vinicius Posted August 13, 2022 Posted August 13, 2022 Hi. I'm trying to use GPIO's of OrangePi PC+ and after install WiringOP, when I run the gpio readall, all my GPIO's Mode are showing OFF. I tryed enable in armbian-config, but I have only pps-gpio and w1-gpio, I tryed enable both but doesn't work too. Someone knows some solution? Thanks. 0 Quote
Igor Posted August 13, 2022 Posted August 13, 2022 You don't need to install anything. This is a script I use on a very similar device: #!/bin/bash task(){ gp=$1 [[ ! -d /sys/class/gpio/gpio${gp} ]] && echo ${gp} > /sys/class/gpio/export echo "out" > /sys/class/gpio/gpio${gp}/direction echo "0" > /sys/class/gpio/gpio${gp}/value sleep 10 echo "1" > /sys/class/gpio/gpio${gp}/value } task "$1" doing this. More info: https://www.google.com/search?q=sunxi+gpio 0 Quote
vinicius Posted August 15, 2022 Author Posted August 15, 2022 (edited) Hi Igor, thanks for your answer, but I tried it too (not your script yet, but commands export, direction, value in /sys/class/gpio). I don't know why doesn't work. Edited August 15, 2022 by vinicius 0 Quote
vinicius Posted August 15, 2022 Author Posted August 15, 2022 (edited) +------+-----+----------+------+---+OrangePiH3+---+------+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+------+---+----++----+---+------+----------+-----+------+ | | | 3.3V | | | 1 || 2 | | | 5V | | | | 12 | 0 | SDA.0 | OFF | 0 | 3 || 4 | | | 5V | | | | 11 | 1 | SCL.0 | OFF | 0 | 5 || 6 | | | GND | | | | 6 | 2 | PA6 | OFF | 0 | 7 || 8 | 0 | OFF | TXD.3 | 3 | 13 | | | | GND | | | 9 || 10 | 0 | OFF | RXD.3 | 4 | 14 | | 1 | 5 | RXD.2 | OFF | 0 | 11 || 12 | 0 | IN | PD14 | 6 | 110 | | 0 | 7 | TXD.2 | OFF | 0 | 13 || 14 | | | GND | | | | 3 | 8 | CTS.2 | OFF | 0 | 15 || 16 | 0 | OFF | PC04 | 9 | 68 | | | | 3.3V | | | 17 || 18 | 0 | OFF | PC07 | 10 | 71 | | 64 | 11 | MOSI.0 | OFF | 0 | 19 || 20 | | | GND | | | | 65 | 12 | MISO.0 | OFF | 0 | 21 || 22 | 0 | OFF | RTS.2 | 13 | 2 | | 66 | 14 | SCLK.0 | OFF | 0 | 23 || 24 | 0 | OFF | CE.0 | 15 | 67 | | | | GND | | | 25 || 26 | 0 | OFF | PA21 | 16 | 21 | | 19 | 17 | SDA.1 | OFF | 0 | 27 || 28 | 0 | OFF | SCL.1 | 18 | 18 | | 7 | 19 | PA07 | OFF | 0 | 29 || 30 | | | GND | | | | 8 | 20 | PA08 | OFF | 0 | 31 || 32 | 0 | OFF | RTS.1 | 21 | 200 | | 9 | 22 | PA09 | OFF | 0 | 33 || 34 | | | GND | | | | 10 | 23 | PA10 | OFF | 0 | 35 || 36 | 0 | OFF | CTS.1 | 24 | 201 | | 20 | 25 | PA20 | OFF | 0 | 37 || 38 | 0 | OFF | TXD.1 | 26 | 198 | | | | GND | | | 39 || 40 | 0 | OFF | RXD.1 | 27 | 199 | +------+-----+----------+------+---+----++----+---+------+----------+-----+------+ | GPIO | wPi | Name | Mode | V | Physical | V | Mode | Name | wPi | GPIO | +------+-----+----------+------+---+OrangePiH3+---+------+----------+-----+------+ The physical pin is 16, GPIO 68. Running the script, nothing happens passing with params 68. Edited August 15, 2022 by vinicius 0 Quote
vinicius Posted August 26, 2022 Author Posted August 26, 2022 (edited) Solved! With BC547 transistor... Edited August 26, 2022 by vinicius 0 Quote
bjorns Posted February 10, 2023 Posted February 10, 2023 what do you mean? On 8/26/2022 at 9:47 PM, vinicius said: Solved! With BC547 transistor... 0 Quote
