] Get:21 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main libbind9-90 arm64 1:9.9.5.dfsg-9+deb8u8 [40.2 kB] Get:22 [url=http://security.debian.org/]http://security.debian.org/[/url]jessie/updates/main linux-libc-dev arm64 3.16.36-1+deb8u2 [1009 kB] Get:23 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main linux-dtb-odroidc2 arm64 5.23 [8034 B] Get:24 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main linux-headers-odroidc2 arm64 5.23 [9307 kB] Get:25 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main linux-image-odroidc2 arm64 5.23 [11.4 MB] Get:26 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main linux-jessie-root-odroidc2 arm64 5.23 [306 kB] Get:27 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/main linux-u-boot-odroidc2-default arm64 5.23 [221 kB] Get:28 [url=http://apt.armbian.com/]http://apt.armbian.com/[/url]jessie/utils sunxi-tools arm64 1.3-1~armbian5.23+1 [31.2 kB] Fetched 27.6 MB in 2s (9370 kB/s) perl: warning: Setting locale failed. perl: warning: Please check that your locale settings: LANGUAGE = "en_US.UTF-8", LC_ALL = (unset), LC_TIME = "en_GB.UTF-8", LC_MONETARY = "en_GB.UTF-8", LC_ADDRESS = "en_GB.UTF-8", LC_TELEPHONE = "en_GB.UTF-8", LC_MESSAGES = "en_US.UTF-8", LC_NAME = "en_GB.UTF-8", LC_MEASUREMENT = "en_GB.UTF-8", LC_IDENTIFICATION = "en_GB.UTF-8", LC_NUMERIC = "en_GB.UTF-8", LC_PAPER = "en_GB.UTF-8", LANG = "en_US.UTF-8" are supported and installed on your system. perl: warning: Falling back to a fallback locale ("en_US.UTF-8"). locale: Cannot set LC_ALL to default locale: No such file or directory Preconfiguring packages ... (Reading database ... 48977 files and directories currently installed.) Preparing to unpack .../tar_1.27.1-2+deb8u1_arm64.deb ... Unpacking tar (1.27.1-2+deb8u1) over (1.27.1-2+b3) ... Processing triggers for mime-support (3.58) ... Processing triggers for man-db (2.7.0.2-5) ... Setting up tar (1.27.1-2+deb8u1) ... (Reading database ... 48976 files and directories currently installed.) Preparing to unpack .../curl_7.38.0-4+deb8u5_arm64.deb ... Unpacking curl (7.38.0-4+deb8u5) over (7.38.0-4+deb8u4) ... Preparing to unpack .../libcurl3_7.38.0-4+deb8u5_arm64.deb ... Unpacking libcurl3:arm64 (7.38.0-4+deb8u5) over (7.38.0-4+deb8u4) ... Preparing to unpack .../libcurl3-gnutls_7.38.0-4+deb8u5_arm64.deb ... Unpacking libcurl3-gnutls:arm64 (7.38.0-4+deb8u5) over (7.38.0-4+deb8u4) ... Preparing to unpack .../libisc-export95_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libisc-export95 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libdns-export100_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libdns-export100 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libisccfg-export90_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libisccfg-export90 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libirs-export91_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libirs-export91 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../mysql-common_5.5.53-0+deb8u1_all.deb ... Unpacking mysql-common (5.5.53-0+deb8u1) over (5.5.52-0+deb8u1) ... Preparing to unpack .../libmysqlclient18_5.5.53-0+deb8u1_arm64.deb ... Unpacking libmysqlclient18:arm64 (5.5.53-0+deb8u1) over (5.5.52-0+deb8u1) ... Preparing to unpack .../tzdata_2016i-0+deb8u1_all.deb ... Unpacking tzdata (2016i-0+deb8u1) over (2016f-0+deb8u1) ... Processing triggers for man-db (2.7.0.2-5) ... Setting up tzdata (2016i-0+deb8u1) ... locale: Cannot set LC_ALL to default locale: No such file or directory Current default time zone: 'Europe/Ljubljana' Local time is now: Sun Nov 13 22:53:28 CET 2016. Universal Time is now: Sun Nov 13 21:53:28 UTC 2016. Run 'dpkg-reconfigure tzdata' if you wish to change it. (Reading database ... 48982 files and directories currently installed.) Preparing to unpack .../dnsutils_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking dnsutils (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../bind9-host_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking bind9-host (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libisc95_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libisc95 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libdns100_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libdns100 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libisccc90_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libisccc90 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libisccfg90_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libisccfg90 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../liblwres90_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking liblwres90 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../libbind9-90_1%3a9.9.5.dfsg-9+deb8u8_arm64.deb ... Unpacking libbind9-90 (1:9.9.5.dfsg-9+deb8u8) over (1:9.9.5.dfsg-9+deb8u7) ... Preparing to unpack .../armbian-firmware_5.22_arm64.deb ... Unpacking armbian-firmware (5.22) over (5.21) ... Preparing to unpack .../hostapd_1%3a2.5~armbian5.23+1_arm64.deb ... Unpacking hostapd (1:2.5~armbian5.23+1) over (1:2.5~armbian5.21+1) ... Preparing to unpack .../linux-dtb-odroidc2_5.23_arm64.deb ... Unpacking linux-dtb-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-headers-odroidc2_5.23_arm64.deb ... Unpacking linux-headers-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-image-odroidc2_5.23_arm64.deb ... /etc/kernel/preinst.d/initramfs-cleanup: 17: /etc/kernel/preinst.d/initramfs-cleanup: linux-version: not found Unpacking linux-image-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-jessie-root-odroidc2_5.23_arm64.deb ... Adding 'diversion of /etc/mpv/mpv.conf to /etc/mpv/mpv-dist.conf by linux-jessie-root-odroidc2' Unpacking linux-jessie-root-odroidc2 (5.23) over (5.21) ... Preparing to unpack .../linux-libc-dev_3.16.36-1+deb8u2_arm64.deb ... Unpacking linux-libc-dev:arm64 (3.16.36-1+deb8u2) over (3.16.36-1+deb8u1) ... Preparing to unpack .../linux-u-boot-odroidc2-default_5.23_arm64.deb ... Unpacking linux-u-boot-odroidc2-default (5.23) over (5.21) ... Preparing to unpack .../sunxi-tools_1.3-1~armbian5.23+1_arm64.deb ... Unpacking sunxi-tools (1.3-1~armbian5.23+1) over (1.3-1~armbian5.21+1) ... Processing triggers for man-db (2.7.0.2-5) ... Processing triggers for systemd (215-17+deb8u5) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... ln: failed to create hard link '/boot/initrd.img-3.14.79-odroidc2.dpkg-bak' => '/boot/initrd.img-3.14.79-odroidc2': Operation not permitted update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Setting up libcurl3:arm64 (7.38.0-4+deb8u5) ... Setting up curl (7.38.0-4+deb8u5) ... Setting up libcurl3-gnutls:arm64 (7.38.0-4+deb8u5) ... Setting up libisc-export95 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libdns-export100 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libisccfg-export90 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libirs-export91 (1:9.9.5.dfsg-9+deb8u8) ... Setting up mysql-common (5.5.53-0+deb8u1) ... Setting up libmysqlclient18:arm64 (5.5.53-0+deb8u1) ... Setting up libisc95 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libdns100 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libisccc90 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libisccfg90 (1:9.9.5.dfsg-9+deb8u8) ... Setting up libbind9-90 (1:9.9.5.dfsg-9+deb8u8) ... Setting up liblwres90 (1:9.9.5.dfsg-9+deb8u8) ... Setting up bind9-host (1:9.9.5.dfsg-9+deb8u8) ... Setting up dnsutils (1:9.9.5.dfsg-9+deb8u8) ... Setting up armbian-firmware (5.22) ... Setting up hostapd (1:2.5~armbian5.23+1) ... Setting up linux-dtb-odroidc2 (5.23) ... Setting up linux-headers-odroidc2 (5.23) ... Compiling headers - please wait ... Setting up linux-image-odroidc2 (5.23) ... update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Setting up linux-jessie-root-odroidc2 (5.23) ... Setting up linux-libc-dev:arm64 (3.16.36-1+deb8u2) ... Setting up linux-u-boot-odroidc2-default (5.23) ... Updating u-boot on device /dev/mmcblk0 Setting up sunxi-tools (1.3-1~armbian5.23+1) ... Processing triggers for libc-bin (2.19-18+deb8u6) ... Processing triggers for initramfs-tools (0.120+deb8u2) ... ln: failed to create hard link '/boot/initrd.img-3.14.79-odroidc2.dpkg-bak' => '/boot/initrd.img-3.14.79-odroidc2': Operation not permitted update-initramfs: Generating /boot/initrd.img-3.14.79-odroidc2 Reboot - everything works fine and as expected Reboot again - stuck in uBoot with solid blue LED (no heartbeat from kernel) I have repeated the above procedure several times and it is 100% reproducible for me. Is there any information you would need in order to trace down this problem?
mervinb Posted November 20, 2016 Posted November 20, 2016 I hit the same error as several other posters - eMMC boot hangs after 2nd reboot after an update. I've verified with two C2s, and two eMMC cards, and a least 20 fresh installations! The image I've used is one from two days ago. I did a fresh install and this time disabled the armbian source, and after update/upgrade the reboots no longer hung the system. Please let us know when a fix for the issue is created. As far as I can see, the eMMC reboot problem has been around since August. This distro looks great, and it would be a pity if this serious issue is not fixed.
Igor Posted November 20, 2016 Posted November 20, 2016 I hit the same error as several other posters - eMMC boot hangs after 2nd reboot after an update. I've verified with two C2s, and two eMMC cards, and a least 20 fresh installations! The image I've used is one from two days ago. I did a fresh install and this time disabled the armbian source, and after update/upgrade the reboots no longer hung the system. Please let us know when a fix for the issue is created. As far as I can see, the eMMC reboot problem has been around since August. This distro looks great, and it would be a pity if this serious issue is not fixed. It should be fixed - check image from BETA builds.
