Dear all,
I'm just trying to get a HummingBoard-Edge (i.MX6 Quad, 2GB) working with Armbian_5.20_Cubox-i_Ubuntu_xenial_4.7.3. Unfortunately, the board is recognized as CuBox-i, U-Boot loads the wrong dtb file (imx6q-cubox-i.dtb) and I have no access to the internal eMMC card (mmcblk1). By the way, it's the same issue with ArchLinuxArm.
Do I have to somehow modify the U-Boot environment variables to get the board being recognized as Hummingoard2? Do you have any other ideas?
Thank you very much for your help!
Best regards
Andreas
U-Boot 2013.10-rc4 (Aug 31 2016 - 17:35:12)
CPU:   Freescale i.MX6Q rev1.5 at 792 MHz
Reset cause: WDOG
Board: MX6-CuBox-i
DRAM:  2 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Hit any key to stop autoboot:  0
Did you try the 'setenv fdtfile' approach as outlined here already?
@tkaiser: Thank you for the hint. boot.cmd now reads as follows. I compiled it via mkimage.
setenv fdtfile imx6q-hummingboard2.dtb
#run autodetectfdt
setenv ramdisk_addr 0x14800000
setenv bootargs "root=/dev/mmcblk0p1 rootfstype=ext4 rootwait console=ttymxc0,1$
ext2load mmc 0 ${fdt_addr} /boot/dtb/${fdt_file} || fatload mmc 0 ${fdt_addr} /$
ext2load mmc 0 ${ramdisk_addr} /boot/uInitrd || fatload mmc 0 ${ramdisk_addr} u$
ext2load mmc 0 ${loadaddr} /boot/zImage || fatload mmc 0 ${loadaddr} zImage || $
bootz ${loadaddr} ${ramdisk_addr} ${fdt_addr}
# Recompile with:
The device is still recognized as SolidRun Cubox-i Dual/Quad. Parts of the boot log:
Reset cause: WDOG
Board: MX6-CuBox-i
DRAM:  2 GiB
MMC:   FSL_SDHC: 0
In:    serial
Out:   serial
Err:   serial
Net:   FEC [PRIME]
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Booting Linux on physical CPU 0x0
Linux version 4.7.3-cubox (root@xenial) (gcc version 4.9.4 20151028 (prerelease) (Linaro GCC 4.9-2016.02) ) #27 SMP Wed Sep 14 23:06:12 CEST 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=50c5387d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: SolidRun Cubox-i Dual/Quad
mmc0 = SD card functional.
mmc0: host does not support reading read-only switch, assuming write-enable
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SL08G 7.40 GiB
 mmcblk0: p1
mmc1 = eMMC (?) shows up in the log but not availabe under /dev/disks
sdhci-esdhc-imx 2190000.usdhc: allocated mmc-pwrseq
mmc1: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
mmc1: new high speed SDIO card at address 0001
@Igor: I will report the issue in the SR forum.
You made a typo:
fdt_file not fdtfile
That's why there was no change. And those:
in log are due too default enabled eMMC for all boards. If you board does not have it you will see this ... it must be fixed in u-boot.
Thank you, Igor, that fixed it! :)
Starting kernel ...
Machine model: SolidRun HummingBoard2 Dual/Quad
eMMC is now accessible:
mmc1: new DDR MMC card at address 0001
mmcblk1: mmc1:0001 4FPD3R 3.64 GiB
mmcblk1boot0: mmc1:0001 4FPD3R partition 1 4.00 MiB
mmcblk1boot1: mmc1:0001 4FPD3R partition 2 4.00 MiB
Key type encrypted registered
mmcblk1rpmb: mmc1:0001 4FPD3R partition 3 512 KiB
