system76 Posted August 19, 2022 Share Posted August 19, 2022 (edited) Hello, I've been just started using Armbian on my Tinker Board 2s and i'm facing problem that i dont get any output on my acer portable monitor using usb type - c. But when i use tinker os i get output on my acer portable monitor. Please help Edited August 19, 2022 by system76 0 Quote Link to comment Share on other sites More sharing options...
Igor Posted August 19, 2022 Share Posted August 19, 2022 33 minutes ago, system76 said: But when i use tinker os i get output on my acer portable monitor. https://docs.armbian.com/User-Guide_FAQ/#why-does-hardware-feature-xy-work-in-old-kernel-but-not-in-more-recent-one 33 minutes ago, system76 said: Please help Contact ASUS. This is their duty and expense to cover. Or yours. Our build system will save you few weeks so welcome to make a donation. It is very expensive to keep it maintained. https://docs.armbian.com/Developer-Guide_Build-Preparation/ When you are done, by you or by people you will be hiring to solve this problem for you, share a patch with others. Armbian does not need this to function. You do. 0 Quote Link to comment Share on other sites More sharing options...
TonyMac32 Posted August 19, 2022 Share Posted August 19, 2022 I've had trouble supporting this board, a lot of "s" variant boards in particular do not like to boot using mainline ATF. The only reason there are mainline images is because I created a device tree/got a supply driver/etc. The DP over type C should work provided the device tree is updated, you can find examples on several other RK3399 boards we support. 0 Quote Link to comment Share on other sites More sharing options...
